How To: Replacing Spark Plugs and Wires on 5VZ-FE 3.4 V6
Discussion in '1st Gen. Tacomas (1995-2004)' started by TacomaJPP, Jan 31, 2013.
  1. Jun 17, 2013 at 12:57 AM
    flatblack
    flatblack Well-Known Member
    CDA
    95.5 Tacoma 3.4 Manual
    :eek:
    what a pain in the !@#
    This is probably the easiest vehicle I've ever worked on
    Guess they had to make something WAY more involved than it should be
    Thanks for the great write-up!
  2. Jul 20, 2013 at 1:22 PM
    wbjdmd
    wbjdmd Active Member
    Brad
    Indianola, MS
    2016 Tacoma TRD Sport DC
    Thanks for the write up. Wouldn't have tried it without it! Nothing to it with your guidance. By the way, all of the NKG plugs I used were way off on the gap. Probably more like .020 for most of them.
  3. Jul 21, 2013 at 10:44 AM
    tcrhino
    tcrhino Active Member
    Twin Cities, MN
    4x4
    3" toytec suspension lifted
    YES! i was waiting for one of this! Someone please sticky this! Thanks!
  4. Jul 21, 2013 at 11:14 PM
    mrbillbrown
    mrbillbrown Member
    mrbill
    Edmond,OK
    01 Limited TRD Off-Road
    Saved for later. Thanks
  5. Jul 28, 2013 at 10:54 PM
    Mac The Steve
    Mac The Steve Member
    Central CA
    Tacoma SR5 4x4
    Custom Innovation shell
    That is the most valuable post I've ever read - Thank you! My "New" 1995 Tacoma v6 with 206,000 miles was mostly an uneducated purchase...but I dig this truck! No mods & very little recent maintenance. Plugs & oil first & I'll be back for everybody else's expertise.
  6. Aug 3, 2013 at 8:13 PM
    TacomaJPP
    TacomaJPP [OP] To secure peace, is to prepare for war
    East TN
    03 4WD TRD XTD Cab
    Snugtop Camper Brushguard
    Glad it helps.
  7. Sep 12, 2013 at 2:39 PM
    12Mk6gti
    12Mk6gti Well-Known Member
    Scott
    Sunshine state
    2019 Nautical Blue TRD OffRoad 4Runner
    Thanks for the post, just installed my new plugs!
  8. Nov 9, 2013 at 11:10 AM
    Cr250jumper
    Cr250jumper Señor member
    The moon
    50 shades of tan©
    Tacoma with some stuff melted to it
    done, thanks for the write up :)
  9. Nov 9, 2013 at 11:54 AM
    BamaToy1997
    Bill
    Navarre, FL
    Due to the detail and professional lay out, this should definitely become a sticky.
  10. Dec 17, 2013 at 10:18 AM
    Hacksaw34
    Hacksaw34 Member
    Dtc
    2000 Tacoma 4wd
    This was incredibly helpful. Changed my plugs this weekend using this as a guide and everything worked incredibly well. Previous owner had changed the driver side plugs before but the passenger side were all original with 188,000 miles on them. blew my mind
  11. Dec 30, 2013 at 2:50 PM
    mmadej87
    mmadej87 Mayday
    NMB, FL
    98 Xcab Prerunner
    This may be a stupid question but why does the wire pack only come with 3 of the 6 boots? And I assume you cleaned the passenger side boots because the wire pack didnt have them? Would make more sense to me that the kit would include all 6 boots.
  12. Dec 30, 2013 at 3:06 PM
    Cr250jumper
    The moon
    50 shades of tan©
    Because the coils are on the boot for the passenger side (cant rember the correct phrase lol) so the wires only go from the coil pack to the driver side
  13. Dec 30, 2013 at 3:41 PM
    mmadej87
    mmadej87 Mayday
    NMB, FL
    98 Xcab Prerunner
    Thanks! ill be picking up these parts tomorrow, dont know if plugs have ever been done in my truck @ 136k mi
  14. Jan 25, 2014 at 5:55 PM
    Fisher4trout
    Fisher4trout New Member
    FAIRFAX CA.
    04 TACOMA
    This great write up, and an upcoming trip to the Mojave, motivated me to change my plugs today at 99,564 miles. My truck was beginning to start a bit rougher and knocking at times. The spark plug change made an instant difference. Truck is running smoother and seems to have more power!
    I used NGK plugs and a #57 drill bit (0.043") to check the gaps. All but one was spot on. On the passenger side I saw no reason to remove the MAF (electrically or physically). Removal of the intake pipe was enough to reach all the plugs easily. The #6 cylinder has the most difficult to access but even that was not really a problem. Anyone that thinks this job is hard should try changing plugs on a V-6 Ford Ranger!
    The old plug gaps had worn to between 0.058 and 0.060 inches. One thing I wanted to do was check the coil resistance on both the low voltage and the high voltage sides. Unfortunately I was unable to find the factory recommended resistances. I'm assuming that is the reason for the multi-meter seen in the original post.
    As there is some question as to the use of anti-seize on spark plug threads I'll get my two cents in. I used anti-seize on this job for two reasons. One is that I don't have a torque wrench. This means I turned them in by hand till the seals seat on the head then turn them just over half a turn more. I believe that the anti-seize compound allows me to more easily feel when the plugs hit the landing. Number two is I believe anti seize will allow the plugs to be removed with out damage to the heads.
    If a torque wrench is used the number one reason may not apply.
  15. May 7, 2014 at 6:02 AM
    #35
    TreadUp
    TreadUp Well-Known Member
    Justin
    Belville, NC
    2007 DBCL TRD Sport
    Bilstein 5100's Toytec Springs / AAL SOS Sliders FN Five Star Wheels Falken Wild Peak AT3W 32"x 10.5"
    Does anyone see an issue with running a single electrode BKR5E-11 NGK V power plug instead of the double electrode? The plugs I have are what the part store supplied me.
    Path of least resistance seems the only advantage. With having 2 electrodes, as one wears down the other one comes into play more?
    Thanks
  16. May 7, 2014 at 6:41 AM
    #36
    two4spooky
    two4spooky Active Member
    Stuart
    AL
    '97 Tacoma SC 4x4 V6 MT
    LockRight locker, LineX
    I have been running a single electrode iridium tipped plug for 8-10 years and I around 130k miles. I know the manual specifically calls for the dual electrode. I am about to change plugs again and will again use the single tipped iridium. No issues, no problems and long plug life.
  17. May 7, 2014 at 7:15 AM
    #37
    TreadUp
    Justin
    Belville, NC
    2007 DBCL TRD Sport
    Thanks spooky. I will go back with what the manufacturer suggest next time but for now the new NGK plugs and wires should make a difference.
  18. May 7, 2014 at 7:49 AM
    #38
    asus611
    asus611 Well-Known Member
    CA
    03 Double Cab Prerunner
    How often is everyone changing the wires? I change my spark plugs every 30k but I have never changed the wires. Truck seems to run fine, just wondering if I should toss out the original wires and put in a new set
  19. May 7, 2014 at 8:18 AM
    #39
    two4spooky
    Stuart
    AL
    I'm using iridium plugs, iridium plugs last a long time. I'm going for replacing plugs and wires every 100k.
  20. May 7, 2014 at 8:55 AM
    #40
    Trapperr
    Trapperr Well-Known Member
    Reno, NV
    2002 Tacoma Double Cab 4x4 3.4l V6
    How many miles on the original wires? I thought mine ran fine until I replaced them with the blue NGK wire set at 117k. VERY noticeable difference in acceleration and mpg. The truck just ran better all around.
    As far as plugs, it's not that hard to go down to the dealership and drop $20 on a set of oem plugs. It's what the trucks were designed to run.
