How To: Replacing Spark Plugs and Wires on 5VZ-FE 3.4 V6
Discussion in '1st Gen. Tacomas (1995-2004)' started by TacomaJPP, Jan 31, 2013.
  1. Apr 15, 2016 at 9:20 PM
    #81
    jaywill808
    jaywill808 Well-Known Member
    2001 Tacoma
    Just changed my plugs and wires today. I used NGK Iridium plugs instead of the dual post plugs. I did not space them truck runs real good. I also got an extra 3 boots out of paranoia which I now need to return. Great post and very helpful pictures. Thank you.
  2. May 3, 2016 at 10:52 PM
    #82
    Tacomoon
    Tacomoon Member
    Art
    Oregon
    2004 Prerunner and 2004 TRD both Lunar
    Huge rack
    Got the job done, thanks! Great article and the pics were a huge help. Zoomed in on the tablet and it was spot on.
    Gaps were not .044, or consistent (denso). Much appreciated
  3. May 31, 2016 at 10:41 AM
    #83
    jjsul
    jjsul Well-Known Member
    James
    New Hampshire
    95.5 OME
    Thank you! I just finished up this project, took me longer, about an hour and a half. All six of my plugs were Denso's, same part numbers as the plugs in the original post.
    I didn't adjust the gaps on my plugs, I wasn't quite sure whether to do so or not with all the back and forth I found in this post and elsewhere. The plugs that came out ranged from .042-.046? and the new plugs were all .032-.033 I just said screw it and plugged them in. Its running fine now.
    opteron likes this.
  4. Jun 24, 2016 at 9:15 PM
    #84
    Oldtimeytoyotaowner
    Oldtimeytoyotaowner New Member
    Bob
    2003 Tacoma xtracab 4x4
    Very helpful but I kept trying to pry the side of the n shape on the clip for the coil. Figured out the tab is on the engine side of the clip that simply pries away from the clip. First time having to change the plugs on a '03 as I bought it used. Great tips on this. Also bought 6 plug wires. Did not know that I only needed 3 and neither did the clerk at O'Reilly. Taking back tomorrow to get the coils. Haynes is simply terrible for a repair book as it had no direction at all other than take off the boot, take out the plug and put in the new plug. Thanks.
  5. Aug 12, 2016 at 1:16 PM
    #85
    bayareayota
    bayareayota Well-Known Member
    Bay Area
    2004 Toyota Tacoma extra cab v6 Trd
    Prinsu 32" K02 OME
    how do you adjust the spacing if the plugs are off?
  6. Aug 12, 2016 at 8:04 PM
    #86
    QMEDJoe
    QMEDJoe Proverbs 3:5-6
    Joe
    Columbus Grove, Ohio
    2003 Tacoma, V6, 5 speed, 4x4.
    Fox 2.0 Coilovers in the front and Fox 2.0’s in the rear, Total Chaos UCA’s, Al-lpro expo leafs, K&N cold air intake, TRD headers,Magnaflow catback exhaust,URD short throw shifter, switched out my 60/40 bench seat for some Tacoma Limited seats, Replaced the vinyl shift boot for a leather one, completely soundproofed the cab w/ Frost King. Replaced stock radio with a Pioneer AVH series head unit. Focal component system w/a 10" sub powered by 2 Alpine amps. Weathertech floor mats. Line-X'd the bed. SCS Ray 10’s, Installed an A.R.E. MX series camper shell. All-Pro Apex front bumper w/ All-Pro skid plates all the way back to the Trans. Low Range fuel skid plate.
    Its about time for me to do mine again.( A little bit past 30k miles) I never checked my gaps on my Denso's and never had an issue. I'm going to be gapping them this time. I'll be sure to post if I notice any difference.
  7. Aug 12, 2016 at 8:34 PM
    #87
    bayareayota
    Bay Area
    Prinsu 32" K02 OME
    How does one gap?
  8. Aug 12, 2016 at 9:22 PM
    #88
    islanti
    islanti Well-Known Member
    1998 Tacoma SR5 V6 4x4
    I dont remember the last time i had to gap spark plugs. I recently replaced the wires and plugs. If they have a cap they will already be gapped. Toyota techs do not check gapping. They put them right in. I did the same and everything is fine.
    Torque them to 15 ft lbs (180 inch lbs)
  9. Aug 13, 2016 at 9:06 PM
    #89
    QMEDJoe
    Joe
    I never have actually gapped a spark plug but I would say buy a spark plug gauge at any local auto parts store (Usually at the register) check the gap with the gauge and ever so carefully bend the spark pug electrode with a pair of needle nose pliers?...I'm sure there are a 1000 & 1 video's on Youtube on how to do so.
  10. Aug 14, 2016 at 9:27 AM
    #90
    ThunderOne
    ThunderOne Well-Known Member
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    Not true. I got my plugs from the dealer (with caps), many were out of spec. Some by .01 or more
  11. Aug 16, 2016 at 2:11 PM
    #91
    chad L
    chad L Member
    2008 tacoma base
    All original
    Does anyone have a recommendation on what brand of spark plugs to buy or is everyone sticking with OEM? 2 prong , 4 prong?
  12. Aug 17, 2016 at 7:07 AM
    #92
    carofchoice
    carofchoice Well-Known Member
    Jeff
    Newton, IL
    2003 DC 4X4 TRD, 2012 X-Runner
  13. Aug 17, 2016 at 1:53 PM
    #93
    ThunderOne
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    OEM, dual electrode (or, "2 prong")
  14. Oct 6, 2016 at 8:47 AM
    #94
    acorn27
    acorn27 Well-Known Member
    2021 MGM TRD DCSB Sport
    I had been having a weird misfire for a while. It didn't happen all the time, couldn't quite determine any consistent conditions that caused it (hot/cold, under load/idle, little or a lot of throttle, etc). Sometimes it was really bad. I tried some FI cleaner just because it was easy to try. Problem still persisted so I suspected the spark. I did some searching and found this great write up. Thanks to the OP, it was extremely helpful.
    Some observations and comments:
    - I ordered the NGK plug wires (#4412, TE66) and Denso OEM plugs (90919-01192). The plugs all had correct gaps out of the box.
    - When removing one of the old plugs, it was giving a LOT of resistance. I was worried the threads were galled but it came out OK. I was actually quite surprised how easy and accessible everything was on this truck. A pleasant surprise for sure.
    - The OEM plugs that I removed, three were NGK and three were DENSO (?) All were the dual-prong type. You could tell they were pretty worn after 135,000 miles. I'll need to check the gaps on those just out of curiousity. Not sure why they were two different brands, I know they were never changed before as I had this truck since 16,000 miles.
    - Everything went back together just fine, make sure to route the wires correctly using the clips so they aren't touching each other or anything else.
    - Change the M10 wrench to an M10 socket. Much easier.
    - After torquing the new plugs, it can be tricky to get the plug socket off the plug rather than having the extensions come out of the socket, leaving the socket down in the hole. I shot a little WD-40 into the socket first to make it slip off the plug easier. And also SLOWLY pull the socket & extensions off the plug.
    Ultimately my problem turned out to be a cracked connector in one of the boots on the driver's side. I didn't notice it when I pulled the boot off, but when I tried to get the socket on the plug to remove it, the socket wouldn't seat. Looking in the hole I noticed the connector and part of the wire in there still on the plug. I managed to get a needle-nose pliers on it and pull it off. Obviously if that was cracked or even separated before, that would be the source of my intermittent misfire.
    I've driven about 25 miles now after the repairs and it seems good. The seat-of-the-pants dyno seems to indicate a little better and smoother power : )
    Thanks again for this helpful write up!
  15. Oct 7, 2016 at 3:58 PM
    #95
    OneWheelPeel
    OneWheelPeel Well-Known Member
    Phoenix, AZ
  16. Oct 11, 2016 at 2:22 PM
    #96
    andrew8404
    andrew8404 Well-Known Member
    ANDREW
    Albuquerque, NM
    17 DCSB TRD OR 4x4 (Sold) 19 Ford Ranger Sport XLT 4x4
  17. Oct 11, 2016 at 2:43 PM
    #97
    99SuperTaco4x4
    99SuperTaco4x4 Well-Known Member
    1999 3.4L V6 Tacoma, 4x4, TRD Supercharger
  18. Jan 22, 2017 at 3:24 PM
    #98
    x2468
    x2468 Well-Known Member
    '02 TRD 4wd V6 Xcab Sr5
  19. Jan 23, 2017 at 8:57 AM
    #99
    skeezix
    skeezix Ol' Geezer
    Colorado
    1998 Limited
    It's been awhile, but IIRC the coil attaches directly to the passenger-side plugs, and the 3 wires run from the coils to the driver-side plugs. Unlike 'way back in the olden days, the plugs fire at every revolution, not every other revolution.
  20. Mar 12, 2017 at 11:08 PM
    #100
    lpt0n
    lpt0n Member
    Eastern Washington
    --00 Tacoma Sr5
    nothing at all
    Who gaps their dual electrode plugs before install? There seems to be a lack of internet content showing this, or how to do this...
    labrador01 likes this.
