How to reset and calibrate your VSC computer - The Easy way
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Crom, Dec 30, 2016.
  1. Feb 15, 2017 at 8:32 PM
    #41
    BlakeT
    BlakeT New Member
    Oregon
    2011 Access cab 4X4 4.0L manual SR5
    Update: Took it to the dealership, caught a code from the steering angle sensor. They reset the system (for free) and have had no problems since. Slip indicator still works in appropriate conditions. No need to short it this time, but thanks for the write up
    Crom[OP] likes this.
  2. Feb 16, 2017 at 7:34 AM
    #42
    BYBO
    BYBO Well-Known Member
    Byron
    Indiana
    Just did this. Worked just as advertised. Another great write up!! Thanks again!!!
  3. Feb 24, 2017 at 8:15 AM
    #43
    Large
    Large Red
    Omg this light was driving my ape shit. Thanks for this post @Crom
  4. Feb 24, 2017 at 8:19 AM
    #44
    Crom
    Crom [OP] Super-Deluxe Member
    Nick
    San Diego, CA
    2009 4x4 DCSB Camp Supreme
    Millions
    welcome!
  5. Mar 5, 2017 at 2:31 AM
    #45
    romafern
    romafern Hug diz nuts
    Rob
    80918 Let's meet!
    Paid for and saving a shit ton of $$$$$
    Thinking of adding a second battery...
    Thanks for the info
  6. Mar 6, 2017 at 3:43 PM
    #46
    slwburn
    slwburn Well-Known Member
    Winter haven Fl
    12 tacoma dclb 4x4
    Just tried this before my scheduled appointment to the Toyota dealership tomorrow for a vcs recalibration. Worked perfectly on my 2012 4x4. Thanks for saving me $270 @Crom
    Norton likes this.
  7. Mar 6, 2017 at 3:46 PM
    #47
    IPNPULZ
    IPNPULZ Well-Known Member
    Deeper in the South…….
    2023 TRD Off Road Premium 4R
    going to be fun!
    Sub'd
  8. Mar 7, 2017 at 6:19 AM
    #48
    weimar
    weimar Member
    The Pacific Northwest
    2020 Tacoma Cement LB 4x4
    I live in the beautiful pacific northwest which is full of roads with up and down tight corners. After lifting and adding tires (3" and 285s) my vsc would kick in on any corner above 35 mph. I adjusted my driving style braking hard going into turns I expected the vsc to hit on and all was fine. Until one day heading east of the mountains taking a turn on the mountain pass doing approx 70mph (which is the speed limit) and my vsc kicked in and pulled me into the next lane narrowly missing a semi.
    So the next week I brought it to the dealer on advice from the forum with the printout. Picked it up and tested it out on my normal commute and hit vsc 3 times again, frustrating. Came across this method and gave it a try, worked exactly the way it was supposed to. So again set out to test it on my normal commute and vsc hit again on same 3 corners. I'm at a loss and have no idea what to do differently. I don't mind braking into corners but one of these days either myself or the wife is going to get caught off gaurd by one of these "safety" features. Any suggestions, please and thank you.
  9. Mar 7, 2017 at 6:36 AM
    #49
    Ridgeline001
    Ridgeline001 Well-Known Member
    Oregon
    2014 DCLB Sport 4wd
    I now shut mine off when I drive over the pass or local mountain roads. https://www.tacomaworld.com/threads/abs-kill-switch-mod-for-05-offroad-easy-way-pics.170927/
  10. Mar 7, 2017 at 6:21 PM
    #50
    weimar
    weimar Member
    Ridgeline001[QUOTED] likes this.
  11. Mar 8, 2017 at 6:31 AM
    #51
    MadMedic35
    MadMedic35 Well-Known Member
    Sandhills, NC
    09 TRD SPORT DCSB
    Fox 2.5 coilover, TC UCA, FOX 2.5 res rear shock, OME leaf pack, SCS Ray-10 gold, Nitto Ridge Grappler, SoftTopper. On order: Relentless Fab Summit Bumper, HC rear bumper with tire carrier, sPOD, Powertray,
    Awesome sticky. Steering wheel was off center to the left in my '09 for a few months since an alignment. I adjusted the tie rods to get the wheel straight and the VSC light came on and stayed on over 25mph. Did the VSC reset as described and problem solved. Thanks
  12. Mar 9, 2017 at 12:51 PM
    #52
    EDDO
    EDDO                         
    Eric
    San Jose, CA
    19 TUNDRA
    Thanks @Crom for posting this concise set of directions.
    Seeing as this is the third time I've come home from a trip to the desert with my alignment messed up sufficiently to turn the light on, I took the suggestion of a couple of people who posted and made a thing out of spare junk and a paperclip.
    z00mer, idahodesert, Travlr and 2 others like this.
  13. Mar 10, 2017 at 9:16 PM
    #53
    Dvst8r1K
    Dvst8r1K Night-Taco
    Greg
    2nd gen Black Tacoma SS 4.0l 4-dr 4x4
    1" Toytec body-lift, K&N filter, coolant by-pass, mesh cotton screen delete, TTBS, WeatherTech in channel visors, 2.5" Rancho full suspension kit, Oil Catch Can, Toyo 285/70 A/T-2's, 21.5" light bar in grill, blacked-out grill, de-badged entire truck; and again, more to come.....
    This may be a silly question, but I'd rather ask, and get it right, than not ask and mess things up...
    When using the SPST switch, are all three prongs on back of the switch (lighted switch) used, or do I just wire the pos and neg prongs of the switch to have this work properly??? Thanks in advance...
  14. Mar 10, 2017 at 9:56 PM
    #54
    EDDO
    EDDO                         
    Eric
    San Jose, CA
    19 TUNDRA
    Just ignore the third (negative) prong. Good idea to meter the switch to make sure you get the correct two.
  15. Mar 10, 2017 at 10:02 PM
    #55
    Dvst8r1K
    Dvst8r1K Night-Taco
    Greg
    So I'll be using the pos and acc posts only, does that sound correct??
    Eddo, Thanks for the info at this hour. Really appreciate it.... I may have to do a reset...
    EDDO likes this.
  16. Mar 10, 2017 at 10:08 PM
    #56
    EDDO
    EDDO                         
    Eric
    San Jose, CA
    19 TUNDRA
    Yep, skip the negative. It is only there to illuminate the switch. :thumbsup:
  17. Mar 10, 2017 at 10:10 PM
    #57
    Dvst8r1K
    Dvst8r1K Night-Taco
    Greg
    Thanks again EDDO, and thanks to all others who have posted...
    EDDO likes this.
  18. Mar 12, 2017 at 12:24 AM
    #58
    ODNAREM
    Ron
    Huntington Beach,CA.
    2012 TRD Sport Prerunner
  19. Mar 12, 2017 at 5:11 PM
    #59
    skkzhg
    skkzhg Well-Known Member
    Stephen
    North Georgia
    Is this necessary if you go to a +1 tire size?
  20. Mar 12, 2017 at 5:15 PM
    #60
    OZ-T
    OZ-T You are going backwards
    Peter North
    British Columbia
    My issues started then , yes it's possible
    Drainbung likes this.
