How to: Retrofit Morimoto FX-R & Mini H1- in depth
Discussion in 'Lighting' started by InSight Retrofits, Nov 21, 2013.
  1. Jul 9, 2020 at 4:30 PM
    #541
    1997tacomav6
    Denver
    Make sure before its all sealed up that you adjusted rhe horizontal alignment
  2. Jul 17, 2020 at 10:53 AM
    #542
    vind
    vind New Member
    Vinh
    Milpitas, CA
    Thank you, I actually marked the spot before removing the headlight to get close to where it were, I made little adjustment to get it should be while I drive around at night. I have a hot spot on passenger side that I haven't got time to address, it's probably due to the bulb itself or needed to reseat the bulb.
