How To: Secondary Stand Alone Fuse Block Install
Discussion in '2nd Gen. Tacomas (2005-2015)' started by H2Otx, Oct 27, 2010.
  1. Nov 15, 2015 at 9:35 PM
    #201
    Someone
    Someone Well-Known Member
    2015 TRD Sport DCLB
    Here is what I did. Instead of on all the time it will run through a relay. Still not done yet. I ordered a tap-a-fuse to tap in to a fuse that will power on when truck is on. I'll be installing a light bar after this to treat my set up. 20151112_091207.jpg
    I'll let you know how it goes once I'm done.
  2. Dec 18, 2015 at 4:31 PM
    #202
    PNW/TRD Steve
    PNW/TRD Steve Well-Known Member
    WA
    2012 DCSB TRD
    ImMrYo Rear view mirror lift bracket. Changed out mud flaps. Salex glove box organizer. OEM Ashtray (cup). AVS Step Shields. 16x8 SCS F5 Matte Jet Black. 265/75 16 Cooper St Maxx. OME Bp-51s. U.S. Offroad Winch Mount (in process) Smittybuilt x20 12k synthetic winch (in process) More....
    Hey Someone, where did you locate you add a fuse. I just installed something similar but have yet to power the relay for ignition on.
  3. Dec 19, 2015 at 11:14 PM
    #203
    Someone
    2015 TRD Sport DCLB
  4. Dec 19, 2015 at 11:47 PM
    #204
    rogs6266
    rogs6266 Well-Known Member
    Alliance, OHIO
    '13 TRD Sport 4X4 DCLB MGM
    SOS weld on sliders, SOS bed rack, SOS front aluminum winch bumper with center and head light hoops, Stealth 6 wheels wrapped in goodyear duratracs, 285-70/17 Beer opener in bed, Thule roof rack on factory rack, Tool box, bed mat, K&N cai, flowmaster side out duals, and tailgate extender, Fog light anytime mod, no mud flaps mod Weathertech full set, Wet okoles front and rears, full OME 886 suspension lift with Dakars in rear, smittybilt X20 comp 10 winch, factor 55 yellow pro link,
  5. Dec 20, 2015 at 7:27 AM
    #205
    PNW/TRD Steve
    WA
    2012 DCSB TRD
  6. Dec 20, 2015 at 3:19 PM
    #206
    Someone
    2015 TRD Sport DCLB
    I'd like to see how yours looks.
  7. Dec 20, 2015 at 4:10 PM
    #207
    PNW/TRD Steve
    WA
    2012 DCSB TRD
  8. Dec 20, 2015 at 5:13 PM
    #208
    Someone
    2015 TRD Sport DCLB
    Nice one. Where did you get your plate? I bought a metal plate from home depot and made it my self. Yours looks more solid.
  9. Dec 20, 2015 at 8:10 PM
    #209
    PNW/TRD Steve
    WA
    2012 DCSB TRD
  10. Dec 20, 2015 at 8:30 PM
    #210
    Timbo's Customs
    Timbo's Customs Well-Known Member
    Timothy
    Lakeland FL
    2019 f250 6”lift 37s deleted 1997 T4r, tons and 4ds
    1997 t4r has super duty axles, 5.13s locked front and rear. 3 link front with 14" kings. Rear 63s.
    4 relays and 6 fuses. All custom wired and custom bracket.
    0210 and Biscuits like this.
  11. Dec 20, 2015 at 8:34 PM
    #211
    PNW/TRD Steve
    WA
    2012 DCSB TRD
    Nice. What is the fuse block?
  12. Dec 20, 2015 at 8:35 PM
    #212
    Timbo's Customs
    Timothy
    Lakeland FL
    Thanks 02 Crown Victoria fuse box
  13. Dec 20, 2015 at 10:47 PM
    #213
    PNW/TRD Steve
    WA
    2012 DCSB TRD
    No ACC fuse under the hood on mine. I will just have to run it into the cab. For now its on the A/C 10amp which requires the fan switch to be on. Not a big deal right now as I almost always have the fan on.
    If I were to start fresh, I would use two 6 position fuse blocks with one always on and the other switched.
  14. Dec 21, 2015 at 6:22 AM
    #214
    ThatguyJZ
    ThatguyJZ Instagram: thatguyjz
    Jim
    TRIAD, NC
    2014 MGM DCSB 4x4 TRD Off Road
    A TRD OR built into a Baja/PRO hybrid
    OP, well done on the bracket and mounting location. I be using this thread in the future as I incorporate more accessories!
  15. Dec 21, 2015 at 7:18 AM
    #215
    Jumpingonfurniture
    Jumpingonfurniture Member
    Oklahoma
    2009 Silver Tacoma SR5 4x4
  16. Dec 21, 2015 at 9:06 AM
    #216
    Someone
    2015 TRD Sport DCLB
    Probably should have mentioned that acc fuse is in the cab not under the hood.
  17. Feb 26, 2016 at 7:26 PM
    #217
    AZDesertTRD
    AZDesertTRD Well-Known Member
    Pamela
    Arizona
    2012 PreRunner Sport
    Well done!
  18. Mar 1, 2016 at 6:06 AM
    #218
    ETXTacoma
    ETXTacoma Someone gave me a plasma cutter.
    Steven
    Tyler, Texas
    2014 DCSB Tacoma TRD OR
    This is a great how-to and I learned a lot doing this install.
    Going to have to switch the Positive Cables in the future as they are currently AWG 6 and not AWG 4, I could not find any Red AWG 4 locally so had to go with the AWG 6 for the time being, once I get more stuff running, then I will switch to AWG 4 for the positive.
    Biscuits, Toynado and Captain Taco like this.
  19. Mar 3, 2016 at 10:09 PM
    #219
    Captain Taco
    Captain Taco RipCity
    Rob
    Portland
    2013 Black Tacoma Sport
    3" Lift, Krank Fuel Wheels, TRD Pro Grill, Curved Roof LED Light Bar
    Does the blue sea fuse box bring a spot for the positive and negative end of the wire? I can see your two red wires going into the fuses but don't see any negative wires
  20. Mar 4, 2016 at 5:26 AM
    #220
    Scott B.
    Scott B. Well-Known Member
    Scott
    Georgia
    2015 ACLB SR5 4x4 Expo
    The connection towards the top of the picture is the negative bus (under the yellow tab on the cover.)
    Blue Sea makes fuse blocks both with and without a negative bus, depending on your needs.
    Captain Taco[QUOTED] likes this.
