How To: Secondary Stand Alone Fuse Block Install
Discussion in '2nd Gen. Tacomas (2005-2015)' started by H2Otx, Oct 27, 2010.
  1. Apr 17, 2014 at 5:59 PM
    #81
    MTopp
    MTopp Professional bear handler
    05 SR5 4x4
    trifecta tonneau, pop n' lock, Depo black bezel headlights, mb 352 wheels, 265/75r16 cooper at3s, visors, colormatched 2011 grille with raptor LEDs, much LEDs in and out Future/wanted: black valence, hood scoop, catback, CAI, 285/75r16s, OMD leaf pack mod
    Do you all think 1/4" lexan is good or 1/2"? Or other, 3/8"? I have to order it online probably, no one around me stocks it
  2. Apr 17, 2014 at 7:18 PM
    #82
    MTopp
    05 SR5 4x4
    Alright, thanks!
  3. Apr 26, 2014 at 5:55 AM
    #83
    MTopp
    05 SR5 4x4
    Should negative from block go to battery terminal or frame? I've read different things
  4. Apr 26, 2014 at 9:17 AM
    #84
    crooks420
    crooks420 Well-Known Member
    Jesse
    San Gabriel
    05 AC Prerunner SR5, 12 DC LB 4x4, 70 FJ40
    Both would be best.
    Jesse
  5. Apr 26, 2014 at 7:06 PM
    #85
    MTopp
    05 SR5 4x4
    I understand, but don't know what'd you use for such large wire
  6. Apr 26, 2014 at 8:02 PM
    #86
    Thelgord
    Thelgord The Pantagonist
    Augusta, GA
    '13 TRD (OffRoad, 4x4)
    SOS Rocksliders, All Pro skid plate, Procomp add-a-leaf, Bilstein 5100 @ 1.75", CB, high-lift jack
    You can go either way. The negative cable (from the battery) goes to the frame, so the frame is a good ground, and is used as such all over the vehicle. You can also go strait to the battery terminal itself. It really doesn't matter.
    Edit: Clarification
  7. Apr 27, 2014 at 4:47 AM
    #87
    MTopp
    05 SR5 4x4
    Alright, thanks, frame it is
  8. Apr 27, 2014 at 9:14 AM
    #88
    Thelgord
    Augusta, GA
    I have never worked with Lexan before, what is the best way to "bend" it to shape? Clamp and a heat gun?
  9. Apr 27, 2014 at 9:47 AM
    #89
    H2Otx
    H2Otx [OP] The Tinkerer
    Austin
    Houston, Texas
    10 DC 4x2 SR5 TRD Off-Road
    SilverStar Ultra Headlights; Nokya Ion Yellow Fogs; SuperBright LED Bulbs; 8" Shorty Antenna; WeatherTech Mats / Bug Shield / Vent Visors; TRD CAI with aFe Pro Dry S Filter; aFe Pre-Filter; Custom CAI Cover and Fuse Box Cover; TRD AT Shift Knob (Japan); TRD Oil Filler Cap (Japan); n-Fab Step Rails; Monster Hook
    Clamps, wood, vise, heat gun... Your intentions are to heat the area you are trying to bend, NOT the entire piece. There are many ways to achieve the same result, however if you heat the entire piece to could end up warping or doing something you didn't intend.
  10. Apr 27, 2014 at 9:49 AM
    #90
    Thelgord
    Augusta, GA
    Thanks for the video, doesn't seem to be all that complicated. Just need the right tools.
  11. Apr 27, 2014 at 1:54 PM
    #91
    MTopp
    05 SR5 4x4
    How's it look wire wise?
  12. May 4, 2014 at 6:08 PM
    #92
    MTopp
    05 SR5 4x4
    Boomp for opinions
  13. May 4, 2014 at 6:57 PM
    #93
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    Looks fine
  14. May 4, 2014 at 7:00 PM
    #94
    crooks420
    Jesse
    San Gabriel
    Looks ok, for one accessory wired up...... :yes:
  15. May 23, 2014 at 9:29 AM
    #95
    RDtres
    RDtres Well-Known Member
    Albuquerque
    2012 Tacoma DC LB
    I finally got around to doing this mod, thank you to everyone for ideas and suggestions. After considering what I wanted and had to work with I chose lexan as my base tray, a Blue Sea 6 slot fuse block, a 100A circuit breaker from Autozone and went to work. The hardest time I had was deciding on shape and design. I made sure to leave room for my PIAA relays and a 100A fuse for later when I install my audio system. Anyhow. here it is. I'm open to questions or positive comments. Thanks again OP
  16. May 23, 2014 at 10:02 AM
    #96
    crooks420
    Jesse
    San Gabriel
    Looks good.
  17. May 23, 2014 at 4:47 PM
    #97
    MTopp
    05 SR5 4x4
    Lol, there's more now, that was just right after the install
  18. May 24, 2014 at 12:30 AM
    #98
    ProForce
    ProForce IG @proforce.expeditions OB#5411
    Anthony
    Alaska
    09 MGM TRD Sport DCSB 4.0 Auto 2wd
    Too many to list. See build page. Link in signature
    Put some conduit (split loom) on that battery cable. Trust me it makes a difference and its super cheap. $3 bucks is a good insurance policy for that setup
    Here is mine:
    GonzoQuick likes this.
  19. May 25, 2014 at 11:53 AM
    #99
    Jtcmedic
    Jtcmedic Shop beekeeper
    Jeff
    Florida
    2014 prerunner sr5
    Bed led, under hood led, secondary auxiliary panel,
    Sub parts on order
  20. May 26, 2014 at 9:43 AM
    #100
    RDtres
    Albuquerque
    2012 Tacoma DC LB
    Copy the suggestion, i bought a few rolls of conduit and will be including that today after i add some under carrage lights. Thank you
