how to separate brake disc from hub
Discussion in '4 Cylinder' started by bikercat, Nov 17, 2009.
  1. Nov 17, 2009 at 4:24 PM
    bikercat
    bikercat [OP] Member
    hello everyone, I'm in the process of changing my front rotors on my 1999 2 wheel dr. tacoma. the disc and hub are stuck together even tho I had taken off the bolts that hold the disc to the hub. how do I separate the two? thanks:)
  2. Nov 17, 2009 at 4:28 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    welcome to tw.
    the two are probably rusted together, so you may need to spray a lil pb blaster or wd-40 around the hub and let it sit for a bit. try a rubber mallet frst tho...may pop loose.
  3. Nov 17, 2009 at 4:41 PM
    Stupid hurts.
    Stupid hurts. Hoogie boogie!
    Steven
    So☆Cal
    '07 5-Lug Impluse Red Pearl Access Cab 2WD
    American Motorsports Front Long Travel Kit, Total Chaos Rear Dual Shock Hoop Kit, Engage 50T Leaf Pack, Engage Front & Rear Hangers, American Motorsports Shackles
    x2
    Some WD-40 and a rubber mallet will help A LOT! My buddy and I changed his front rotors and pads on his '04 Tacoma and getting the front rotors off was the only step that took such a long time. Good luck! :thumbsup:
  4. Nov 18, 2009 at 5:30 AM
    bikercat
    thanks everyone for responding. will give it another go. yesterday sprayed some pb blaster on it and banged it with a hammer, still wouldn't loosen up. If I can't separate the two, does that mean that I'll have to purchase a new hub?
  5. Nov 18, 2009 at 5:42 AM
    98tacoma27
    98tacoma27 is going full "Ben" Moderator
    Ben
    Beech Creek
    05 Tundra SR5 (+265k AND COUNTING), 88 SR5 PU (SOLD), 98 TRD OR (CRUSHED)
    5100's all on fours
    No, they will seperate. Try this method: place a heavy metal object close the where the hub and the rotor meet. Then hit that metal object with a large hammer. I find this works better than just a hammer strike. Also as stated above, you can never use too much PB.
  6. Nov 18, 2009 at 6:49 AM
    bikercat
    thanks again, is there some sort of retaining ring in the hub that needs to be removed?
  7. Nov 18, 2009 at 6:53 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    Nope.
  8. Nov 18, 2009 at 6:56 AM
    rutherk1
    rutherk1 ElPhantasmo&TheChickenRunBlastarama
    09 Silver TRD 4door
    I always do a rubber hammer on both sides of it. You have to hit pretty hard but it will come off. Lots of PB.
  9. Nov 18, 2009 at 7:14 AM
    bikercat
    thanks again for responding so quick. will let you know how I fare.
  10. Nov 18, 2009 at 7:19 AM
    rutherk1
    09 Silver TRD 4door
    Good luck. If all else fails call Chuck Norris.
  11. Nov 18, 2009 at 7:21 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    that may be a bit extreme...Last time Chuck kicked a truck, it fell entirely into peices.
  12. Nov 18, 2009 at 7:21 AM
    98tacoma27
    Ben
    Beech Creek
    5100's all on fours
    But the rotor would be off. :eek:
  13. Nov 18, 2009 at 7:23 AM
    rutherk1
    09 Silver TRD 4door
    Yeah. Good point. Once Chuck Norris kicked a brake rotor trying to remove it and the entire truck was launched all the way around the world and landed on his home town destroying everything in sight. Every year on the anniversary of the destruction he remembers it happening and his laugh can be heard for a 1000 mile radius
  14. Nov 18, 2009 at 7:49 AM
    jyffmguy
    jyffmguy Taco Boosh!
    Jeff
    Midlothian, IL
    '10 DC SB OR
    Those with more mechanical knowledge then me(which is just about everyone), stop me if I'm wrong - but while working on my friend's front discs, we ran into this problem. A few minutes worth of heating with a propane torch and a few whacks with a mallet loosened it right up.
  15. Nov 18, 2009 at 8:15 AM
    mjp2
    Milton Juevos Portimous II
    NJ
    '06 TRD Access Cab, v6, 6-speed
    Scaffolding and a painted grill
    Chuck Norris once kicked my truck. :(
  16. Nov 18, 2009 at 8:16 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    :eek: Is that why it was on jack stands for so long? :eek:
  17. Nov 18, 2009 at 8:20 AM
    mjp2
    NJ
    I'm just happy he hasn't come back to kick my jackstands!
  18. Nov 18, 2009 at 8:23 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Actually, I heard that if he kicks the brake rotor....all Tacomas die. :eek:
  19. Nov 18, 2009 at 8:48 AM
    otter
    otter Well-Known Member
    Rob
    MI
    09 4 cyl Reg Cab
    Use a propane or MAPP gas torch to heat the rotor up near the hub. The heat will cause the metal to expand/distort a bit, which will break the rust.
  20. Nov 18, 2009 at 2:51 PM
    bikercat
    thanks everyone for your suggestions. copious amounts of PB blaster, time and wacks with a chisel and hammer finally did the trick. "whew" I'll do the other side tomorrow. are the rear brakes easier?
