how to separate brake disc from hub
Discussion in '4 Cylinder' started by bikercat, Nov 17, 2009.
  1. Nov 19, 2009 at 8:05 AM
    SUPMO72
    SUPMO72 Well-Known Member
    Cleveland Ohio
    09 MGM Reg 4x4 5spd
    OEM Fog Lights, Tailgate Lock, Color matched OEM Grill, GT seat covers, Undercover bed cover, OEM back up camera
    Take a 7/8 cold chisel and put it in between the rotor and the back of the stud and hit the chisel with a hammer. Rotate all the around the rotor till it pops loose.
  2. Nov 19, 2009 at 10:24 AM
    bikercat
    bikercat [OP] Member
    just saw your email today. past couple of days I used pb blast and a large chisel and actually did what I read in your post, took a couple of hours but I was finally able to separate the rotor from the hub. thanks anyway. see that you ride a c14 concours. I ride a 2005 connie. wanted the newer version, unfortunately I'm already vertically challenged on mine. thanks again for replying.
  3. Nov 19, 2009 at 10:29 AM
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    Is there not a hole in the rotor to screw in a bolt that will push the rotor away from the hub? or is that concept too old school?
  4. Nov 19, 2009 at 1:56 PM
    bikercat
  5. Dec 10, 2009 at 4:29 PM
    DeltaHotel
    DeltaHotel Member
    I ran into this same issue with my 2002 taco recently. I tried lots of PB, lots of beating, and tugged and pulled for a good long while. It was as if it was welded to the hub!
    Finally, I took a small bottle jack and wedged it between the rotor and a steel pry bar I wedged against the frame. That worked perfectly.
  6. Dec 16, 2009 at 1:38 PM
    Death_Stalker
    Death_Stalker " The Master Ninja"
    Talha
    Cypress, TX
    2018 4Runner LE
    TRD Pro Wheels BFG AT Tires
    i tried changing the rear hub assembly but i had no luck seperating the hub from the drum breaks my 05 prerunner ... i wonder if there is a write up on that ......
