How To: Spark Plug Change (1 GR-FE)
Discussion in 'Technical Chat' started by chris4x4, Mar 16, 2009.
  1. Dec 15, 2009 at 4:27 AM
    #201
    jester156
    jester156 Well-Known Member
    Cumberland, RI
    2021 GMC Sierra AT4. 3.0l Duramax
    changed my plugs yesterday, took about an hour, I had a CAI installed so there was less to move on the passenger side. I actually had to do 7 plugs since my socket got stuck on one of the plugs so I had to uninstall it. I even had tapped it to the extension... Great write up.
  2. Dec 24, 2009 at 9:27 PM
    #202
    Rowdy K
    Rowdy K New Member
    Rowdy
    Tx
    06 PreRunner SR5 Sport debadged
    6in fabtech lift Volant cold air intake RPB Nerf Bars Scan gauge II Skid plate More to come
    Awesome write up! Thanks will be changing my plugs soon.
  3. Dec 26, 2009 at 12:37 PM
    #203
    hoosiertaco
    hoosiertaco Well-Known Member
    As always, excellent work Chris! Everything I needed to know plus all the info I need to give my tech a pop quiz after he finishes the work for me.:D I Wish I had the time to do it myself.:eek:
  4. Jan 13, 2010 at 1:10 PM
    #204
    jgolden
    jgolden Member
    06 Access Cab TRD Sport 6 Speed
    TRD Exhaust
    Thanks alot for your post. Changed my plugs today and saved some $$$.
    Very helpful.
  5. Jan 13, 2010 at 3:52 PM
    #205
    BakoTruck
    BakoTruck Well-Known Member
    Matthew
    Bakersfield, CA
    05 PreRunner TRD
    I have a quick question, I'm not sure if it has been answered yet since I don't have time to read every post.
    I noticed the box of spark plugs on the write up had a quantity of 10. Do they sell them one at a time out of that box, or only at a quantity of 10? I don't fell like paying extra to buy spark plugs I don't need. Granted I could buy another box for next time and I'll be set for two more changes, but that is bull cr@p. I'll still end up with extra spark plugs.
  6. Jan 13, 2010 at 3:55 PM
    #206
    BakoTruck
    Matthew
    Bakersfield, CA
    05 PreRunner TRD
    Cool, thanks wolfpack! :thumbsup:
  7. Jan 16, 2010 at 8:06 AM
    #207
    linkfeeney
    linkfeeney Well-Known Member
    link the stink!
    Sewell, NJ Eh!
    09 Doublecab TRD Off-Road! Magnetic Grey!
    did u guys use the torque wrench to do the 15lb thing? or just go by how it feels?
  8. Jan 16, 2010 at 9:42 AM
    #208
    chris4x4
    chris4x4 [OP] With sufficient thrust, pigs fly just fine. Moderator
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Use a Torque wrench.
  9. Jan 16, 2010 at 10:02 AM
    #209
    Toyota Truck
    Toyota Truck Well-Known Member
    JT
    Texas
    2008 Prerunnner
    Magnaflow Muffler-TSB springs-Nuvi 265wt-aFe pro dry s filter-Husky Liners-Blue dome light-extra d-rings-OME 90000 sport struts-885 coils-N182 shocks-TSB AAL-LR UCAs-procomp black alloy rims- nitto terra grapplers-20% tint
    What happens when you don't gap your plugs right? and don't use the anti sieze
  10. Jan 16, 2010 at 10:48 AM
    #210
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    If you dont gap the plugs propperly, the engine may not run propperly. If you dont use Anti Sieze, the plugs may stick in the head.
  11. Jan 18, 2010 at 7:53 AM
    #211
    Hus
    Hus New Member
    Nova Scotia
    07 TRD Off Road
    Chris,
    It’s the first time I changed the plugs on my truck and started with the plug nearest the firewall on the driver side. Because the middle plug was a little easier to access I unplugged that coil first to make sure I was doing it right. Once I got the coil out I found I needed a skinnier socket. To confirm that I went over to the passenger side and removed the coil nearest the rad as it was easier to see. I put it all back together, or so I thought and started the truck up. The check engine light came on and I realized I forgot to plug in the middle coil on the driver side. So I did so but the check engine light is still on. Any idea why now? Everything is back together and the trucks running fine.
  12. Jan 18, 2010 at 8:03 AM
    #212
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    You will need to get the code cleared with an OBD2 reader.
  13. Jan 18, 2010 at 8:04 AM
    #213
    98tacoma27
    Ben
    Not Beech Creek
    Or disconnect the Neg battery cable for a few minutes.
  14. Jan 18, 2010 at 8:06 AM
    #214
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    True. Though I have had a couple of instances in which that didnt work.
  15. Jan 18, 2010 at 12:25 PM
    #215
    george3
    george3 Well-Known Member
    New Jersey
    2008 2.7 Manual Trans Tacoma
    Seat belt beeper, Cabelas (Weathertech) floor liner gray, Covercraft Seat Savers in Taupe, Protecta Heavy Duty Rubber Truck Bed Mat, Pop n Lock PL5200, Pace Edwards Full Metal JackRabbit, Wolverine oil pan heater, Scangauge2, afe pro dry s filter, Remote Underbody 4 Piece LED Light Kit (White) used as Bed light, DIY Washable Cabin Air Filter, PA15-TOY, 4x4 Illuminated Switch, full synthetic, Redline Tuning Hood Support, Smittybilt Nerf Steps black powder-coated
    If U or someone U no has a Scangauge U can clear it with that. A few of the parts stores will let U use their code reader for free hoping U will find a reason to buy a part.
  16. Jan 18, 2010 at 12:33 PM
    #216
    HankB
    HankB Well-Known Member
    Hank
    near Chicago
    06 Preruner TRD Off Road
    bone stock
    On some cars and with some codes, if you start the car enough w/out the problem recurring, the light will clear. It may still be stored, but at least in Illinois, stored codes will not result in a failed test if the CEL is not on. I would suspect that a CEL that results from an engine miss will clear if the miss goes away. it might take 25 start cycles so you might have to wait a couple weeks.
  17. Jan 18, 2010 at 3:53 PM
    #217
    linkfeeney
    link the stink!
    Sewell, NJ Eh!
    go to autozone, they can clear it
    they aren't suppose to, especially when the manager is there
    when I had my 2000 Altima... it was coming alot and so I keep going back to autozone to turn off the engine light, i had like 170k miles on it.
  18. Jan 19, 2010 at 6:07 AM
    #218
    Hus
    Hus New Member
    Nova Scotia
    07 TRD Off Road
    Thanks guys for the info. Looks like the computer picked up the unplugged coil as a fault. Once it was plugged back in I turned the truck on/off a few times and the light went out.
  19. Jan 30, 2010 at 4:22 PM
    #219
    linkfeeney
    link the stink!
    Sewell, NJ Eh!
    I know that the plug needs to gap at .43
    but my plug gapper thingy goes from .40 to .45...
    I guess I should be ok right?
  20. Jan 30, 2010 at 4:28 PM
    #220
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Gap them closer to .040
