How To: Spark Plug Change (1 GR-FE)
Discussion in 'Technical Chat' started by chris4x4, Mar 16, 2009.
  1. Jan 31, 2010 at 9:45 PM
    #221
    r6dink
    r6dink Member
    So on the tools needed list... There were (2) 6" extensions and (1) 3"...
    Di you guys find that you needed that 2nd 6"? I am just asking cause otherwise I am all set but dont have the extra 6" extension, and if I need it... I'd really rather pick it up BEFORE starting. lol
  2. Jan 31, 2010 at 9:52 PM
    #222
    BakoTruck
    BakoTruck Well-Known Member
    Matthew
    Bakersfield, CA
    05 PreRunner TRD
    I'm sure Chris or someone else can answer this better than I can, but I would say yes.
    If you really don't feel like buying it, you can try doing it without it. Just make sure you have another car to get you there.
    But I found that I needed a longer extension for the driver's side of the engine. Because of all that crap in the way, It made it a lot easier. Hope that helps.
  3. Feb 1, 2010 at 8:00 AM
    #223
    chris4x4
    chris4x4 [OP] With sufficient thrust, pigs fly just fine. Moderator
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Correct. The longer extensions give clearance to access all the plugs on the driver side. Makes it a little more easy :)
  4. Feb 1, 2010 at 9:57 AM
    #224
    MattN03
    MattN03 Well-Known Member
    Bluegrass State
    SOLD: 07 DC 4x4 TRD Off-Road
    20% window tint, beep mod, hardwired V1, TSB springs, AVS Bugshield-21803, USA Spec PA15, OEM Tacoma scuff plates, Weathertech mats, Truxedo LoPro, TRD skid, GY Duratrac's 265/75/16 C Range, locker mod (switch method)
    Great writeup and pics!
  5. Feb 1, 2010 at 12:27 PM
    #225
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Thanks. :)
  6. Feb 2, 2010 at 12:14 AM
    #226
    r6dink
    r6dink Member
    I already had the 3" extension and one 6" extension. Instead of gettin another 6" I picked up a 10". Made for alot more different length combinations and also kept me from having 3 extensions linked up at any given time.
    BTW... the electrical tape ont he socket wreck is CLUTCH. I'm doin that from now on!
    Overall I think it took me about 1.5 hours of on-task time.
  7. Feb 4, 2010 at 3:50 PM
    #227
    805TRDTacoma
    805TRDTacoma Member
    Oxnard, Ventura County CA
    06 PreRunner SR5
    This is a GREAT post Chris 4x4..really helped me out. They wanted to charge me $250 to do it at the dealer. I said EFF that! Your posting really helped! :)
  8. Feb 4, 2010 at 3:54 PM
    #228
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Good to hear! Welcome to TW!
  9. Feb 15, 2010 at 5:27 PM
    #229
    aficianado
    aficianado Well-Known Member
    bay area, california
    2006 access cab. 4x4, TRD-OR + 2023 TRD off-road.
    back to bone stock.
    well chris..you are going to be with me(this thread) on another project. picked up 6 plugs today. perused the previous owner's receipts and found no mention of any shop changing the plugs..EGADS! i'm at 43000 miles. thanks to this thread, i checked.
    to late to start tonight. i'll attack it tomorrow afterwork. thanks for laying out all the "gotchas!". i'll report back. oh, same parts counter lady said plugs are pre-gapped. that would be a first.
    cliff
  10. Feb 15, 2010 at 5:30 PM
    #230
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Good to hear!! Let me know if you run into any issues. Check the plugs regardless of what they say ;)
  11. Feb 16, 2010 at 4:33 PM
    #231
    aficianado
    back to bone stock.
    confirmed! stock plugs on my 43k miles truck. i had the NGK/DENSO mix. none looked to bad, gap was huge tho.
    generally PIECE-O-CAKE! took me about an hour, because i didnt really remove anything on the driver's side. i had some swivel sockets, and some long locking extensions. thanks guys. officially, this is the first vehicle i have owned that you can check torque with a torque wrench. nice.
    oh, all new plugs were accurately pre-gapped...who would have thunk it!?
    again, thanks.
  12. Feb 16, 2010 at 6:12 PM
    #232
    linkfeeney
    linkfeeney Well-Known Member
    link the stink!
    Sewell, NJ Eh!
    09 Doublecab TRD Off-Road! Magnetic Grey!
    i got 29995 miles on my truck but can't do my plugs because of WINTER!!!
    what kind of torque wrench are u using?
  13. Feb 16, 2010 at 6:29 PM
    #233
    aficianado
    back to bone stock.
    POS craftsman. pretty accurate, but adjusting readings is very notchy.
  14. Feb 17, 2010 at 3:07 AM
    #234
    linkfeeney
    link the stink!
    Sewell, NJ Eh!
    but you just turn it until its snug right?
    maybe I should just buy the torque and return it... :eek:
  15. Feb 17, 2010 at 7:38 AM
    #235
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    The plugs have a crush washer on them. They need to be seated propperly, for them to seal. Too much torque, and you strip the plug hole, and will need a helicoil, or the head re tapped.
  16. Feb 24, 2010 at 3:43 PM
    #236
    1TUFFTRD
    1TUFFTRD WTF
    out and about building powerlines
    06 AC with a skewp
    06 With a Skewp.
    i gotta do this... awesome write up
  17. Feb 27, 2010 at 4:07 PM
    #237
    BTO
    BTO Well-Known Member
    California
    '07 Silver PR DCSB SR5 V6 AT TP LSD
    Bilstein 5100s front, Adjustable Ranchos rear.
    Just finished replacing my plugs for the first time. I have 56k on my '07 Taco. The old plugs still looked OK. I measured the old ones after I took them out. The Densos seemed to fair better than the NGKs. The gaps on the Densos had burned open to about .046. The Ngks were closer to .050. Also, all of the NGKs had alot of burned whatever on their threads but the Densos did not.
    I replaced with the stock Densos. That's what the dealer sold me. They came gapped at .040. I think I'll leave these in till 120k.
    Kudos to you Chris for this excellent write up that I followed all the way. The only other thing I found that helped me was when taking off the coil wire connectors on the driver side, I found it handy (basically I was having a hell of a time getting those off) to use two flat blade screw drivers. One to push down on the release and one to pry the connector off.
  18. Feb 27, 2010 at 4:23 PM
    #238
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Thats what I used the long needle nose pliers for. :)
  19. Feb 28, 2010 at 3:35 PM
    #239
    plannerbuyer
    plannerbuyer New Member
    Eduardo
    Tecate California
    SR5 TRD
    Chris Thank You very much for this tutorial I was come back for the store knowing that I just save some buck`s
  20. Feb 28, 2010 at 3:40 PM
    #240
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Glad to help. Welcome to TW! :)
