How To: Spark Plug Change (1 GR-FE)
Discussion in 'Technical Chat' started by chris4x4, Mar 16, 2009.
  1. Jun 21, 2010 at 9:04 AM
    #281
    skulltacoma
    skulltacoma Make more better!
    BEN
    Calgary, AB, Canada
    2009 toyota tacoma trd modified
    CAI, dynomax turbo exhaust system,tinted windows medium on the fronts to match the backs, hid kit hi and low beam, pop and lock tailgate, painted calipers red with caliper paint, put 2.25' leveling kit in front and a 1" block in the rear. its now level and rides WAY better (readylift)>way nicer than the revtek my buddy has i think its garbage imo<, hurst "T" shifter, 18 x 10 american racing (can't remember the name) chrome rims with badass 5 inch lip :), 12 inch rockford fosgate punch with rockford fosgate 600 watt amp, bushwacker fender flares (cheaper than replacing the one i wrecked lol) ,kc light bar with kc lights, toyota aluminum stamped skid plate, and a skull front license plate. More mods to come, thinking a 6 inch lift and arb bumper etc etc.
    subscribed thanks.
  2. Jun 21, 2010 at 2:07 PM
    #282
    chris4x4
    chris4x4 [OP] With sufficient thrust, pigs fly just fine. Moderator
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    They get torqued to 7 ft-lbs. If you dont have a wrench to go that low, use a 1/4" drive, and get them snug.
  3. Jun 21, 2010 at 4:19 PM
    #283
    george3
    george3 Well-Known Member
    New Jersey
    2008 2.7 Manual Trans Tacoma
    Seat belt beeper, Cabelas (Weathertech) floor liner gray, Covercraft Seat Savers in Taupe, Protecta Heavy Duty Rubber Truck Bed Mat, Pop n Lock PL5200, Pace Edwards Full Metal JackRabbit, Wolverine oil pan heater, Scangauge2, afe pro dry s filter, Remote Underbody 4 Piece LED Light Kit (White) used as Bed light, DIY Washable Cabin Air Filter, PA15-TOY, 4x4 Illuminated Switch, full synthetic, Redline Tuning Hood Support, Smittybilt Nerf Steps black powder-coated
    Thanks Chris. I like practical by feel rule of thumb info like this ! [​IMG]
  4. Jun 22, 2010 at 10:27 AM
    #284
    randyg123
    randyg123 Well-Known Member
    Randy
    2024 Bronze LTD
    Aye, I did exactly that, just the1/4" drive and a grip up close to the ratchet head to make sure I don't over do it. I'm going to go back with a small torque wrench (I got one in in-lbs that I believe goes below 100) just to make sure. Being under 36k miles I don't want to give Toyota any warranty exclusions for something simple like this should I need to bring it in for something.
    I forgot to add that the three Denso plugs came out gapped right at 40-41, but the three NGKs were more like 44-45. I put in six Densos as recommended above all gapped at 40. Four came that way straight out of the box but two were a bit wider and I had to close them up a bit.
    I hope to get to the fluids this weekend and will start a new thread with some questions on those. Thanks again for the help, Randy:D
  5. Jun 22, 2010 at 10:28 AM
    #285
    raycie
    raycie Well-Known Member
    Oahu, HI
    2013 DCLB / 2016 4R Trail
    In need of $$$
    Success... Followed the tutorial pretty much to the T. The clip drivers-side furthest left was a PIA to get off... Everything else was fairly o.k. I am buying one of those attachments that articulate a little to have an easier time getting off the driver's side. Seems smoother, plus the butt dyno seems to like it a lot.
  6. Jun 23, 2010 at 8:17 PM
    #286
    07TacomaDan45
    07TacomaDan45 Well-Known Member
    Dan
    Ventura County
    07 Prerunner Long Bed Indigo
    Ipod Cable, Painted stock wheels, Prevent Tailgate Theft Mod
    Hey I got a question for ya Chris. I am gonna be doing this in a couple days. This is probably a really dumb question, but should I unplug the battery before I start taking the spark plugs out?
  7. Jun 23, 2010 at 8:31 PM
    #287
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    I dont, and havent had any issues.
  8. Jun 23, 2010 at 10:06 PM
    #288
    07TacomaDan45
    Dan
    Ventura County
    Thanks for the quick response Chris:thumbsup:
    Wish me luck!
  9. Jun 25, 2010 at 6:40 PM
    #289
    hoeflich
    hoeflich Its all mod on the inside
    florida
    96 3.4L 4X4
    Stuff
    Chris, thanks...finished this...I didnt have any problems...pretty damn easy actually! You da man!
  10. Jun 25, 2010 at 7:26 PM
    #290
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Good to hear! :)
  11. Jun 29, 2010 at 1:25 PM
    #291
    Peru
    Peru Well-Known Member
    Jonathan
    Redmond WA
    SR5 -- V6 -- 2005 -- 4X4
    none
    Excellent write-up. This job is very straight forward and anyone with any wrenching skills could do it. What this writeup does is give you the peace of mind that you won't get thrown a curve ball and or make a mistake because you didn't follow a special procedure.
    A solid thanks to 4x4
  12. Jul 13, 2010 at 5:41 PM
    #292
    07TacomaDan45
    Dan
    Ventura County
    Thanks Chris for this awesome write up! I attempted this today and I was successful! Only took me 3 hours and I have never attempted anything like this. Saved me some mulah too. Only $30 for the spark plugs from AutoPartsWarehouse.com and a couple more for the anti-seize. The only thing that was annoying was unplugging the wire harnesses. Other than that it went smoothly. I definitely recommend other people to try this; just follow this handy write up. TW rocks!
  13. Jul 16, 2010 at 4:39 PM
    #293
    MrGrimm
    MrGrimm Mall Crawler
    Dean
    Wisconsin
    2006 Toyota Tacoma 4WD w/TRD Sport Package
    See build page
    Great DIY. 90 min no problems.
  14. Jul 20, 2010 at 1:23 PM
    #294
    rob1
    rob1 Well-Known Member
    Robert
    South Texas
    Indigo Blue DblCab 4X4 Long Bed TRD Sport SR5
    Tail gate mod, locking gas cap, locking spare tire, rear spring tsb,Weathertech Digital fit's
    What a world of difference changing out the spark plugs!! Did this at 35000 miles and before heading out on vacation to Garner State Park here in Texas!! Took me no less then 1 hr & 15min first time next time I'm sure it will be allot easier!! Better throttle response plus smooth & quiet as an Indian under the red light!!:D
    Thanks Chris4x4!!
  15. Jul 23, 2010 at 12:16 AM
    #295
    haynsoljah
    haynsoljah COUNTRY BOY
    Waiohuli, Maui but currently living Oahu
    2006 Indigo Tacoma 4X4 Longbed
    6" Lift, 33" BFG M/T, K&N Cold Air Intake, 50 Series Flowmaster Exhaust, Wet Ass-holeys Seat Covers
    Thanks for the info! :thumbsup:
    I'm gonna subscribe to this for future reference as I am coming to the 30K MI mark.
  16. Jul 26, 2010 at 9:36 AM
    #296
    PRS
    PRS Member
    The "U-11" suffix on the plug model number is the designation for pre-gapped plugs at 1.1mm. I've have yet to find a Desno or NKG that was not spot on. I "think" NKG claims their plugs are also pre-treated with some type of anti-sieze surface treatment, but not sure about that -- my memory seems to fail at times. Do not mess with spark plugs in a hot head -- let cool heads prevail! Very good job of "How to".
    prs
  17. Aug 1, 2010 at 9:42 AM
    #297
    jjew18
    jjew18 the Nightman cometh!
    Alliance Airport
    05 PreRunner SR5
    Added extra awesomeness to its original awesomeness.
    Agreed, I went to Autozone and got their premium Autolites, installed them and something just didn't feel right, took them out, reinstalled them to make sure something wasn't done wrong the first time. Still didn't feel right. Picked up some Denso plugs from Toyota, running like a champ again.
  18. Aug 1, 2010 at 9:45 AM
    #298
    achirdo
    achirdo I Weld!
    Adam
    North DFW
    06 dodge ram 3500 5.9 cummins
    did mine the other day. the hardest part was unclipping the wiring harness' on the divers side. those were a biotch. but 2 1/2 hrs no prob
  19. Aug 1, 2010 at 9:52 AM
    #299
    george3
    New Jersey
    Your profile on the post doesn't say, do you have a 6 or a 4 ? I'd guess a 6. Wonder if it make any difference on the 4, 2.7 ?
  20. Aug 1, 2010 at 12:03 PM
    #300
    jjew18
    Alliance Airport
    05 PreRunner SR5
    6, Don't know if it makes a difference there, don't know enough about plugs to really know any differences othere than just trying them out. Not sure why the Autolites didn't feel right, there was just a big difference when I swapped them out.
