How To: Spark Plug Change (1 GR-FE)
Discussion in 'Technical Chat' started by chris4x4, Mar 16, 2009.
  1. Aug 1, 2010 at 12:08 PM
    #301
    jjew18
    jjew18 the Nightman cometh!
    Alliance Airport
    05 PreRunner SR5
    Added extra awesomeness to its original awesomeness.
    Did you ever find an answer to the oil on the plugs? One of mine had the same thing. The coil even seemed to have a little oil baked on.
  2. Aug 1, 2010 at 12:35 PM
    #302
    george3
    george3 Well-Known Member
    New Jersey
    2008 2.7 Manual Trans Tacoma
    Seat belt beeper, Cabelas (Weathertech) floor liner gray, Covercraft Seat Savers in Taupe, Protecta Heavy Duty Rubber Truck Bed Mat, Pop n Lock PL5200, Pace Edwards Full Metal JackRabbit, Wolverine oil pan heater, Scangauge2, afe pro dry s filter, Remote Underbody 4 Piece LED Light Kit (White) used as Bed light, DIY Washable Cabin Air Filter, PA15-TOY, 4x4 Illuminated Switch, full synthetic, Redline Tuning Hood Support, Smittybilt Nerf Steps black powder-coated
    Thanks. Maybe someone will know why the Autolites didn't work but bottom line now you know to use Denso. Just a thought Chris 4X4 knows just about everything about Taco maintenance, he might know the answer. I'll see.
  3. Aug 1, 2010 at 3:54 PM
    #303
    chris4x4
    chris4x4 [OP] With sufficient thrust, pigs fly just fine. Moderator
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    The ignition is designed to work with plugs of a particular resistance, and temperature range. If the Autolights are out of that range, then you will loose performance.
  4. Aug 1, 2010 at 4:18 PM
    #304
    george3
    New Jersey
    Thanks Chris ! Figured you'd know the answer.[​IMG]
  5. Aug 1, 2010 at 8:40 PM
    #305
    RockyTacoma
    RockyTacoma Well-Known Member
    Dojo
    colorado
    2002 tacoma trd
    stock
    another project i cant do it myself. i will pay dealer $170 for this service.
  6. Aug 1, 2010 at 9:04 PM
    #306
    Tacomanator
    Tacomanator Well-Known Member
    Clam Slammer
    Southern Cali
    King 2.5" extended travel coilovers with compression adjusters, Camburg UCA's, King 2.5" rear shocks, TRD 1st gen CAI.
    great write up! glad i found this since im swappin my plugs to Pulstar Iridiums this week :)
  7. Aug 2, 2010 at 7:40 AM
    #307
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Good luck with those Pulstars. Let us know how they treat ya.
  8. Aug 5, 2010 at 9:07 PM
    #308
    Corbitt00
    Corbitt00 Member
    First off, let me just say thanks for all the tips on routine maintenance. Also, I may just be paranoid, but I feel like it takes my truck slightly longer to start after changing my plugs out just now. I went with the same exact plugs you recommended from the dealer (V6). Maybe I just didn't ever think about it...but it seems like it cranks for a full second before it finally starts. I don't have another Tacoma to compare it to, so I'm wondering if this is normal?
    If it starts and seems to run fine, can I assume I did it correctly?
    Thanks
  9. Aug 5, 2010 at 9:12 PM
    #309
    BakoTruck
    BakoTruck Well-Known Member
    Matthew
    Bakersfield, CA
    05 PreRunner TRD
    Probably nothing, I noticed I was paying a lot more attention on how the truck started and idled after a plug change.
    My truck sometimes takes a little longer to start too, nothing to worry about.
    If it gets worse, you may want to check to make sure all the plugs are properly installed. And if it continues to get worse, take it in.
  10. Aug 6, 2010 at 7:28 AM
    #310
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    Did you disconnected battery before the spark plug change? That could be one reason. otherwise if you screw up sparkplugs you pretty much know right away (CEL code, rough iddle, lack of power, misfires etc) Cranking for one more second is not really a spark plug thing unless all 6 are a problem.
  11. Aug 9, 2010 at 6:12 AM
    #311
    Corbitt00
    Corbitt00 Member
    I didn't disconnect my battery beforehand. I'm sure I'm just more aware of the truck (maybe looking for problems). I guess I was just needing to hear it from someone else.
    Thanks for your input
  12. Aug 14, 2010 at 1:51 PM
    #312
    Sampson90
    Sampson90 Well-Known Member
    Maryland
    2005 DC LB
    Chris,
    Another great techincal DIY write-up. Completed in about 90 minutes. Nice to know what to remove without taking too much off. Improve throttle respond, now to see if mpg's increase.
    Thanks Again !!!!!
  13. Aug 14, 2010 at 1:52 PM
    #313
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
  14. Aug 14, 2010 at 2:03 PM
    #314
    4421.frank
    4421.frank Well-Known Member
    Southside chicago
    02 double cab prerunner supercharged
    nasty dent on driver's side bed panel, shabby seats, cigarette burned interior roof, missing berf bar pad, cracked rain visor, removed hood scoop, unmentionable stain on back bench?
    I just got done installing new iradium 24k's on my first gen this afternoon. I have done this before but every time there is something new. This time I checked to make sure the new spark plugs were gapped right, they weren't. So I gapped 'em to .40. I also took the time to blow out my cold air intake and clean the inside of the intake pipe running to the throttle. Fired 'er up and she starts like a champ. Gonna go out later this evening and see if she rides any smoother.
  15. Aug 20, 2010 at 4:35 AM
    #315
    cblanke66
    cblanke66 New Member
    Carl
    Ft Worth Texas
    04 Pre Runner
    I noticed the picture of the plug is a single ground plug. I just changed plugs last night. Right after replacing all with the plugs, my son noticed a sticker on the timing belt cover that stated DO NOT USE SINGLE GROUND PLUGS<_ONLY DOUBLE GROUND,-which is what I pulled out,-half Denso and half NGK. I had just started the truck to make sure it ran,-but have not restarted until I find out about these plugs,-whether I can use them or not.
    Do you know if the single ground plugs are acceptable, and why the note about not using them? 2004 Prerunner V6 3400
    Thanks,
    Carl
    cblanke66@yahoo.com
  16. Aug 20, 2010 at 5:52 AM
    #316
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    The Dual ground plugs are required in the First gen V6's. It will run with the single ground, but you may get a check engine light, or poor performance.
  17. Aug 21, 2010 at 6:46 AM
    #317
    JoeSchmuck
    JoeSchmuck Well-Known Member
    Joe
    Virginia
    09 PreRunner SR5 2x4 O.R., Timberline Green
    Pop & Lock, Access LE Rollup Cover, Alpine PDX-5 Amp, Image Dynamics CS-6/CX-6 & 10" Sub
    Hum... This is the first I've heard of this in this thread, but I probably forgot something way back when I first read the entire thing. I'll have to take a look at my timing cover to see if it requires dual ground plugs. I'm not near replacing my plug, maybe in a few years, but it's still good to know before it's time. Now I'll have to look for test results using triple grounded plugs to see if that has a possitive or negative impact, if any.
    Anyway, glad I read this part.
  18. Aug 21, 2010 at 6:48 AM
    #318
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Only the first genners' (1997 - 2004) use the dual ground plugs. The 1GR-FE uses single electrode plugs. Use the ones I mentioned in the write up.
  19. Aug 21, 2010 at 7:04 AM
    #319
    JoeSchmuck
    Joe
    Virginia
    Thanks. Guess I got confused what engine had which plugs, but what's new ;).
  20. Aug 25, 2010 at 2:53 PM
    #320
    Vinybagodoughnuts
    Vinybagodoughnuts Member
    Vince
    Deerfield Beach,Fl
    05 trd sport sb
    Too many!!!!LOL
    Hey Chris thanks for the write up. Just finished and it runs like a champ. You rock!:D
