How To: Spark Plug Change (1 GR-FE)
Discussion in 'Technical Chat' started by chris4x4, Mar 16, 2009.
  1. Aug 25, 2010 at 5:25 PM
    #321
    chris4x4
    chris4x4 [OP] With sufficient thrust, pigs fly just fine. Moderator
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    No worries. It happens :)
    Glad to help !:)
  2. Aug 30, 2010 at 2:32 AM
    #322
    ph16drive
    ph16drive \m/.....\m/
    Paul
    Clevelandish
    08 DC, V6, 4x4, 5-Speed Auto
    Shorty antenna, Pop-&-Lock tailgate lock, Undercover bed cover, Aeroforce Interceptor gauge (custom mount), bed mat, AFE Pro Dry S air filter, map light mod, suspension TSB, Billy 5100's all around, Eibach springs, custom fuel tank armor plate, custom cat armor plate, painted front brake calipers, Grillcraft MX upper grill & Hella 500s, ipod adapter, dash pushbutton garage door opener, aux reverse lights, custom ipod nano 4G mount, seatbelt chime mod, custom bull bar w/ (3) Lightforce 140 Lance lights, POR-15 Chassis Coat Black drivetrain, illum 4x4 switch, xtra bed D-rings mod, locker anytime mod, diff breather relocation mod, ABS disable switch mod, Heated seats
    Thanks Chris for the great write up. I can't stress enough the use of electrical tape on the socket - very important.
    Thanks again Chris!:D
  3. Aug 31, 2010 at 9:51 AM
    #323
    Cortland
    Cortland Well-Known Member
    Cortland
    California
    Clifford aka Big Red
    Camburg 4" Spindles, 5100's All Around, All-Pro 1.5" Leaf Pack, All-Pro U-Bolt Flip Kit, Avid Sliders, AFE Pro Dry Filter, Wicked Flow 18" Muffler
    Thanks for the write up!
  4. Sep 6, 2010 at 11:12 PM
    #324
    stmpjmpr
    stmpjmpr Well-Known Member
    Jimmy
    So Orange County, Ca
    2014 Tacoma Sport MGM 4X4
    going to do my plugs tomorrow. Thanks Chris. i feel much better prepared to do it right the first time. and in a more timely manner.
  5. Sep 11, 2010 at 7:18 PM
    #325
    stmpjmpr
    Jimmy
    Did my plugs. followed these instructions and thank god Chris used tape on the socket. i also cleaned the MAF and TB. now it feels much better but i have the check engine light on. oh well. will investigate tomorrow. I verified all plugged back in.
  6. Sep 11, 2010 at 8:36 PM
    #326
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Re check your MAF connection, and make sure the air box is sealed good :)
  7. Sep 13, 2010 at 11:21 AM
    #327
    thegreatsam
    thegreatsam Well-Known Member
    Sam
    Vancouver, WA
    06 Double Cab TRD Off-Road
    Replaced the passenger side plugs easily enough, but I'm having a heck of a time replacing the drivers side plugs. There are 2 area's that are holding me up. I attached a picture because it's easier to see what it is I'm trying to describe.
    1) I was able to remove both bolts attached to the surge tank stay, but I can't move it more than an inch. Attached to the stay are several hoses (behind the large hose in the forground, you can see the markings "DOT KYO3). They are preventing me from moving the stay. Are these removable as well?
    2) How did you remove this plug? I can get the 10mm bolt removed, but I can't for the life of me get my big ogre hands in there to press the clip down.
  8. Sep 15, 2010 at 9:26 PM
    #328
    RX2RIDE
    RX2RIDE Well-Known Member
    Everett, WA
    09 TRD Tacoma (mine), 08 Sport 4 Runner(Wife)
    Is this the same process and plug gap for a 2008 4 runner? I just turned 30K and about to go on a 2000 mile road trip. What is the plug gap again?
  9. Sep 15, 2010 at 9:45 PM
    #329
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    I used the long needle nose pliers to get that plug off. You can just push the hoses out of the way.
    If its the same engine, It should be no different.
  10. Sep 23, 2010 at 3:16 PM
    #330
    pfalcon
    pfalcon New Member
    Coos Bay,OR
    Tacoma 4x4
    I will be doing a change out soon....
    Thanks for the heads up.
  11. Sep 29, 2010 at 11:15 AM
    #331
    gunner_20
    gunner_20 .....
    Nixa, MO
    '10 Tacoma DCLB Sport 4x4
    Thanks Chris4x4 for the write up. Got my done in about an hour. All the NGK were .050 or above. 48,000 miles (I know its a little long...) :eek:
    Also i put some boot protector on inside of the boots. Guess this is optional??
  12. Sep 29, 2010 at 12:39 PM
    #332
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Good to hear! Yeah, I've never used the boot protector stuff, and never had an issue. It cant hurt.
  13. Oct 8, 2010 at 5:43 AM
    #333
    Jessrin
    Jessrin Oh, okay...
    Jesse
    Upper Michigan
    24 Tacoma Double Cab TRD Off Road 4X4
    Stock
    Chris..
    I'm a little worried. I just bought this truck. It's has a lot of miles. 160000 miles. I've been reading this thread. Thinking I better check into this. I emailed the seller and asked when he last changed the plugs...... HE DIDNT!! The whole life of the truck...
    So.. Should I just have Toyota do this one????
    I'm dead ain't I???:confused::eek:
  14. Oct 8, 2010 at 8:03 AM
    #334
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    ONE HUNDRED AND SIXTY THOUSAND MILES??? I cant belive its still running....Yeah....Have the dealer change them. Theres a good chance the plugs could be frozen in the head, and this will take the liability off you.
  15. Oct 8, 2010 at 1:52 PM
    #335
    Jessrin
    Jessrin Oh, okay...
    Jesse
    Upper Michigan
    Stock
    Yes.. 160632 to be right on.. well, called the toyota dealership and was told that it would cost around 400 dollars! um.. NO!!! so today went and got the denso OEM plug. Same part number that you told us. Plus a 3/8 torque wrench.. and some anti-sieze
    okay.. the three on the passager side (DENSO ONES)... came out awsome.. WAY WORRIED WHEN I STARTED TO TURN THEM OUT.. but, it was okay.. got a little used to it by the third one..
    okay.. now on to the drivers side......... I had to come back to your post and study some more...
    wish me luck!
  16. Oct 8, 2010 at 2:03 PM
    #336
    Packman73
    Packman73 ^^^^ 3%er ^^^^
    The free state of Arizona
    2007 TRD Off Road
    Bilstein 5100's (front set @ .85"), OME 885's, chris4x4 anti-Taco-lean spacer on driver's side, Total Chaos UCAs, Rear Leaf Spring TSB, Toytec AALs, Black FJ TT Wheels, BFG 285/75R 16 AT Tires, TRD Exhaust, Viper Alarm, Fog Light Mod, De-badged, Blue LED Dome Light, EZ Clamped Tailgate, Wet Okoles, Satoshi Grill, 5% Tint, Engine Tick Fix, Black Rear Bumper, Black Center Valence, Exhaust Cut At Axle, Thanks for all the help chris4x4!
    Good luck, that side is tricky. Chris did mine and made it look easy though.;)
  17. Oct 8, 2010 at 2:48 PM
    #337
    Jessrin
    Jessrin Oh, okay...
    Jesse
    Upper Michigan
    Stock
    I DID IT!! I DID IT!!! taking a big deep breath.. started it up and kicked over and idled like it never did before.. i feel good now..
    THANK YOU SO MUCH ON A GREAT THREAD..
    CHRIS YOU ARE THE BOMB..
    THANK YOU FOR ALL THE PICS AND HELP.
    THANK YOU,
    THANK YOU!:)
    by the way, the old plugs were over .60 and the electrode was almost gone!! and yes.. they were the from the factory.. Denso on the right and NGk on the left... I can't beleive it.. over 160000 on those plugs..
    I hope now that I get some better fuel milage.. and i also replaced the air filter (since i was that far in the airbox) with a k&n filter..:D
  18. Oct 8, 2010 at 3:10 PM
    #338
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Good to hear!!! Man...Those plugs were a mess! Nice to hear the 1GR kept firing though !:)
  19. Oct 8, 2010 at 3:10 PM
    #339
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Aint nuthin but a thang :cool: :p
    TacomaCZman likes this.
  20. Oct 8, 2010 at 3:47 PM
    #340
    george3
    george3 Well-Known Member
    New Jersey
    2008 2.7 Manual Trans Tacoma
    Seat belt beeper, Cabelas (Weathertech) floor liner gray, Covercraft Seat Savers in Taupe, Protecta Heavy Duty Rubber Truck Bed Mat, Pop n Lock PL5200, Pace Edwards Full Metal JackRabbit, Wolverine oil pan heater, Scangauge2, afe pro dry s filter, Remote Underbody 4 Piece LED Light Kit (White) used as Bed light, DIY Washable Cabin Air Filter, PA15-TOY, 4x4 Illuminated Switch, full synthetic, Redline Tuning Hood Support, Smittybilt Nerf Steps black powder-coated
    Congratulations ! My first thought when I was reading this thread was "Welded" as in plugs welded to the block.:eek: Glad it didn't happen. Any pics of those plugs ?:confused::confused: Amazing they still were working at 160,000.
