How To: Spark Plug Change (1 GR-FE)
Discussion in 'Technical Chat' started by chris4x4, Mar 16, 2009.
  1. Jun 3, 2011 at 7:07 PM
    #521
    chris4x4
    chris4x4 [OP] With sufficient thrust, pigs fly just fine. Moderator
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    The problem with doing one side, or all of them at once, if you get distracted, you could forget which plugs were torqued, and which ones werent. Torquing a plug 2 times, could result in a striped head, or broken plug.
    TacomaCZman likes this.
  2. Jun 3, 2011 at 7:23 PM
    #522
    eyball
    eyball Well-Known Member
    Dudley, MA
    20 Double cab TRD Sport Voodoo Blue
    Going one at a time worked good for me but that's with two ratchets
  3. Jun 3, 2011 at 9:04 PM
    #523
    JKD
    JKD Well-Known Member
    By the way, changing the factory plugs at 44570 miles, here were the gaps. I list them with plug number in brackets, plug manuf/model, wire gauge results (max size I had was 0.045"), and vernier caliper measurement in cm:
    Plug Numbers (as best I know, from http://bit.ly/iLwSnz )
    [Engine Fan]
    [2][1]
    [4][3]
    [6][5]
    [1] Denso K20HR-U11 >0.045" 0.12cm
    [2] NGK R LFR6C H >0.045" 0.13cm
    [3] D >0.045" 0.12cm
    [4] N >0.045" 0.13cm
    [5] D >0.045" 0.12cm
    [6] N >0.045" 0.12cm
    Acceptable gap range is 0.039" to 0.043", or about 0.10 to 0.11 cm. Mine were over, but I have not noticed any driveability, mileage, or roughness issues. Most of my driving has been 55-70 mph commuting.
    While the caliper measurements are rough at best, two of the three NGK plugs were measurably wider gap than any of the Denso.
  4. Jun 3, 2011 at 9:09 PM
    #524
    JKD
    By the way, it seemed odd that I didn't feel any sort of 'click' when reinstalling the coils. Do they just use the bolted-in style to make sure there is contact between the coil and the plug?
  5. Jun 4, 2011 at 10:02 AM
    #525
    linkfeeney
    linkfeeney Well-Known Member
    link the stink!
    Sewell, NJ Eh!
    09 Doublecab TRD Off-Road! Magnetic Grey!
    do you really need to use the dielectric grease on the coil packs? I changed mine at 30k I put the anti sizeing compound on my plugs. When i had my 2000 Altima, it was wires and plugs and I put dielectric grease on that. 60k is coming up already on my truck... should I add the grease this time around?
  6. Jun 4, 2011 at 10:53 AM
    #526
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    It wouldnt hurt.
  7. Jun 5, 2011 at 7:18 AM
    #527
    linkfeeney
    link the stink!
    Sewell, NJ Eh!
    do i put the grease on the ceramic part of the spark plug? or put it on the coil pack outside boot part? thx
  8. Jun 5, 2011 at 7:20 AM
    #528
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Ive always just put it on the inside of the boot.
  9. Jun 5, 2011 at 2:28 PM
    #529
    JKD
    Inside of the boot, smear it around a bit. I've never used much. I have the same little tube of dielectric grease in my toolbox that I've been using since the mid-1990s.
  10. Jun 5, 2011 at 9:12 PM
    #530
    ctxtaco
    ctxtaco Well-Known Member
    Austin, Texas
    2010 PreRunner SR5 Double Cab
    Black tube steps
    30,960 miles on the 2010 PreRunner. Changed the plugs tonight with the new recommended Densos. The old NGKs looked a little worse than the old Densos. There is a definite difference in performance and power on the test drive. Thanks, Chris for the great write up. It was a hassle free 3 hours to get it done.
  11. Jun 22, 2011 at 1:03 PM
    #531
    Danosabre
    Danosabre Well-Known Member
    Dan
    Gardner,Ma
    09 TRD Off Road
    Extang Trifold bed cover,DDM 55W 6000k HID, maglight, Vent visors
    Thanks Chris for the write up, I'll be using it soon to do my plugs.
    I had to buy my plugs on line, because none of the auto stores around me carry the denso's. I checked Advance auto, auto zone , napa, caps and carquest. Then I called the stealer and they wanted 13.99 a plug. :quickdraw::rant: So I went here: http://sparkplugs.com/results_app.asp?productTypeID=1&AAIA=1442970 and paid 3.46 a plug. :headbang:
  12. Jun 23, 2011 at 5:38 AM
    #532
    Jkinney65
    Jkinney65 Member
    White House, TN
    08 Pre Runner SR5 V6 2wd
    Perhaps I should have asked, but when I changed plugs at 30 K I changed to iridium. I decided that if they would work in cars for 100 K they would work in pickups. I think it's toyota's way of getting dealers more work.
  13. Jun 23, 2011 at 9:04 AM
    #533
    romafern
    romafern Hug diz nuts
    Rob
    80918 Let's meet!
    Paid for and saving a shit ton of $$$$$
    Thinking of adding a second battery...
    You could be right but I do not agree with that. You own the truck and you can take it anywhere you want to. In fact, it is more enjoyable to work on it yourself. This of course is up to a certain extent since now they have all those computers and stuff. I keep getting calls from my dealer and Toyota reminding me to take my wife's 2011 Highlander in for their complementary free oil change. I told them not interested since I do not trust the local and only dealer in this area. Some engines are very picky when it comes to the plugs. The GMC Envoy my wife had required a specific plug and no other. If you put another kind, it will act like some of the trucks in this forums. I say change the plugs per Toyota recommendations and you will be golden.
  14. Jun 23, 2011 at 9:31 AM
    #534
    romafern
    Rob
    80918 Let's meet!
    Good Lord!
    You should show them what you paid for them. I can see them for 6 bucks but 13 for one of them, is plain illegal.
  15. Jun 24, 2011 at 12:36 AM
    #535
    seanmccarthy1
    seanmccarthy1 Member
    massachusetts
    05 sr5
    Excellent!!!!!!!!!!!!!
  16. Jun 27, 2011 at 6:18 PM
    #536
    GSB
    GSB Well-Known Member
    Odenton, MD 21113
    09 TRD Sport DC Long Bed
  17. Jun 27, 2011 at 6:32 PM
    #537
    GSB
    Odenton, MD 21113
    They wanted $45 for a stock air filter. I havent tried any other local dealers for prices. I have just been ordering on the net.
  18. Jun 27, 2011 at 7:39 PM
    #538
    BrokenTusk
    BrokenTusk I support a velociraptor free workplace.
    Marcelasaurus
    AB, Canada
    The Scarlett Whore
    Check Build Thread!!
    i paid 28 for all 6 from dealership 2 months ago
  19. Jun 28, 2011 at 1:19 AM
    #539
    flatfeet
    flatfeet Well-Known Member
    Rob
    Hilo
    09 TRD Sport 4x4 DBL CAB
    RCD 4.5 lift, 18x9 BFD, 305/60-18 Mickey Thompson ATZ's, projector HIDs, TRD exhaust, AFE intake, onboard air, led dash mod, train horns.
    Just payed $30 at the dealership here in Hawaii (for the set). Ouch!
  20. Jul 2, 2011 at 3:41 AM
    #540
    ELKERSKELTER
    ELKERSKELTER New Member
    Mayberry, MA.
    09 tacoma double cab LB
    Thanks for the write up! I did mine in less than an hour. I used my extendable craftsman magnet to retrieve the plugs and to start them, because the rubber grommet in my socket was to loose.
