How To: Spark Plug Change (1 GR-FE)
Discussion in 'Technical Chat' started by chris4x4, Mar 16, 2009.
  1. Feb 7, 2012 at 8:00 PM
    #701
    Jayzekiel
    Jayzekiel Active Member
    Colorado
    08 Tacoma
    aries bull bar, truxedo low pro, k&n cold air
    Very well... Thanks guys!
  2. Feb 8, 2012 at 9:42 AM
    #702
    garys05tacoma4x4
    garys05tacoma4x4 OneLife
    Agawam, MA
    05TRDSportLB4x4
    Synthetic oil/lubes used throughout. NGK Iridium Lazer 100K spark plugs. Rear differential breather extension modification. Toyota front skid plate, roof rack, bed mat, chrome exhaust exhaust. Runs like new!
    The srevice department will recomend either Denzo or NGK but of course they only sell their Toyota Denzo Plugs. Unlike 99% of people posting on here I have better things to do than replace my plugs ever 30K.
    I switched over to NGK Iridium 100K (I believe called platinum lazer-not sure what the lazer does but for .70C more a plug I figured what the heck)) plug from NAPA. The service department had a chart on the wall stating they could be used and I was talking to the serviceman who was suppose to do the 30k plug change intervals on his Sequia SUV. He was happily driving it with 118k NGK Iridiums. I was sold. My truck runs like new still. I spent about $65-$75 for the plugs and my mechanic to do it in 45 minutes. Don't have to think about or again until I hit 172K; doubt I'll even keep the truck that long but that depends on gas prices and maintenance until that time.
    Or you can change the plugs 3 times, continue to buy new plugs at the dealer and it seems to take most people 1.5 to 2 hours to change. Lets just call it 6 hours for 90K; buying & changing the plugs 3 times. I still have 10K more miles before I have to change mine, saved 5hours and 15 minutes, plus the cost of rebuying plugs 3X. You do the math. Good luck.
  3. Feb 8, 2012 at 9:54 AM
    #703
    chris4x4
    chris4x4 [OP] With sufficient thrust, pigs fly just fine. Moderator
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    By changing the plugs, you are also able to see how the engine is performing by looking at the condition of the plugs. It takes on average, about 45 mins to change all 6. It gives peice of mind that the engine is running good, or can give a "heads up" if somthing is going wrong. I dont think most people have a hard time spending 45 mins. every 30k miles changing their plugs. Besides, there is quite a bit of satisfaction doing it yourself. Not to mention, some folks have had issues running Platinum/iridium plugs..
    TacomaCZman likes this.
  4. Feb 8, 2012 at 10:48 AM
    #704
    wyotaco06
    wyotaco06 Well-Known Member
    Offroad 4x4 06
    I have done this twice now, and am almost to my 90K change. Both times I have not used a torque wrench. I don't own one and have heard that using a cheaper wrench or one that is for 0-80 ft. lbs isn't all that accurate as most wrenches are more accurate in the middle of their range(for a 0-80fl/lbs wrench I guess 25-65ft/lbs would be more spot on than the 15ft/lbs these plugs require). Is this true?
    BTW, when I have done this I used the extension to get the plugs finger tight, then turned them 1/4-1/2 turn more or until they felt snug keeping in mind the "15ft.lbs" they require. No problems so far in two changes, but I have wondered what kind of harm could be done by not torquing them enough or too much, besides stripping the heads. I feel that you would have to REALLY have to crank on them to strip them out, it has always felt pretty obvious to me when they were good to go and not to apply any more force.
    Is my technique flawed? Obviously a nice T wrench would be better but I would say %99 of the time you have this done at a shop they would not use one, even with access to a good T wrench...
  5. Feb 8, 2012 at 1:10 PM
    #705
    george3
    george3 Well-Known Member
    New Jersey
    2008 2.7 Manual Trans Tacoma
    Seat belt beeper, Cabelas (Weathertech) floor liner gray, Covercraft Seat Savers in Taupe, Protecta Heavy Duty Rubber Truck Bed Mat, Pop n Lock PL5200, Pace Edwards Full Metal JackRabbit, Wolverine oil pan heater, Scangauge2, afe pro dry s filter, Remote Underbody 4 Piece LED Light Kit (White) used as Bed light, DIY Washable Cabin Air Filter, PA15-TOY, 4x4 Illuminated Switch, full synthetic, Redline Tuning Hood Support, Smittybilt Nerf Steps black powder-coated
    finger tight, then turned them 1/4-1/2 turn more or until they felt snug - sounds good 2 me:D
  6. Feb 8, 2012 at 2:35 PM
    #706
    Jayzekiel
    Colorado
    08 Tacoma
    Right.. finger tight and 1/2 a turn. Did mines today with denso and took me 35 min. Saved me $175 from the dealer. Also installed the k&n cold air intake. I couldnt pass up $202 for those and free shipping and no tax. Taco is running very smooth and cant wait for the scangauge to come in the mail.
    @Chris.. very true to change them out at the correct intervals as you see how the engine is performing.
    @Gary.. Yes, I did the math. Pay little now or more later. :)
  7. Feb 10, 2012 at 5:19 PM
    #707
    PhishPhryer
    PhishPhryer Well-Known Member
    Lewisberry
    '09 Tacoma SR5
    Chris thank you so much for the write up. Did this today and it was a breeze. I never would have tried this but the instructions really simplified it for me.
    I asked the guy at the parts counter if he knew why Toyota used three Denso's and three NGK's to which he replied that Toyota absolutely does not do that. Further solidifying my plans to never have the dealer work on my truck unless absolutely necessary.
  8. Feb 10, 2012 at 5:26 PM
    #708
    george3
    New Jersey
    :eek::eek::eek::eek:
  9. Feb 11, 2012 at 9:27 AM
    #709
    canyonchaser
    canyonchaser Member Known Well
    Dave
    Utah
    LR TRD PRO MT
    Ha! My dealer had a very sensible answer straight away.
    dp
  10. Feb 11, 2012 at 11:59 AM
    #710
    PhishPhryer
    Lewisberry
    '09 Tacoma SR5
    Well? What was it?
  11. Feb 13, 2012 at 9:13 PM
    #711
    RJinWarren
    RJinWarren Member
    RJ
    Oregon
    05 Tacoma Dbl Cab LB 4x4
    3" coil over lift, 33" BFG Mud-Terrains, Yakima Rack System, Debadged, Snugtop Canopy, AFE drop-in air filter
    Thanks for the great instructions! Took care of mine last week, and discovered that at 83K my previously owned Taco still had the original plugs. Densos weren't too bad, and NGK's were a bit worse.. Passenger side was a breeze, and drivers side wasn't bad other than the front plug (closest to radiator) had zero slack in plug wires and took a great deal of patience (and a quick beer break) to get accomplished.. Ran one tank of gas through and picked up some MPG.
    Just dropped in a new AFE air filter today. Thanks for all the info TW members!
  12. Feb 14, 2012 at 9:25 PM
    #712
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    You guys think that something I need to replace sparkplugs on my 3UR-FE this weekend. Wish me luck.:D
  13. Feb 17, 2012 at 8:38 PM
    #713
    John Cheong
    John Cheong Active Member
    East Bay, CA
    2001 SR5 PreRunner
    33" falken rocky mountian A/T, 3.5" fabtech lift, Deck plate mod, Painted badges.
    dont ever use the coin gapping tool on modern sparkplugs. it can mess up the prongs and electrode and you would never be able to tell. use a wire gauge to gap the plugs. My old teacher from wyotech couldnt stress that enough and hes been building engines for over 40 years...
  14. Feb 17, 2012 at 8:45 PM
    #714
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    I use either the coin gapper, or feeler gauges. Never had an issue with the coin tool.
  15. Feb 18, 2012 at 4:29 AM
    #715
    jandrews
    '09 FourDubDee TRD OR
    Coin gappers are only dangerous to precious metal plugs, which really shouldn't be used in the case of the 1GR-FE.
    If you're a sucker and use the platinums or iridiums or any of that other overpriced stuff, then yes, you could wear the metal off the electrode tip.
  16. Feb 18, 2012 at 9:40 AM
    #716
    george3
    New Jersey
    "If you're a sucker and use the platinums or iridiums " Aren't iridiums required on the 2.7 ? If so am I still a sucker ?:rolleyes:
  17. Feb 18, 2012 at 12:09 PM
    #717
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    If the owners manual calls for it, youre not a sucker.
  18. Feb 18, 2012 at 2:27 PM
    #718
    jandrews
    What is the title of this thread?
  19. Feb 19, 2012 at 10:44 AM
    #719
    Lukin
    Lukin Active Member
    New Jersey
    2011 DC TRD Sport
    Thank you for this write up. I did this today along with the rest of the 30k service. By far one of the easiest vehicles I have ever worked on. Had an 08 5.7 tundra before my Taco and never wanted to mess with it and was at the dealers mercy for that. Saved a boat load of money, got the satisfaction of doing it myself and knowing it was done right. Thanks again
  20. Feb 20, 2012 at 6:09 AM
    #720
    mtgross
    mtgross New Member
    Michael
    Durham, North Carolina
    05 PreRunner
    The front plug (farthest away from the firewall) on the driver's side was by far the most difficult to change in my 2005 PreRunner. There is very little room behind the wire harness that goes to the coil, making it very difficult to remove the harness or to re-attach the harness if the coil is still bolted in place. The trick I discovered to deal with this was to first remove the 10 mm bolt holding the coil to the valve cover and then lift the coil up slightly so that you can tip it toward the firewall. This creates a little more room behind the wire harness to make its removal easier. After you change the spark plug, then do everything in reverse and attach the wire harness before you bolt the coil to the valve cover. Otherwise, all of the other wire harnesses can be removed and re-attached with the coil bolted in place. Hope this helps you all. Mike
