How To: Spark Plug Change (1 GR-FE)
Discussion in 'Technical Chat' started by chris4x4, Mar 16, 2009.
  1. Jan 24, 2013 at 3:34 PM
    #981
    chris4x4
    chris4x4 [OP] With sufficient thrust, pigs fly just fine. Moderator
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Use a plug gap gauge, and bend the electrode out just a bit, then insert the gauge, and bend in until snug against the correct size gap gauge. Hope that makes sense :eek:
  2. Jan 24, 2013 at 3:37 PM
    #982
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
  3. Jan 24, 2013 at 3:51 PM
    #983
    waheed
    waheed Well-Known Member
    Waheed
    Vancouver
    2010 Tacoma TRD OFF-ROAD
    Banks power Exhaust, 4x4 LED mod, Duratracs, SNUGTOP, LED insideNout
    I'm sticking to the good ol' Original Gangstas :D
  4. Jan 24, 2013 at 6:54 PM
    #984
    4Paws
    4Paws Active Member
    Scott
    Texas
    '04 PreRunner
    Hey Chris,
    (1st post btw) enjoyed your very thorough description. I'm about to do my plugs so I may do something similar since mine is an '04. You wouldn't have any idea what the gap for those plugs should be would you?
    I bought a new set of Densos from Toyota and the guy said they should be good to go. I checked one and it was about .033. They are dual electrode.
    Thanks,
    Scott
  5. Jan 25, 2013 at 5:51 AM
    #985
    snappa
    snappa Snappa
    Rhode Island
    2011 PreRunner Access Cab
    Chris,
    As I said before, props to you for this step by step. Could not have been more clear nor would I have successfully completed the task or even attempted without your instructions.
    My question, as indicated in the title line, has to do with the use of anti-sieze on the plug threads. To the best of your knowledge, does Toyota or Denso or NGK specifically state that anti-sieze should be used, or not used, for this application?
    I am not questioning the efficacy of the use, or not, of anti-sieze. I have not been able to find this mentioned in the limited Toyota literature I possess.
    Thanks in advance.
    paul
    aka Snappa
  6. Jan 25, 2013 at 5:55 AM
    #986
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Toyota does not say specifically to use anti seize on the spark plugs. However a friend of mine who was a lead mechanic at Toyota, eventually moved up to head mechanic told me that it's a good practice in his eyes to use anti seize when installing spark plugs into aluminum heads.
    TacomaCZman likes this.
  7. Jan 25, 2013 at 5:58 AM
    #987
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    The correct gap is 0.0394 to 0.0433 in
  8. Jan 25, 2013 at 8:12 AM
    #988
    4Paws
    4Paws Active Member
    Scott
    Texas
    '04 PreRunner
    Hey Chris, thanks for the info. Do you mind telling me what your source is for that?
  9. Jan 25, 2013 at 8:19 AM
    #989
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    The FSM.
  10. Jan 26, 2013 at 8:47 AM
    #990
    snappa
    snappa Snappa
    Rhode Island
    Chris,
    Thanks for the reply. I also ride a Honda GL1800 m/c. Among others, a particular NGK spark plug is recommended. The spark plug number has a suffix or prefix, which I cannot recall at this time, indicating an anti-seize compound of some type has been applied at the factory to this particular plug. Additional anti-seize is not recommended.
    ride safe
    paul
    aka snappa
    Chris,
    Let me stand corrected on the foregoing. NGK specifically recommends that anti-seize not be applied on plugs with a metal shell plating such as zinc or nickel, on the threads:
    "Applying anti-seize to the threads of spark plugs that have a metal plating allows the installer to mistakenly over-tighten the spark plug in the cylinder head; This stretches and fatigues the threads of the spark plugs, causing a much higher probability that the plug will break during installation or in some cases upon removal." Additional info:
    http://ngksparkplugs.com/pdf/TB-0630111antisieze.pdf
    However, given the foregoing, each do what they feel is best.
    As always,
    ride safe
    paul
    aka snappa
  11. Jan 26, 2013 at 1:55 PM
    #991
    JoeSchmuck
    JoeSchmuck Well-Known Member
    Joe
    Virginia
    09 PreRunner SR5 2x4 O.R., Timberline Green
    Pop & Lock, Access LE Rollup Cover, Alpine PDX-5 Amp, Image Dynamics CS-6/CX-6 & 10" Sub
    It's interesting to note that both NGK and Denso both do not recommend using anti-sieze compound due to over-torquing problems.
    Also NGK recommends 18-21.6 lb-ft where Denso recommends 14.75-22 lb-ft of torque.
    I'm curious where the 15 lb-ft value came from in this thread (probably the FSM).
    So I'm curious if we really should be using anti-seize compound on the plugs. Prior to buying a torque wrench I always seated the plug by hand and then used a socket wrench to crush the washer and slightly more until it was a good snug fit. I learned that from my daddy. Plugs without washers were different and those were hand tight + slightly more until it firmly stopped. It's hard to describe it, that is why a torque wrench comes in handy.
  12. Jan 26, 2013 at 2:12 PM
    #992
    Sgtfluffy16
    Sgtfluffy16 Well-Known Member
    Corey
    PA
    07 Tacoma Double Cab TRD Sport
    20% tint, HID headlights/ yellow fog light bulbs and LED lights interior/exterior lights. 4.5 Inch RCD lift, 1 Piece custom driveshaft, AEM intake, Dynomax Exhaust, Amp research Moto-bed extender, Extang Express tonno.
    I have always used White Lithium Grease on my threads... Just did my plugs in about an hour.. Pics to follow soon. and WOW! do I have news!
  13. Jan 26, 2013 at 2:39 PM
    #993
    Sgtfluffy16
    Corey
    PA
    So after I found out we should change out our plugs every 30k I started doing research and found that NGK V-Power's are the most reccomend I bought a set and just did them about 2 hours ago. my truck has 82K on it and here to find......... I .... STILL..... HAVE.... THE..... ORIGINAL.... PLUGS.... INSTALLED!! Great!.. This is prolly why I could only get 17MPG max when I bought it 2 years ago when it was bone stock and had 67K on it. I put an intake on it hoping it would help fuel mileage and it didn't ( BTW the intake make its much easier to plugs ;)) Then I did the lift which I knew would hurt the fuel mileage but wait til you see what the plugs gap is when I took them out. So new plugs are in and Here's for new and improved fuel mileage I hope. (PS. I also noticed the Denso Plugs were harder/ required more force to thread out of the heads then the NGK's which came out quite easy)
    Easier install with an intake [​IMG]
    Just loosen the clamps there and you can get to the front plug [​IMG]
    82K on the denso plug (its a "little" out of spec) [​IMG]
    The NGK's with 82K on them
    All 6 plugs.. NGK's were on drivers side Denso on Passenger side [​IMG]
  14. Jan 26, 2013 at 4:09 PM
    #994
    JoeSchmuck
    Joe
    Virginia
    White Lithium grease for the threads? Isn't that the wrong product? Typically anti-seize is not lithium based for high heat applications. It's more of a selection of powered metals mixed into a paste. And these there is dielectric grease for the spark plug wires if you ant them to pull off easy in a few years.
  15. Jan 26, 2013 at 4:17 PM
    #995
    Sgtfluffy16
    Corey
    PA
    Its what I have ALWAYS used on plugs and I have had quite a few fixer uppers and never have I ever had issues removing plugs after 5 years after I did plugs with White Lithium
  16. Jan 26, 2013 at 4:54 PM
    #996
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Although they dont recomend the anti sieze on their sites, I have always been told its good to use it on aluminum heads. I asked my friend about the 15# listed in the FSM, and he said thats for use with the anti sieze, as the torque value is lower when using it. Higher (20# or so) without it. Havent had an issue with anti sieze on a plug in around 25 plug changes on vehicles.
  17. Jan 26, 2013 at 5:08 PM
    #997
    JoeSchmuck
    Joe
    Virginia
    Yea, I really would prefer to use anti-seize compound too so thanks for the feedback about the torque spec. In the old days I always used it but we didn't have fancy coatings on the plugs and aluminum heads were for people who had money to burn, which wasn't my family :(
  18. Jan 26, 2013 at 5:17 PM
    #998
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    After my first siezed plug in an aluminum head, which ended up stripping all the threads in it, having to remove the head, drill, insert new threads (metal sleave threaded), I wont ever NOT use anti sieze again.
  19. Jan 26, 2013 at 5:30 PM
    #999
    JoeSchmuck
    Joe
    Virginia
    Oh how I love helicoils ! I use them in my line of work whenever someone screws (pun intended) up, never had to use them on an engine. I've seen some monster sized helicoils when I was on the submarine, thankfully I didn't have to to drill, tap, and insert those monsters. The small ones are fine unless it's some heavy duty steel (normally was) and then the easy-outs were never that easy to make work. Try an easy-out on a stainless steel 4-40 screw, no fun drilling it out. Sorry for the ranting on an on.
  20. Jan 26, 2013 at 8:03 PM
    #1000
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    I had to use a timesert on the head. Not sure a helicoil would have worked given the temp fluctuation of the head. Then again.....if the helicoils worked on subs, who knows. The last helicoil I used was on the engine block of my buddies Duccati. When changing the cam belt, he didnt want to use a torque wrench, and blew thru the threads on 4 holes. SO.....he got to see how a helicoil works. :)
