How To: Spark Plug Change (1 GR-FE)
Discussion in 'Technical Chat' started by chris4x4, Mar 16, 2009.
  1. Jan 29, 2013 at 11:34 AM
    #1001
    fcboos
    fcboos Member
    Frank
    League City, Texas
    2006 prerunner
    Revtech 3"
    Great write up. Just finished my plugs took my time and all came out well. The driver side is a lot harder to do. Also used two long extensions for the driver side, got the wrench out of all the hoses. Thanks for the write up it helped. :thumbsup:
  2. Jan 29, 2013 at 1:06 PM
    #1002
    chris4x4
    chris4x4 [OP] With sufficient thrust, pigs fly just fine. Moderator
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    :cheers:
  3. Jan 29, 2013 at 3:10 PM
    #1003
    Aggiesdm
    Aggiesdm Well-Known Member
    San Antonio
    17 TRD OR 4X4
    SnugTop topper, WeatherTec mats, thats all for now
    NIce Write Up! I did mine in about 45 mins and was surprised at how much the gap had widened on the OEM plugs. It was at .52 vs the .40 that is recommended. Anyway, hoping to get back a little performance and milage.
  4. Jan 31, 2013 at 3:05 PM
    #1004
    Rackster
    Rackster Well-Known Member
    Kevin
    Connecticut
    '04 E/cab 4x4 2.7 Auto SR5
    I swapped out my plugs on my 2004/2.7....looks like the previous owner may have never changed the plugs. Gaps on the plugs were around .079. Amazingly, I never had trouble starting/driving the vehicle and maintained 20/23 MPGs.
  5. Jan 31, 2013 at 3:20 PM
    #1005
    matadorCE
    matadorCE Well-Known Member
    Melbourne, FL
    '05 Prerunner Accesscab TRD Offroad
    Good write-up and it was hepful when I did my plugs last month. My truck never had it done before by the previous owner since I found one side had Densos and the other side had NGK. I disagree with using antiseize on the spark plugs, although realistically it won't do any harm if you know what you're doing. I don't use torque wrenches for spark plug or on the oil drain plug since I'd rather not strip anything by putting confidence on a wrench that may/may not be calibrated correctly or highly accurate. I use a short handle ratchet when tightening the plugs so that way I'm not multiplying the torque by a lot and stop tightening when I start feeling significant resistance. I've used this method on my MR2 for almost 10 years now (aluminum head on an iron block) and no stripped plugs so far.
    PS I couldn't believe how little slack there is in the ignition coil wire harness for the forward-most driver side plug. I didn't think i was going to be able to get the coil off at first and I think in the future it may be a big risk of messing up the wire harness as everything ages and get heat cycled.
  6. Feb 1, 2013 at 6:37 AM
    #1006
    JimROCDS
    JimROCDS Well-Known Member
    Jim
    Massachusetts
    Tacoma
    So Chris, do you have a write up like this for doing break jobs?
    That's gonna me my next project.
    Regards
    Jim
  7. Feb 4, 2013 at 2:13 PM
    #1007
    CZ10
    CZ10 New Member
    Don
    Central CA
    And I thought my 69 Porsche was a PITA!!!
  8. Feb 4, 2013 at 3:03 PM
    #1008
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    brakes are REALLY simple. I should have made a write up, as I changed Pinal1223's the other week,.
  9. Feb 8, 2013 at 10:50 PM
    #1009
    Drunknsloth
    Drunknsloth Indffrnce will be the fall of manknd but who cares
    Retribution
    South West
    08 SR5 Access V6 6-Speed
    Blacked-Out Badges; Retribution Decals (Sockmonkey); Tailgate Mod; Red LED Rear Blinkers; Yellow Foglights; Yellow Front Blinkers; Superwhite Xenon Corner Bulb; Leer Bedcap; Bedrug Bedmat; Black Cupholders; Black Plastic Piece Around Window Controls; Plasti-Dip Front Bumper Valence; Plasti-Dip Grill Surround; Blackout Chrome Back Bumper; Metal Miller Skid-Plate; Aero Turbine 2525 Muffler; TSB Rear Leaf Springs and Shocks; Satoshi Grill Pending; Off-Roading Torn off Mirror (Replaced); Blue-Sea Fuse Box; Tinted Tail Lights; URD Short Shifter; Interior Mood Lighting; Hood Lights; BedLights Pending
    It would help me :eek: Every time I drive someone else's car it feels like I slam on the brakes the first time I touch the brakes because they're so much more sensitive.
  10. Feb 9, 2013 at 10:26 AM
    #1010
    cajunron
    cajunron Active Member
    Ronnie
    Atlanta, GA
    2006 PreRunner Access Cab
    I'm with you on that one, brother. I am a union electrician by trade, and I know first hand the importance of using a lubrication medium between two threaded surfaces. ESPECIALLY between a joint that is intended to have service intervals. Not using anti-seize is just leaving yourself open to serious problems. It's not just cross threading you have to worry about. Ever shear the head of a bolt off of something because it was seized up? NOT fun.
  11. Feb 16, 2013 at 6:44 AM
    #1011
    Redsoxnation
    Redsoxnation Well-Known Member
    Pa.
    PreRunner TRD 4X4 Impulse Red
    none yet...
    Chris.. many thanks for this write up along with your oil filter post..
    I see you used 6 denso rather than 3 denso 3 nkg.. I read on another Toyo forum about some reason to use denso/ngk combo because of "waste spark cross over" ? can I use 6 denso's on my 2006 V6 TRD ? with out mileage loss or preformance ?
    Thanks
  12. Feb 16, 2013 at 6:52 AM
    #1012
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Toyota does not use a wasted spark system on the 1GR-FE. you will be fine using the denso spark plug
    TacomaCZman likes this.
  13. Feb 16, 2013 at 9:19 AM
    #1013
    JoeSchmuck
    JoeSchmuck Well-Known Member
    Joe
    Virginia
    09 PreRunner SR5 2x4 O.R., Timberline Green
    Pop & Lock, Access LE Rollup Cover, Alpine PDX-5 Amp, Image Dynamics CS-6/CX-6 & 10" Sub
    Even if our engine used wasted spark, what difference would it make in using two different types of plugs since they all have to fire in the same manner. As far as I know, there is no rhyme or reason to using two different plugs in our engines but Toyota has been doing this for a long time now. I would love to know why they do this, right now I think it's a data collection effort for the reliability of the components. It makes sense to do things that way because you subject both plugs to the same stresses so when the dealer changes them out it just becomes so much easier to have a valid comparison. This is assuming Toyota ever wants to collect data.
  14. Feb 16, 2013 at 10:10 AM
    #1014
    Redsoxnation
    Pa.
    none yet...
    I read something about pre WW2 and post WW2 in Japan about
    manufacturing equal rights law requiring companies to procure equally from component company's.. or something like that..
  15. Feb 16, 2013 at 11:12 AM
    #1015
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Since about 2 million have been sold, and have had the Denso/NGK plug arangement, Im thinking they should have enough out there to form a viable decision.
  16. Feb 17, 2013 at 5:59 AM
    #1016
    Optimus2009
    Optimus2009 Well-Known Member
    '09 DC 4x4 OR
    Bilstein 5100s x 4, Fabtech 1.5" AAL, Pioneer DMH-W4660NEX, SiriusXM, Console Vault
    That would not surprise me at all. Amazing how politics gets in the way of important stuff. The parts guys at the dealer just handed me 6 denso plugs. Good enough for me. Go Sox.
  17. Feb 17, 2013 at 7:10 AM
    #1017
    JoeSchmuck
    Joe
    Virginia
    I could believe that too.
    Go Sox :confused:
    LOL
  18. Feb 17, 2013 at 5:01 PM
    #1018
    tonytehpirate
    tonytehpirate Member
    Tony
    garden grove
    1999 toyota tacoma 3.4L v6 efi
  19. Feb 17, 2013 at 5:46 PM
    #1019
    Sgtfluffy16
    Sgtfluffy16 Well-Known Member
    Corey
    PA
    07 Tacoma Double Cab TRD Sport
    20% tint, HID headlights/ yellow fog light bulbs and LED lights interior/exterior lights. 4.5 Inch RCD lift, 1 Piece custom driveshaft, AEM intake, Dynomax Exhaust, Amp research Moto-bed extender, Extang Express tonno.
    this may be a dumb question but I replaced all my plugs with ngk v powers.. I gapped them all at like .041 buttt.. I thought replacing my plugs could possibly help me get a few more MPG's I was wrong! It has actually made my MPG's even worse.. Anyone else have this same issue? or is it temporary until I run a few gas tanks through?
  20. Feb 18, 2013 at 1:05 PM
    #1020
    romafern
    romafern Hug diz nuts
    Rob
    80918 Let's meet!
    Paid for and saving a shit ton of $$$$$
    Thinking of adding a second battery...
    How is your air filter? Tire pressure?
    Tony,
    Ahoy! If your cables look fine, then there is no need. As for the part number, sorry I can't help you there...I will have to do some research... someone should chime in b4 I post.
