How To: Spark Plug Change (1 GR-FE)
Discussion in 'Technical Chat' started by chris4x4, Mar 16, 2009.
  1. Jun 11, 2013 at 9:54 AM
    #1101
    chris4x4
    chris4x4 [OP] With sufficient thrust, pigs fly just fine. Moderator
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    That's when they should be changed
    TacomaCZman likes this.
  2. Jun 11, 2013 at 10:09 AM
    #1102
    T Fades
    T Fades Well-Known Member
    Simi Valley, CA
    '11 PreRunner V6 2wd DCLB
    Satoshi, debadged, rear view mirror bracket, tail gate hose clamps, trimmed mud flaps.
    Thanks Chris!
  3. Jun 12, 2013 at 6:38 AM
    #1103
    JimROCDS
    JimROCDS Well-Known Member
    Jim
    Massachusetts
    Tacoma
    Of course if your dysfunctional like me, you'll start the engine and let it run for just a minute just to confirm that it ran before you worked on it. :D
    Jim
  4. Jun 12, 2013 at 1:32 PM
    #1104
    Dizo
    Dizo Well-Known Member
    Oliver
    North of 62°, Canada
    2005 DCLB TRD Sport
    Aux Audio-input, 5100's @ 1.75", 2" Wheeler's AAL, LED Underhood Lighting, Anytime ABS-Off Switch,
    They *should* be changed cold, but if you're having difficulty getting your plugs out when it's cold, it's worth trying when the engine is warm to take advantage of expansion of heated metal to make them easier to remove. It's worth noting though that you SHOULD NOT reinstall plugs in a hot engine, as it will then contract and lock the plugs in. Instead, remove the plugs a few threads from the heated engine and wait for it to cool before pulling them out all the way and installing the new ones (leaving them in while you're waiting for it to cool just helps keep your cylinders clean :) ).
    If you're like me and replacing the plugs in your truck after a dealer did them many thousand miles ago and didn't use anti-seize, this method can be helpful.
  5. Jun 13, 2013 at 12:13 PM
    #1105
    T Fades
    Simi Valley, CA
    Good tip Dizo. Will see how difficult they are to remove.
    Is there any type of gasket on the plug that needs to be replaced? I know there is a gasket on the coil that contacts with the valve cover, but is there anything between the coil and plug? Do you guys replace the gasket on the coil as well?
  6. Jun 13, 2013 at 12:15 PM
    #1106
    Agent Smith
    Agent Smith Always outnumbered, never outgunned
    05 TRD Offroad Ivan Stewart Edition
    Toytec lift,FJ Anthracite wheels wrapped in BFG A/T 265/75/16's,WAAG Brush Guard, IPF 868's,sleeved fog lights
    No gasket between coil and plug, just reuse the coil gaskets. Just a crush washer between plug and block/head, new plugs have them already.
  7. Jun 13, 2013 at 12:23 PM
    #1107
    T Fades
    Simi Valley, CA
    Thanks Agent.
  8. Jun 13, 2013 at 12:24 PM
    #1108
    YOTA LOVER
    YOTA LOVER Stay Calm, and Fire For Effect
    NH
    2011 MGM Tacoma DCLB SR5
    A slew of pricey stuff my wife hates me for.
    Good write-up Chris! I got a little lost when you referred to things by their proper names. I'm more familiar with do-dads and whatchamacallits :D
  9. Jun 14, 2013 at 5:55 PM
    #1109
    WPDAWG11
    WPDAWG11 Well-Known Member
    Murfreesboro
    2005 4x4 5spd 4cyl
    Need suggestions
    Sorry I have been searching and cant find what the Gap needs to be on a 2005 2.7?
    Also there wouldnt happen to be a write up like this for the 2.7 :)
  10. Jun 14, 2013 at 6:02 PM
    #1110
    YOTA LOVER
    NH
    Prolly is, but it's all basically the same stuff only you're lucky enough to only have 4 plugs inline and less crap to move.
  11. Jun 14, 2013 at 6:41 PM
    #1111
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    gap needs to be .040"
  12. Jun 14, 2013 at 8:54 PM
    #1112
    WPDAWG11
    Murfreesboro
    2005 4x4 5spd 4cyl
    Need suggestions
    Yeah I just pulled off everything and I saw this. Pretty bad ass though I would rather move more crap and have a v6 lol
    Thank you!!
  13. Jun 14, 2013 at 9:22 PM
    #1113
    ruslanus
    ruslanus Well-Known Member
    Rus
    Wasilla, AK
    I just changed mine out at 68,000 for the first time. Way over due, but not too bad.
  14. Jun 14, 2013 at 11:09 PM
    #1114
    BenMara
    BenMara That Asian RedNeck
    Ben
    Belton, SC
    2011 DC 4x4 SCed
    TRD Blower, Ham Radio, DBA T2 Rotors
    Ok its almost time for me to do 30k maint, Anyone have a easy way to remove sparkplugs on driver side under the SCer? W/O removing the SCer?
  15. Jun 15, 2013 at 5:46 AM
    #1115
    ckeene9
    ckeene9 Well-Known Member
    Chesterfield, VA
    '12 DCSB Supercharged 4x4 TRD Sport
    See Build Thread
    Sub'd for this.
  16. Jun 15, 2013 at 3:48 PM
    #1116
    WPDAWG11
    Murfreesboro
    2005 4x4 5spd 4cyl
    Need suggestions
    Well changed them that was easy enough and switched out the miss fire coil #2 with #1. The maintenance required light is still flashing about 10 times but no codes are coming up on my reader. But I did disconnect the battery so it may take a bit. I guess if cylinder one missfires then it is the damned coil. When I did a ohms test on that coil the resistance was jumping around. How long yall think I can ride a bad coil?
  17. Jun 15, 2013 at 3:54 PM
    #1117
    YOTA LOVER
    NH
    Is it really worth waiting? You can ride all day on one less cylinder (start backfiring like a mother if the ecu keeps cycling the injector), but what's to be gained?
  18. Jun 15, 2013 at 4:01 PM
    #1118
    WPDAWG11
    Murfreesboro
    2005 4x4 5spd 4cyl
    Need suggestions
    Lol my happy ass is broke and arnt they like 90 bucks?:(
  19. Jun 15, 2013 at 5:00 PM
    #1119
    YOTA LOVER
    NH
    Junkyard/salvage has saved my hide many a time. Just takes a little phone and Internet time.
  20. Jun 15, 2013 at 5:51 PM
    #1120
    Brunes
    Brunes abides.
    Rotorhead
    Around
    60 and change from rockauto.com...
