How To: Spark Plug Change (1 GR-FE)
Discussion in 'Technical Chat' started by chris4x4, Mar 16, 2009.
  1. Jul 14, 2009 at 8:06 AM
    #101
    george3
    george3 Well-Known Member
    New Jersey
    2008 2.7 Manual Trans Tacoma
    Seat belt beeper, Cabelas (Weathertech) floor liner gray, Covercraft Seat Savers in Taupe, Protecta Heavy Duty Rubber Truck Bed Mat, Pop n Lock PL5200, Pace Edwards Full Metal JackRabbit, Wolverine oil pan heater, Scangauge2, afe pro dry s filter, Remote Underbody 4 Piece LED Light Kit (White) used as Bed light, DIY Washable Cabin Air Filter, PA15-TOY, 4x4 Illuminated Switch, full synthetic, Redline Tuning Hood Support, Smittybilt Nerf Steps black powder-coated
    Thanks.
  2. Aug 2, 2009 at 7:36 AM
    #102
    JoeSchmuck
    JoeSchmuck Well-Known Member
    Joe
    Virginia
    09 PreRunner SR5 2x4 O.R., Timberline Green
    Pop & Lock, Access LE Rollup Cover, Alpine PDX-5 Amp, Image Dynamics CS-6/CX-6 & 10" Sub
    Chris,
    First this is a very nice and well illustrated writeup. I don't even have 3K on my engine yet and itching to replace the plugs. I just love getting dirty I guess.
    I have a single question about the other bolts... Looks like some of these would require either a thread locker or anti-sieze compound. I know thread lockers normally inhibit against coorosion.
    -Joe
  3. Aug 2, 2009 at 7:37 AM
    #103
    chris4x4
    chris4x4 [OP] With sufficient thrust, pigs fly just fine. Moderator
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    No thread locker or anti sieze is needed on any other bolts. Anti Sieze for the plugs only. :)
  4. Aug 2, 2009 at 8:41 AM
    #104
    JoeSchmuck
    Joe
    Virginia
    Very well. Have a great weekend.
  5. Aug 2, 2009 at 8:59 AM
    #105
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
  6. Aug 4, 2009 at 9:26 PM
    #106
    JJ Customs
    JJ Customs Supreme Leader!
    Jay
    NV
    Sierra Denali Ultimate, 6.2
    A few additions to make me feel cool.
    So I was doing the 30k tuneup on the 4runner and since I have 23,500 on the truck I decided to do that one as well. I changed all the fluids last week and tonight decided to do the plugs. Thanks for a great writeup Chris. As always you do a great job taking the edge off all these projects. My plugs looked fine but had the Denso on the passenger side and NGK on the drivers. I used the NGK because that's what NAPA could get and I live in BFE! Overall it only took about an hour and I feel better knowing everything is up to date on my ride. Again, thanks for all the questions you answer and help you provide this site and its members Chris.
  7. Aug 5, 2009 at 6:06 AM
    #107
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Thanks, for the kind words, Buddy! Im glad to help. :)
  8. Aug 5, 2009 at 7:33 AM
    #108
    Bolster
    Bolster New Member
    Mexifornia
    2004 SR5 XCab
    Hi, new member here. Thanks for the excellent writeup.
    I am going to use your instructions for my 4-banger; I'm sure the process is similar except that the air intake is different.
    My question is about blowing compressed air into the spark plug wells. This isn't like yesteryear's engine, where accumulated dirt can blast off into the surrounding area, we're working in a well. Seems you'd just be moving dirt around in the well. Makes me wonder if blasting air down the well would just loosen the crud, but not get it out.
    Secondly, the top of the well is sealed with the coil unit. So how dirty would it get in there anyway? My concern is loosening dirt up but not getting it out. Would blasting with air be worse than just leaving it alone? I notice in your original write up you don't talk about an air blast.
    I think the vacuum route is probably best, but will need to modify my vacuum to get it breathing down a tube small enough to go down the plug well.
  9. Aug 5, 2009 at 7:46 AM
    #109
    george3
    New Jersey
    I would like to know what the diff is for the 2.7 when you find out. I have read all of Chris's write ups and they are excellent, but for the 6. Thanks
  10. Aug 5, 2009 at 8:54 AM
    #110
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    I personally dont blow air into the plug well anymore. No dirt should be in there, as it is sealed from the coil. :)
  11. Aug 5, 2009 at 8:54 AM
    #111
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    I would love to do some write ups on the 2.7, but I cant get any volunteers. Seems there are not alot of 2.7's on TW nearby. :(
  12. Aug 5, 2009 at 11:13 AM
    #112
    george3
    New Jersey
    I ordered the Haynes. I have 15m, when I hit 30m I'll change the plugs. I know Toyota says 100m but I'm old school and besides I don't want them to get welded to the block. Maybe I can write it up with some help on posting the pics in the write up. Thanks for all your help in the past Chris.
  13. Aug 5, 2009 at 11:23 AM
    #113
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Sounds good. Many folks on here can help with the pics. :)
  14. Aug 5, 2009 at 1:14 PM
    #114
    Bolster
    Bolster New Member
    Mexifornia
    2004 SR5 XCab
    Hi Guys. Yes, I'm new here, hope you don't mind if I "glom onto" this post. I wrote out the procedure I used to change the plugs in my 2004 2.4L, based on Chris' instructions, but modified for the little 4-banger. I put it into a PDF download to save some time.
    Lots of photos. You can download it here.
    Name of Delmar O'Donnell Bolster. Bona Fide Soggy Bottom Boy.
  15. Aug 8, 2009 at 1:48 PM
    #115
    BlueTaco
    BlueTaco Well-Known Member
    Long Beach, CA
    08 Tacoma Speedwayblue
    Thanks for the write up! this was so easy to do!
    PS On the drivers side spark plug (closest to the back) just above the top thread looked wet, the node itself was dry, could this be a sign of a problem?
  16. Aug 8, 2009 at 1:55 PM
    #116
    BlueTaco
    Long Beach, CA
    here it is, dont know if you can tell with the pic, but its wet on the dark ring area, i think it should be fine :notsure:
  17. Aug 8, 2009 at 3:48 PM
    #117
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    You should be fine. It looks damp, but not "Wet".
  18. Aug 8, 2009 at 5:21 PM
    #118
    BlueTaco
    Long Beach, CA
    thanks again chris =)
  19. Aug 8, 2009 at 6:04 PM
    #119
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Yw. :)
  20. Aug 8, 2009 at 6:06 PM
    #120
    george3
    New Jersey
    Thanks for the write up Bolster . I have a 2.7 and this is the first I have seen for the 2.7. The pics were clear and make the job easy. Thanks for your time and effort.
