How To: Spark Plug Change (1 GR-FE)
Discussion in 'Technical Chat' started by chris4x4, Mar 16, 2009.
  1. Oct 19, 2013 at 6:34 AM
    #1181
    JoeSchmuck
    JoeSchmuck Well-Known Member
    Joe
    Virginia
    09 PreRunner SR5 2x4 O.R., Timberline Green
    Pop & Lock, Access LE Rollup Cover, Alpine PDX-5 Amp, Image Dynamics CS-6/CX-6 & 10" Sub
    Has anyone looked into the difference between the reason for NGK on one side and Denso's on the other? I was thinking maybe it has to do with indexing of the ground electrode. I plan to mark the plugs before I remove them to see if it is indexing.
    The steps will be:
    1) Using a sharpie mark all the plugs, preferably the upper part.
    2) Remove the plugs.
    3) Compare the plugs to see if the ground electrodes are pointing in the same general direction. If they are all over the place, well indexing isn't being used.
    4) If the electrode grounds are roughly 180 degrees out between the two plug types then it looks like indexing is the reason for the different plug types. I would also install one plug from the drivers side into the passenger side to verify the mark I had made is roughly 180 degrees out.
    I'm approaching 50K on my truck and looking into purchasing some plugs in a few weeks and will be cleaning the MAF and Throttle Body at the same time while things are taken apart.
  2. Oct 19, 2013 at 6:57 AM
    #1182
    chris4x4
    chris4x4 [OP] With sufficient thrust, pigs fly just fine. Moderator
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Indexing the plugs is moot in these, and most 4 valve heads.
  3. Oct 19, 2013 at 7:14 AM
    #1183
    JoeSchmuck
    Joe
    Virginia
    That may be true but I'm still curious if that is the reason for the different plugs since I've never seen an answer other than Toyota has to buy both brands by law, or something odd like that.
  4. Oct 19, 2013 at 7:20 AM
    #1184
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    I've searched for a reason for this since 2002. Can't get a defined reason.
  5. Oct 19, 2013 at 8:00 AM
    #1185
    JoeSchmuck
    Joe
    Virginia
    I'll post the results either way so you will know if indexing might be the reason or it blatantly is not. And as you said, it may not make a difference in this type of engine but it doesn't hurt to look into it.
    I just ordered my six Denso plugs, couldn't believe the shipping cost almost as much as the plugs but that is the way the internet sellers bring you in. One place the shipping was a buck more than the plugs. And the local dealership would have cost me more. So $36.61 delivered isn't bad at all.
  6. Oct 19, 2013 at 8:01 AM
    #1186
    Justus
    Justus fucks not given
    Nabisco the kid
    In ur toolbox
    stockish
    If it was significant, I believe parts counter would make a killing by selling 1 plug cheap and hike the price of the other plugs.
    Instead I always get a box of denso, never a problem.
    Unlike the older z24 engine in my Nissan yrs ago..... Crazy plug times.
  7. Oct 19, 2013 at 8:02 AM
    #1187
    Justus
    Nabisco the kid
    In ur toolbox
    stockish
    Take the parts guys lunch once in awhile ;)
  8. Oct 19, 2013 at 8:08 AM
    #1188
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    I have experimented with indexing plugs for many years.yeah it doesn't seem to have any impact in the slightest except on carburated or throttle body injected engines, with inefficient 2 Valve heads.
  9. Oct 20, 2013 at 8:23 AM
    #1189
    JimROCDS
    JimROCDS Well-Known Member
    Jim
    Massachusetts
    Tacoma
    For all we know, it was merely a business decision based on inventories of the types of plugs.
    Jim
  10. Oct 20, 2013 at 8:57 AM
    #1190
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    One thing a friend of mine mentioned, was a possible difference in resistance of the 2 different plugs. I haven't gotten a chance to test this, but if anyone in the metro Phoenix area has a set of NGK's, and Denso (both OEM) let me know. New or used doesn't matter.
  11. Oct 21, 2013 at 11:19 PM
    #1191
    LocoTaco
    LocoTaco Well-Known Member
    Don
    Central Washington
    09 SR5 TRD Sport
  12. Oct 27, 2013 at 8:38 PM
    #1192
    itsky
    itsky Member
    Thanks for the write up, I'm at 90k now on my 4runner now and for the third time I've come back to this article for a guide. Appreciate the effort.
  13. Nov 13, 2013 at 9:52 AM
    #1193
    robu
    robu Well-Known Member
    Rob1224
    Cottonwood, AZ
    TRD sport debadged
    kings front and rear 3" expedition deaver pack 700lbs in front. lighted 4x4 switch and fixed temp console
    Just got done doing mine with my son helping. little over an hour and all buttoned up. thanks for the great write up!
  14. Nov 18, 2013 at 4:43 PM
    #1194
    empty hull
    empty hull Active Member
    Tim
    Baton Rouge, La
    Prerunner V6 SR5 TRD Off Road
    I think it was like the Twix commercial with which side is better! Lol. Tim
  15. Nov 18, 2013 at 7:33 PM
    #1195
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    Lol :thumbsup: best explanation yet.
  16. Nov 25, 2013 at 8:29 PM
    #1196
    Ryan07
    Ryan07 Well-Known Member
    New Brunswick
    07 TRD DC,LB Sport 4x4
    Icon Ext. Coilovers, LR UCA's, Icon AAL, Nitro 9000 Shocks, 7"Kragen HID's/Billet Grille, Extang Solid Fold Tonneau Cover, Bed Lights, Diff Breather Mod, D-Rings Mod, LED Interior Lighting/Plate Lights, LED 4X4 Switch, Viper Starter, AVH-P4200DVD, PAC Interface, OEM Backup Camera/Pop&lock, Wet Okole Seat Covers, Weathertech Mats, Husky Mud Flaps, 8000lbs Champion Winch/Winch Cradle and Quick Connect Kit, 4,500lbs Champion Winch/Front Hidden Winch Mount, OEM Painted Rims, Spidertrax 1.25, 265/70R17 BFG KO's
    Changed my plugs today, thanks Chris. :cheers:
  17. Nov 25, 2013 at 9:50 PM
    #1197
    mehrmj
    mehrmj New Member
    08 TRD Off Road
    Thanks, Chris. Would have probably taken a lot more off on the left side of the motor that wasn't necessary. Great post.
  18. Nov 27, 2013 at 2:44 PM
    #1198
    NicP
    NicP Well-Known Member
    Nic
    colorado
    05 DC LB
    3" Icon CO Icon Rez and AAL ProComp 7089 BFG 285 AT KO
    Thanks Chris. Plugs and throttle body cleaning done.
    Some additional suggestions for plug change
    --as shown in the tutorial- electric tape on the extensions and sockets always helps
    --drivers side use longer extensions and universals to clear manifold and other items that make that side difficult.
    --if you don't have a compressor to blow foreign material away from the coils use can of compressed air BEFORE you remove the plugs.
    --sometimes plugs stick too much to the rubber grommet in sparkplug sockets . use silicon spray or other mild lubricant so plug will release from socket.
    otherwise great help in showing what to do by Chris again. Rep
  19. Dec 17, 2013 at 5:30 PM
    #1199
    dalesrn
    dalesrn Tacoma TSS
    Dale
    Southeast Louisiana
    2008 Tacoma PreRunner DC with TSS Package
    Borla exhaust system, Sirius Satellite Radio, Chrome package, Trailer Hitch, Clazzio Leather seat covers, TSS badging, Anytime on fog lights mod, Daytime driving lights mod, Dual backseat DVD players w/monitors, 3rd Brake Light "TSS" mod, Bed pocket lights mod, Seat belt chime mod, Bed storage compartment auxillary outlet mod, Shorty antenna, Armor Lid Tonneau Cover, Line of Fire tailgate light
    Do these plugs look normal for ~35k miles (70k miles on engine) on them?
    Sorry for the pics being sideways. Took these on iPhone...enough said.
  20. Dec 17, 2013 at 5:37 PM
    #1200
    BenMara
    BenMara That Asian RedNeck
    Ben
    Belton, SC
    2011 DC 4x4 SCed
    TRD Blower, Ham Radio, DBA T2 Rotors
