How To: Spark Plug Change (1 GR-FE)
Discussion in 'Technical Chat' started by chris4x4, Mar 16, 2009.
  1. Feb 10, 2014 at 3:59 PM
    #1261
    ToyTaco09
    ToyTaco09 Well-Known Member
    Texas
    09 TRD Sport DC
    Changed my plugs yesterday (first time at 60k miles) and notice such an improvement in how the truck drives. My scanguage is already showing 1.5-2 mpg improvement. Thanks for an awesome "how to" thread. I wouldn't have attempted this if it wasn't for this write up. The dealer wanted $300 for parts and labor. I did it under $50. Thanks again!
    One piece of advice for any other newbie doing this: When you tape the socket to the extension bar, make sure you tape it really good. I got it stuck down in the first plug. Took a while to get it out. I made sure it wouldn't happen again.
  2. Feb 15, 2014 at 9:56 AM
    #1262
    knayrb
    knayrb Well-Known Member
    Bryan
    Somewhere in the square states
    2010 Dbl-Cab Off-Road
    Pure stock
    Just had to say thanks for the tutorial. Got it done without a hitch at 66K miles.
    First change dealer at ~30K $$$.
    All old plugs were at .48-.50
    All new plugs are at .40 at 40 degrees outside
    Took half hour on passenger side
    Took one hour on drivers side
    Got to use my new inch-pound torque wrench as a bonus.
    Thanks Chris and others.
  3. Feb 21, 2014 at 8:37 AM
    #1263
    VinTaco
    VinTaco Well-Known Member
    Burnaby bc
    2016 Black Tacoma TRD OR
    Why is it that many vehicles have plugs that last around 60,000 miles plus and on a Tacoma you are having to change them a lot earlier.??
  4. Feb 22, 2014 at 6:45 AM
    #1264
    JimROCDS
    JimROCDS Well-Known Member
    Jim
    Massachusetts
    Tacoma
    From what my mechanic told me, they're all going over to 30,000 mile change of spark plugs. With the 100,000 mile plug change, people thought there was no maintenance necessary beforehand.
    But mostly, it avoids the pit falls of trying to remove plugs that are seized because they are so old.
    Jim
  5. Feb 22, 2014 at 6:54 AM
    #1265
    chris4x4
    chris4x4 [OP] With sufficient thrust, pigs fly just fine. Moderator
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Manufactures try to have a "Low maintenance" schedule, and "Low cost of ownership" to appeal to the buying public. One way of doing this, is to extended plug change intervals.
    TacomaCZman likes this.
  6. Feb 22, 2014 at 9:40 AM
    #1266
    dexterdog
    dexterdog My pee parts itch
    Oly WA
    2012 F150
    +2. I am also dreading the day that I have to change out the iridium plugs on my wife's Highlander. The transverse mounted 3.5 requires the front cowl to be removed as well as a host of other parts to get to the back three cylinders. Allot of beer will be consumed that weekend.
  7. Feb 23, 2014 at 1:21 PM
    #1267
    carcharias
    carcharias Giggiddy what what
    Los Angeles, CA
    SOLD: '11 AC MGM OR
    Kings all-around w/ 700lb coils, Dakar leaf pack, TC uca's, DO single hoop bumper, BAMF bolt-on sliders w/ kickouts, Rigid 20" e-series spot/flood, aFe pro-dry, BFG KM2 255/85/16, silver TRD FJ wheels, WARN M8000-s, Access LE, Grillcraft, BAMF lightbar, BAMF rear dif skid, BAMF LCA skids, window tint, Wet Okoles, WeatherTech floorliners, Silverstar lights, led dome lights, Redline Tuning hood struts, center console lock mod, mag-lite mod, extra d-rings, re-routed exhaust, ATO skids, ATO Hi-Lift mounts, pipe tailgate lock, seatbelt alarm delete, wheel/spare locks, Viper 5901, LoJack... WISHLIST: a golden canary that poops platinum
    DONE!! First time, too! Woohoo! Very easy, aside from a stuck bolt on the bracket and that forward driver's side plug. Had to unbolt an extra wire harness to get in there more easily. The used spark plugs finished gapped between .050 and .055. Gapped new ones at .041. Thanks for the tutorial!
  8. Feb 28, 2014 at 8:44 AM
    #1268
    VinTaco
    Burnaby bc
    Should plugs be replaced with original plugs or is there a better plug that would actually make a difference..??
  9. Feb 28, 2014 at 8:51 AM
    #1269
    carcharias
    Los Angeles, CA
    SOLD: '11 AC MGM OR
    I bought them from a Toyota dealer. Think all 6 were about $22. Did that because I remember reading a thread here that ultimately said one spark plug isn't any better than another spark plug.
  10. Mar 1, 2014 at 6:46 AM
    #1270
    VinTaco
    Burnaby bc
    Well that makes it simple.. thanks.. Did you use the same plug on both sides,..?? Is there a reason why some have 1 type of plug on 1 side and another on the other side.??
  11. Mar 1, 2014 at 7:44 AM
    #1271
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Use the same plug. Only speculation as to why Toyota uses 2 different plugs. The Denso's hold gap longer than the NGK in these trucks, so stick with them.
  12. Mar 1, 2014 at 7:47 AM
    #1272
    carcharias
    Los Angeles, CA
    SOLD: '11 AC MGM OR
    Naw, I just threw them all in. According to the OP there's no rhyme or reason behind the two different OEM plugs. My truck hasn't noticed.
    EDIT: Chris beat me to it! heheh
  13. Mar 2, 2014 at 5:06 AM
    #1273
    VinTaco
    Burnaby bc
    Thanks for the info.. How long would you keep the Denso`s before changing them.. ( Mileage.)
  14. Mar 2, 2014 at 8:31 AM
    #1274
    VinTaco
    Burnaby bc
    What kind of mileage will you get out of the Denso`s before you change them..??
  15. Mar 2, 2014 at 8:32 AM
    #1275
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    I change at 30k.
  16. Mar 3, 2014 at 7:42 AM
    #1276
    VinTaco
    Burnaby bc
    Thanks Chris
  17. Mar 3, 2014 at 8:01 AM
    #1277
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    If I used ngk change them sooner or pull and regap them?
  18. Mar 9, 2014 at 2:23 PM
    #1278
    TX Graywolf
    TX Graywolf Member
    J
    DFW
    08 PreRunner SR5 TRD Sport
    Thanks Chris4x4 for the great write up and to all the other comments. The tips and tricks made this much easier. Bought my truck new and thought it had iridium plugs like my former truck. After reading you article, with 107,000, it was time to change. The Denso were up to .057-58 and the NKGs were up to .063. I replaced with the Denso copper (from NAPA-in stock) after reading all the responses. It still ran fine but I can feel the additional pep now. Cleaned the MAS while in there.
    This my first post and I want to thank all who contribute. More work ahead!
  19. Mar 9, 2014 at 6:42 PM
    #1279
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Just get the Denso's
    Welcome to TW!
  20. Mar 15, 2014 at 12:39 PM
    #1280
    Pushincaskets
    Pushincaskets Well-Known Member
    High Point, NC
    07 PreRunner DCSB
    4" Maxtrac Spindles, Dakars and extra leaf, SOS Concepts bed rack, Lund tonneau cover, RTT,
    Great write up!
    Just completed first time change 92,235, truck had been running pretty good gas mileage was ok about 16-17 around town I have no other mods. Plugs came out no problem. Passenger side Densos were 0.50-0.52 gap, driver side NGK were 0.59-0.61. Replaced with Denso copper plugs.
