How To: Spark Plug Change (1 GR-FE)
Discussion in 'Technical Chat' started by chris4x4, Mar 16, 2009.
  1. Jan 23, 2015 at 8:34 PM
    #1501
    chris4x4
    chris4x4 [OP] With sufficient thrust, pigs fly just fine. Moderator
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Cyl. #2. was the issue, and he tried 2 plugs.
  2. Jan 23, 2015 at 8:54 PM
    #1502
    replica9000
    replica9000 Das ist no bueno
    Lake Chargoggagoggmanchauggagoggchaubunagungamaugg
    2019 T4R ORP
    Maybe there was more than 1 bum plug in there?. :notsure: I've seen videos. It happens.
  3. Jan 24, 2015 at 5:32 AM
    #1503
    NutZac
    NutZac Active Member
    Zach
    Long Island
    13 TRD Sport
    UltraGauge K&N AirFilter Weathertech Floor Liners BakFlip G2
    I would assume there is a misfire sensor on each cylinder not just for the left and right bank of cylinders. As I pulled each plug out I re-checked the gap on them. Nothing changed but the electrode started to change that bluish color. The #2 cylinder never did with either plug. I did change them out twice with new ones so they wouldn't have had the chance to heat up as much, but every other cylinder was firing.
  4. Jan 24, 2015 at 5:35 AM
    #1504
    replica9000
    2019 T4R ORP
    Odd. If you do have Toyota do it, ask them if they had any issues. I'm curious to find out what the issue is.
  5. Jan 24, 2015 at 5:41 AM
    #1505
    NutZac
    Zach
    Long Island
    13 TRD Sport
    I absolutely will. Thanks for all the help and insight dudes!!!
  6. Jan 25, 2015 at 12:15 PM
    #1506
    00PowderSpecial
    00PowderSpecial Well-Known Member
    Chad
    Newfoundland, Canada
    09 TRD DC
    Thanks so much for the write up, made it a breeze! It was my first time and have been putting it off for sometime but I had 164000 Kim's on my 09 and it had the Denso NGK combo so they must have been original. They looked okay but the gap was .070 on the denso and .065 on the NGK. Hopefully fuel mileage improves some.
  7. Jan 28, 2015 at 5:06 PM
    #1507
    DolphinJohn
    DolphinJohn Well-Known Member
    Nature Coast, FL
    '13 Access Cab 4x4 SR5
    I just did my '13 with 32,000 miles this afternoon. Great write-up, made it super easy.
    I don't know if it has been covered but on my truck it was easier to just unsnap the filter housing then disconnect it from the inlet hose. That gave me enough room. There was a bunch of stuff covering one of the bolts to remove the whole intake hose assembly.
    My Densos were at about .045 and the NGKs were at close to .050.
    I set my new Densos to .040-.041
    Runs great.
  8. Feb 2, 2015 at 12:23 AM
    #1508
    CrazyMike
    CrazyMike Member
    Canada , Aldergrove
    08 Tacoma Sr5
    I just did my too . First time at 75000 km , they looked good with gap about 0.065-0.0070" . Hopefully fuel mileage improves too .:)
  9. Feb 2, 2015 at 8:49 AM
    #1509
    ryanbitt
    ryanbitt Wherever you go...there you are.
    Hutto TX
    07 DCLB 4x4
    Wouldn't you like to know!
    Just did mine this weekend! Took about 2.5 hrs with breaks. Although I found out the truck had the stock plugs in it because the driver side was NGK's. Dealer had told me when I bought it that it had a tune up recently at 60K miles. (guess that was a big fat lie) sad to say I waited waaaayyy to long to change these as I noticed the old plugs were all fudged up. Now I know what to do so it shouldn't take more than an hour or so next time. Great write up!
  10. Feb 7, 2015 at 9:49 AM
    #1510
    robre
    robre New Member
    Rob
    Pennsylvania
    06 trd sport
    Glad I READ YOUR WRITE UP! I didn't think it would take that long. Thanks for posting the tools needed also.
  11. Feb 9, 2015 at 9:00 PM
    #1511
    unk
    unk Well-Known Member
    San Jose
    2017 TRD OFFROAD
    FOX 2.5 Factory Coilovers w/resi DSC @fox ———————————————- Camburg Kinetik Series Upper Billet Control Arms @camburgracing ——————————————— FOX 2.5 Factory Shocks w/resi DSC @fox ——————————————— Icon Vehicle Dynamics AAL @ivdsuspension ——————————————— Baja Designs Squadron-R amber fog light kit @bajadesignsofficial ——————————————— RCI Bed Rack @rcioffroad ——————————————— Tepui KUKENAM 4 XL Ruggedized @tepui
    Great write-up, took me about an hr to do. I did get a check engine light the next day. Checked and the VSV plug was still disconnected. Anything I should be worried about? Drove about 20 miles with no performance issues.
  12. Feb 10, 2015 at 9:06 AM
    #1512
    NutZac
    Zach
    Long Island
    13 TRD Sport
    Hey All...
    So I went to Toyota to have them change the plugs for me. I went down and spoke to the tech who worked on my truck, even though he wasn't that friendly (even after a $10 tip) we spoke for a minute. He said that he's never seen that issue before and there could be a chance that I had two bad plugs. To me that seem like a BS excuse. I even went back and checked my torque wrench, the gap in the plugs and anything else I could think of. I have no clue and I'm lost. I guess in another 30k miles ill see again when I go back to change them!!
    Just wanted to say thank you again to Chris4x4, dude you kept me sane through the troubleshooting, even when it was 15 degrees outside!!
  13. Feb 20, 2015 at 9:25 PM
    #1513
    DoubleB
    DoubleB Well-Known Member
    Bakersfield CA
    22 TRD Pro / 06 PreRunner
    Thanks for the excellent write up! Just changed out my plugs tonight. Truck is an '06 wtih 112K on it. The plugs looked great except for the large gap, well over 0.05. I struggled a little with the driver side front getting the coil plugged back in, but was able to get it connected with a little patience and some wiggling. I also cleaned the throttle body, MAF, new air filter, cabin filter, and changed out the diff fluid. Truck is running great. Good to go for a few more years!! Thanks again Chris4X4!
  14. Feb 20, 2015 at 10:03 PM
    #1514
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Great to hear! :)
  15. Feb 25, 2015 at 5:00 PM
    #1515
    amati5
    amati5 Well-Known Member
    2010 Prerunner TRD
    I read the write up but not all the posts. Do we need to use dielectrics grease on the end of the plugs?
    thx
  16. Feb 25, 2015 at 5:13 PM
    #1516
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    YOu don't have to, but its a good idea.
  17. Feb 25, 2015 at 5:22 PM
    #1517
    amati5
    2010 Prerunner TRD
  18. Mar 1, 2015 at 12:32 PM
    #1518
    MyToyTaco
    MyToyTaco ╒╪╕
    Nick
    wenatchee, wa
    09 DCLB 4x4
    Just changed mine. Pulled out ngk's & densos. 115k miles.
  19. Mar 2, 2015 at 9:24 AM
    #1519
    Lpheat22
    Lpheat22 Well-Known Member
    Albert
    La Puente, SGV
    09 PreRunner SR5 DCSB Sport
    DDM Tuning 6000k HID Headlights, Pioneer X5500BHS, CSJumper switchbacks, Fox 2.5 w/reservoirs and CDC adjusters, Sick Nick PreRunner Tube Bumper, 17 in SCS Stealth 6's Matte Gunmetal, Toyo ATII 285/70/17
    So I'll be doing this probably saturday but do I have to change the harnesses also? I'm at 101xxxx miles so just curious. This is the first time I've changed my plugs (I know bad owner). The write up looks simple even hopefully it'll go smooth.
  20. Mar 2, 2015 at 9:51 AM
    #1520
    MyToyTaco
    MyToyTaco ╒╪╕
    Nick
    wenatchee, wa
    09 DCLB 4x4
    You shouldn't need to
