How To: Spark Plug Change (1 GR-FE)
Discussion in 'Technical Chat' started by chris4x4, Mar 16, 2009.
  1. Sep 12, 2009 at 9:49 PM
    #141
    RelentlessFab
    RelentlessFab Eric @Relentless Fab Vendor
    Eric
    Sparks, NV
    07 AC 6mt>03 SR5 >08 Sport and 17 6MT TRD OR
    Yep. One of those goofy things toyota does apparently.:confused:
  2. Sep 20, 2009 at 5:39 PM
    #142
    linkfeeney
    linkfeeney Well-Known Member
    link the stink!
    Sewell, NJ Eh!
    09 Doublecab TRD Off-Road! Magnetic Grey!
    on putting back the coil pack... do I need to put a little bit of grease/lube on it so it won't stick later on? I remembered i had to do that on my wire plug on my old altima.
  3. Sep 20, 2009 at 5:40 PM
    #143
    chris4x4
    chris4x4 [OP] With sufficient thrust, pigs fly just fine. Moderator
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    I never have.
  4. Sep 21, 2009 at 3:00 AM
    #144
    JoeSchmuck
    JoeSchmuck Well-Known Member
    Joe
    Virginia
    09 PreRunner SR5 2x4 O.R., Timberline Green
    Pop & Lock, Access LE Rollup Cover, Alpine PDX-5 Amp, Image Dynamics CS-6/CX-6 & 10" Sub
    This is not regular grease or lube, it's dilectric grease. Just a little dab will do ya if you use it. Do not fill the boot, place some on the top electrode of the spark plug and it will prevent corrosion and the parts sticking together.
    It's not required but if you are in really humid conditions it's not a bad idea.
    -Joe
  5. Sep 21, 2009 at 12:34 PM
    #145
    Crom
    Crom Super-Deluxe Member
    Nick
    San Diego, CA
    2009 4x4 DCSB Camp Supreme
    Millions
    Chris, Thanks for writing this up. Very informative and I'm sure I"ll reference it when it's time to swap my plugs out.
  6. Sep 21, 2009 at 1:42 PM
    #146
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
  7. Sep 29, 2009 at 5:28 PM
    #147
    DriverSound
    DriverSound Señor Member
    Oregon
    2015 DCSB OR 4x4
    Too few to list.
    AlCapwn likes this.
  8. Sep 29, 2009 at 5:33 PM
    #148
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Yes. Thats Milimeters. .15 mm is 0.0059 inches. WELL within spec at 30,000 miles if gapped at .040 inches.
  9. Sep 29, 2009 at 5:34 PM
    #149
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    It also says:
    I have found the gap for the Denso plugs in the 1GR-FE only grow to around .048 @ 30,000 miles.
  10. Oct 5, 2009 at 11:40 AM
    #150
    DriverSound
    Oregon
    2015 DCSB OR 4x4
    Too few to list.
    I seemed to miss the mm part for wear on the gaps. Thanks Chris, you're always a wealth of knowledge!
    Btw, do you recommend the plugs being gapped at .040 or .043?
  11. Oct 5, 2009 at 11:42 AM
    #151
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    I gap mine at .040 to .041. :)
  12. Oct 5, 2009 at 11:49 AM
    #152
    trdracing5
    trdracing5 Well-Known Member
    Elizabeth City, NC
    2003 Tacoma SR5
    Ok just replaced my plugs this weekend with the help of this thread. Great instructions. Even an idiot like me could follow them.:)
    The good thing was I replaced the sparkplugs the bad thing was the plugs that were in there looked brand new and were gapped correctly (right at .040 for all 6) so they didn't really need to be replaced.
    Since I bought the truck used (had 36,000 miles) I was not sure if they had been changed but since they were all Denso's I assume that they got changed at the 30,000 mile mark like they were supposed to.
    Oh well it was good practice and I had a good excuse to buy a new ratchet extension and spark plug socket.
  13. Oct 5, 2009 at 12:01 PM
    #153
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Its always better to be safe. :) Congrates on the new tool, and a job well done. :)
  14. Oct 9, 2009 at 6:04 AM
    #154
    KevinOK
    KevinOK Member
    I'm not sure why all the headache for iridium plugs when Toyota puts them stock in at least one of their engines. Toyota sets up their ECM's to accept the heat ranges and fire rates for both stock copper and iridium, according to dealership.
    I went ahead and installed the OEM iridium's in my 06 tacoma, took maybe 1 hour and really basic.
    I know the Toyota service department guys I talked to recommended them based on their experience for whatever that is worth.
    According to Denso and NGK the iridium plugs will last longer and be more economical. I do know I've ran NGK iridiums for many years in my ATV's and nothing compares on a really cold day.
    I will report back here in a few fill ups to see how my milage is going as I track it every single tank.
    For the record my 06 has 60K miles, first plug change and the stock ones looked great, I had assumed my tacoma came with iridium as it stated in the owners manual, though upon closer inspection the engine type was not mine, my oversight.
    The down side on iridium is they are expensive and if better fuel economy is not achieved then next change I will go back to the stock copper based.
  15. Oct 9, 2009 at 6:10 AM
    #155
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Your not gonna get better mpg. I have tried this myself and found it to be slightly less.
  16. Oct 11, 2009 at 7:59 PM
    #156
    outlawtacoma
    outlawtacoma Well-Known Member
    W. TN
    2018 T4RTRDOR
    thanks chris4x4 for this write up. I changed mine Friday. man a couple of those on the driver side are a pain. but with two 6 in extensions its manageable.
  17. Oct 11, 2009 at 8:09 PM
    #157
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Yeah, it gets tight on that side. Good to hear you got it. :)
  18. Oct 12, 2009 at 3:14 AM
    #158
    linkfeeney
    link the stink!
    Sewell, NJ Eh!
    how about a 10 inch? would that work too?
  19. Oct 13, 2009 at 5:42 PM
    #159
    outlawtacoma
    W. TN
    2018 T4RTRDOR
    yeah a 10 inch would work but I dont have one, I have 2 6's, so I snapped em together and wahlah
  20. Oct 14, 2009 at 3:59 AM
    #160
    Ridingontrd
    Ridingontrd Well-Known Member
    Richard
    Laughlin,N.V
    trd sport 4x4 w/towpkg
    aFe prodry,Dynomax ultra flo ss,Scangauge2,Demello front bumper,BudBuilt skids,sliders(local)AllPro rear bumper,Wet O's cobalt blu,w/halfpiping,TRD logo in gold,R/L hood struts,5150's@10"aal 3 pack,T/C uca,Light racing c/o,1"diff.drop,de-badged,
    Thanks for the info.I just hit 30K today.Waiting for the plugs to come in.
