How To: Spark Plug Change (1 GR-FE)
Discussion in 'Technical Chat' started by chris4x4, Mar 16, 2009.
  1. Jan 11, 2016 at 11:56 AM
    #1661
    JUJtacoma2010
    JUJtacoma2010 Well-Known Member
    Fresno
    Tacoma 2010 Dbl Cab. OFF Road Package
    runs smooth yes. No parts left over. yes I put the anitseize and yes torque them. its run smooth. and no hickups or engine light
    JimboAnz likes this.
  2. Jan 11, 2016 at 4:39 PM
    #1662
    Revelations
    Revelations Well-Known Member
    2014 MGM DCSB
    Or a spark plug socket.
  3. Jan 11, 2016 at 4:45 PM
    #1663
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    Try this on a transverse V6 (any one of the 800,000 or so Camrys, Accords, or Altimas sold every year). Those plugs on the rear cylinder bank facing the firewall... :devil: The Tacoma is still relatively easy to work on by today's standards (and waaay easier than the modern Duramax or Powerstroke diesels, where cab removal for engine work is common).
  4. Jan 11, 2016 at 5:01 PM
    #1664
    KenLyns
    Belly of the Beast
    ^If you are just turning the extension by hand, without a ratchet handle for leverage, there is very distinct and positive feel when the plug has bottomed, especially if there's antiseize on the threads. Did this with my truck and my mower (aluminum head), no issues.
    DoorDing likes this.
  5. Jan 11, 2016 at 9:52 PM
    #1665
    Revelations
    2014 MGM DCSB
    Exactly. i always carefully insert and thread by hand. If there's any doubt at all, I remove it and inspect the threads before putting it back in.
  6. Jan 12, 2016 at 9:00 AM
    #1666
    JUJtacoma2010
    Fresno
    so how do I use a piece of hose?
  7. Jan 16, 2016 at 7:36 PM
    #1667
    whiskeytacos
    whiskeytacos Well-Known Member
    New York
    '14 DCSB Off Road MGM
    OME 886 springs on 90000 struts Total Chaos UCA OME Dakar + AAL energy suspension steering rack and sway bar bushings SCS SR8 wheels Cooper ST Maxx 285/85r16 Pelfreybilt IFS skid plate Pelfreybilt hidden winch mount broken ass winch Softopper All Pro Off Road OTT pack rack
    Took me about an hour tonight, very easy. Thanks for the great write up. As for removing the intake hose, I just removed the part that holds the air filter and left the hose in place, working around it. definitely saved time there and it truly didn't impede my work.
    Also, I noticed the NGK plugs were far more worn than the Denso plugs. So weird that they use two at the factory. The NGK plugs were now gapped to an average of .055" where the Densos were at around .042-45 after 33k miles
  8. Jan 17, 2016 at 9:15 PM
    #1668
    930dreamer
    930dreamer Well-Known Member
    04 Tacoma Prerunner
    Not 100% sure if this is the correct thread to ask this question?
    04 Prerunner 2.7l, I can't get the #2 plug out, in fact I broke an extension trying to remove it. So now I have the socket with the broken end of the extension stuck in the valve cover. :(
  9. Jan 17, 2016 at 9:29 PM
    #1669
    930dreamer
    04 Tacoma Prerunner
    My two hands and the 3/8" drive extension "was" a vintage Bonney. I'm very worried the head is/will be damaged.
  10. Jan 17, 2016 at 9:42 PM
    #1670
    930dreamer
    04 Tacoma Prerunner
    With the broken extension end in the socket I can't get it with anything as of yet. Monday I'll look for a stronger magnet, maybe with a longer pair of needle nose pliers.
  11. Jan 20, 2016 at 1:52 PM
    #1671
    Mariotaco
    Mariotaco Well-Known Member
    Mario
    El Paso, Texas
    11 SR5 4x4
    Why do you need different sizes of the 10mm socket?
  12. Jan 20, 2016 at 1:58 PM
    #1672
    frizbal
    frizbal Well-Known Member
    Sean
    Tulsa, Oklahoma
    2012 TRD Off-Road
    You need a left turn and a right turn one
  13. Jan 20, 2016 at 2:01 PM
    #1673
    Mariotaco
    Mario
    El Paso, Texas
    11 SR5 4x4
    Are you trolling? He said "10mm socket (3/8" and 1/4")"
    chris4x4[OP] likes this.
  14. Jan 20, 2016 at 5:41 PM
    #1674
    Bobcape
    Bobcape Well-Known Member
    Bob
    Black Hills, SD
    2013 DCLB SR-5
    Question for you all. I changed my plugs two weekends ago at 34K. First change. Indeed there were two different brands installed. I also changed my front and rear diff and transfer case fluids with Royal Purple. Everything went well. Great info here. I have been running an Ultragauge for more than a year and constantly watch my MPG. Whether the gauge is accurate or not I'm not 100% sure, but it is consistent for me. In town I average 15.8 and interstate driving I average 18.7 for the last year.
    After changing the plugs and fluids my MPG has gone down slightly. The last two weeks in town have averaged only 14.9 and a 4 hour interstate trip averaged only 16.9. I used Denso K20HR-U11 plugs gapped at .040". My rolling resistance has reduced. There's a long hill I travel often. Before changing my fluids, as a test, I put it in neutral and coasted down it. It very gradually reduced speed before the fluid change. After the change, I now gradually increase speed on the same stretch. The engine runs very smoothly at idle (I believe a little bit smoother) and during acceleration. I only checked two of the old plugs and they were .048" and .049". They looked fine.
    It will be 3 weeks this Saturday since I changed everything. I don't believe there's anything wrong with the plug change but I'm wondering if anyone else has had similar results? I was hoping for an increase in MPG. Thanks for your replies.
    Bob
  15. Jan 20, 2016 at 5:47 PM
    #1675
    Bobcape
    Bob
    Black Hills, SD
    2013 DCLB SR-5
    BTW - I'm elk hunting this week and am driving a lot in 4WD in snow on Forest Service roads in WY. (I'm not factoring these miles into the average above.) But I notice a big difference in 4WD since the fluid change. Much less start-from-stop and coasting resistance. I'm glad I got it changed before this trip.
    Bob
  16. Jan 20, 2016 at 6:45 PM
    #1676
    chris4x4
    chris4x4 [OP] With sufficient thrust, pigs fly just fine. Moderator
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    This ^^^^. Its easier to use a small wrench in some places.
  17. Jan 20, 2016 at 6:55 PM
    #1677
    frizbal
    Sean
    Tulsa, Oklahoma
    2012 TRD Off-Road
    Hey, I thought it was funny
  18. Jan 21, 2016 at 5:44 AM
    #1678
    simplehuman
    simplehuman Well-Known Member
    I'm probably not as experienced as most of the owners on here, but maybe the fluids need time to break in? :notsure: I'm interested to see what other have to sa, too.:popcorn:
  19. Jan 21, 2016 at 7:08 AM
    #1679
    Revelations
    2014 MGM DCSB
    Bob,
    You may consider opening the gap to .043 (max recommended range). A larger gap should increase the burn efficiency in the engine, provided your coils are working properly. Plugs gapped too small cause incomplete burn resulting in loss of mpg. Given that your factory plugs are gapped much wider than spec and the plugs were in good condition (according to your post), I wonder if the FSM needs an update? I went with iridium plugs and gained back a good amount of mpg. They're pre-gapped and are working great.
  20. Jan 21, 2016 at 7:09 AM
    #1680
    Revelations
    2014 MGM DCSB
    Fluids don't need a break in time. It's the opposite. The newer the fluid, the better performance you will have.
