How To: Spark Plug Change (1 GR-FE)
Discussion in 'Technical Chat' started by chris4x4, Mar 16, 2009.
  1. Jun 23, 2016 at 1:58 PM
    #1741
    Mariotaco
    Mariotaco Well-Known Member
    Mario
    El Paso, Texas
    11 SR5 4x4
    good to hear :) The one thing I'm scared of is cross threading
    JMoney[QUOTED] likes this.
  2. Jun 23, 2016 at 2:09 PM
    #1742
    jrzyshore
    jrzyshore Well-Known Member
    Scott
    SNJ
    2010 Toyota Prius TRD Offroad
    Icon extended travel coilovers and rear shocks, Dakar leaf springs, Toytec U bolt flip, extended length Icon 2.0 rear shocks, Timbren Bump stops ,TC UCAs, Street Taco (Beefedtaco) 1 1/2" CB drop, 4x Innovation DOM tube sliders with kick outs, some extended brake lines,ATO front skid plate, ATO trans skid, ATO Hi Lift brackets, 60" Hi Lift jack and a pine tree air freshener.
    I've done a lot of plugs in my time and this is one of the easiest. I while back I was able to change my plugs in the time it took me to cook a steak on the grill.
  3. Jun 23, 2016 at 4:47 PM
    #1743
    Polymerhead
    Polymerhead Well-Known Member
    Missouri
    '18 TRD Limited Inferno...Tundra!
    Well, you can cross thread a plug, or worse - snap one off, then it'll be $$ to get it fixed. Sounds like the chances of that are pretty slim though. Follow the tutorial step by step and there won't be surprises. The only step I didn't follow to the letter was the torque on my plugs. Tried to use a wrench that bottomed out at 15 ft lbs and it didn't want to click. I didn't push the issue since it was a 2 ft torque wrench. I just tightened hand tight then another quarter turn. Plenty of anti-seize on them to make the next change just as easy.
    Mariotaco[QUOTED] likes this.
  4. Jun 23, 2016 at 5:00 PM
    #1744
    Mariotaco
    Mario
    El Paso, Texas
    11 SR5 4x4
    Thanks for the advice, I will end up doing it, and save myself 90 bucks to go towards a leather skinwrap for the steering wheel. How many miles have you driven since you spark plug change? Just wondering because I may also hand tighten the plug and do another 1/4 with the wrench
  5. Jun 23, 2016 at 5:36 PM
    #1745
    kullin
    kullin Well-Known Member
    Scott
    Denison Tx..
    2015 Toyota double cab
    None Yet :)
    The easiest way to get the plugs out is to use a pc of rubber fuel line and push it over plug... Works great for starting plugs in hole also as its easy to cross thread one using a socket because you lose the feel...
  6. Jun 23, 2016 at 5:39 PM
    #1746
    Polymerhead
    Missouri
    Plenty to know if there was an issue. Truck drives smoother now, but probably more due to the tire rotation than the new plugs. Plugs were only 32k miles old and still pretty clean.
  7. Jun 23, 2016 at 6:07 PM
    #1747
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    In my experience a rigid socket extension gives more distinct feel than a rubber hose. Just turn the socket extension with your fingers. If you use antiseize on the threads, the plugs go in extremely smooth, and it's very apparent when the plugs have bottomed, at which point you snap on a ratchet handle and give it another half a turn. Did this with the Taco and my Honda-engined lawn mower (which also has an aluminum head).
  8. Jun 23, 2016 at 7:57 PM
    #1748
    mrlee
    mrlee I like crunchy Tacos!!
    2013 TRD Sport (Yeah, it's gotta skewp, Haterz gonna hate)
    Bed rug, ARE bed top, Weathertechs. Little goodies here and there!
    To remove the plugs, I just used a normal spark plug socket. I did acquire an extension set where you have to release the socket. Basically, the socket won't come off the extension without releasing it. Made it all easy-peasy. My socket is probably 20 years old and still holds on to the plugs. Old SK brand socket. Damn they have lasted, don't have many of those left. Not even sure if they are even still made.
    Installed using the same method in reverse, but always started threading by hand on the extension. Once you do one, you'll know how it feels if you're cross threading or not.
    Just take your time. Do one at a time and you'll be fine.
    TacomaCZman likes this.
  9. Jun 24, 2016 at 2:27 PM
    #1749
    Zoot
    Zoot Well-Known Member
    2011 DC/SB TRD O/R 4X4
    Toyota bed mat, Wet Okole's F&R, Window Tint, custom trail-stripes, Cooper A/T3 265/75R16, MedlinAround interior LEDs, Leer 100r, aFe air filter, K&n cabin filter
    Set the plug in hole with ratchet and push down slightly, turn it backwards as if you were removing it until you feel it clear the top thread and drop down into engine, then start tightening by hand. Ive never cross threaded nothin' but this retarded ikea bookshelf.
    Mariotaco likes this.
  10. Jun 27, 2016 at 8:33 AM
    #1750
    heedfulCrayon
    heedfulCrayon Member
    2006 Speedway Blue Tacoma SR5
    So I just replaced my plugs this weekend at 120K miles. Plugs came out with one side NGK and the other side Denso... so I'm pretty sure they were the original plugs. The engine runs much better now.
    One question I do have is, are the cables supposed to be replaced at any point in time? Seems like it would be a pain in the butt to replace them.
    1Shifter and kullin like this.
  11. Jun 27, 2016 at 1:59 PM
    #1751
    Chris(NJ)
    Chris(NJ) Well-Known Member
    Usually in Central Jersey
    08 Indigo 4x4 DC OR
    Mods are currently being changed .....
    There shouldn't be any reason to change the wiring harness going to them.
    If, for some reason, your connectors corrode, you could splice a new connector on there, but that'd be about it.
    heedfulCrayon[QUOTED] likes this.
  12. Jun 27, 2016 at 4:27 PM
    #1752
    linkfeeney
    linkfeeney Well-Known Member
    link the stink!
    Sewell, NJ Eh!
    09 Doublecab TRD Off-Road! Magnetic Grey!
    wow, you waited 120k to change your plugs? that's pretty hardcore!
  13. Jun 27, 2016 at 4:50 PM
    #1753
    heedfulCrayon
    Actually I bought the truck at a dealer at 110k miles. Apparently the truck's maintenance was not up to date like they claimed
  14. Jun 28, 2016 at 6:48 AM
    #1754
    KenLyns
    Belly of the Beast
    Did you measure the gaps of the 120k plugs? Would be interesting to see.
    It's coil-on-plug ignition. No need to replace the wires since they carry low voltage and aren't as susceptible to dielectric breakdown.
    ninjastar808 likes this.
  15. Jun 28, 2016 at 2:45 PM
    #1755
    ninjastar808
    ninjastar808 flaccid member
    "key-key"
    HI --> CA --> NV
    05 X-Runner BSP
    Magnaflow muffler, LED lights, beer tap knob
    Mine are about to be done in the 2nd weekend of July. Got mine at a stealership @ 103k and it's been feeling sluggish lately @ 113k. I just hope that I don't pull out original plugs also o_O would be a sad sight.. I'll measure the old ones tho and update :thumbsup:
    Thanks for the write up! Will be doing it every 30k for sure :D
  16. Jun 28, 2016 at 6:39 PM
    #1756
    heedfulCrayon
    Just measured the gaps on my old plugs, 2 were at .066, 2 at .058, 2 at .060... definitely should have been changed a while ago
  17. Jun 30, 2016 at 4:16 PM
    #1757
    KenLyns
    Belly of the Beast
    ^That's not too bad for 120k, actually. Mine at 31k were .055 on the RH bank (Denso) and .061 on the LH bank (NGK).
  18. Jun 30, 2016 at 5:22 PM
    #1758
    linkfeeney
    link the stink!
    Sewell, NJ Eh!
    I have to do my truck soon... I did 30k, 60k, then I got lazy, almost at 120k now... also thinking getting a new torque wrench... tekton, i see people are reviewing them and a lot of 4-5 stars on Amazon.
  19. Jun 30, 2016 at 8:58 PM
    #1759
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    Here's a short review on my Harbor Freight (Pittsburgh) 1/2" Torque wrench. My buddy took it to his work and had it tested. It rang in at 2ft/lbs low. I'm happy with that for $10
  20. Jul 1, 2016 at 2:58 PM
    #1760
    Chephie
    Chephie Well-Known Member
    Chad
    Ohio
    2012 MGM DCSB TRD OR
    OME884/5100's Wheelers Progressive AAL LR UCA's 265/75/16 Duratrac Method NV wheels Color matched grille surround ImMrYo rear view mirror relocation bracket Avid slider/steps
    I've been pleased with my Tekton torque wrenches. I have both the 1/2" and 3/8", for what I do they fit the bill.
