How To: Spark Plug Change (1 GR-FE)
Discussion in 'Technical Chat' started by chris4x4, Mar 16, 2009.
  1. Dec 30, 2017 at 12:56 PM
    #1961
    Lil'Taco
    Lil'Taco Well-Known Member
    Scotty
    Wilsonville
    2010 PreRunner Sport DCSB
    Total Chaos +2" Long Travel, Coil Bucket Gussets, Spindle Gussets, LCA Cam Gussets, Glassworks 4" fenders, B.A.M.F. rock sliders with fill plates, Decked Drawer system, aFe CAI, Borla Cat-back exhaust, Blitzpro 21S LED light bar w/ B.A.M.F. behind the grill light bar mount, Red Label Off-road tube bumper, Redline hood struts, Grillcraft grill, Weather Tech floor mats, HID headlights and fog lights... It has more stuff done to it now.
    Spark plugs changed, super easy with a cold air intake and the engine cover removed.
    As far as the plugs though anyone know why R1,L1, and L2 have the brown on the outside of the plug?
  2. Dec 31, 2017 at 10:54 AM
    #1962
    SIZZLE
    SIZZLE Pro-party
    Novato, CA
    2014 DCSB TRD Off Road
    A little a this, a little a that...
    Great how-to OP! Just changed mine for the first time. Easy peesy.
    I also have an OR so I just disconnected the intake hose at the air filter housing. That gave me plenty of room and I didn't have to mess with the pump.
  3. Jan 6, 2018 at 7:44 AM
    #1963
    TONYCANNOLI
    TONYCANNOLI Well-Known Member
    ‘15 DCSB 4x4 Sport / ‘14 SR5 Premium 4Runner
    About to do this. Sub’ed for easy searching.
  4. Jan 13, 2018 at 3:00 PM
    #1964
    the dashing ham
    the dashing ham Taco n00b
    Scotty
    Los Angeles
    '12 DCLB rattle can
    yes, I have done the mods
    Great write-up. Also a first-time plug changer.
    How much wetness is normal on the plug threads? I've got a couple that are partway dark, and one that the wetness is all the way up to the washer.
  5. Jan 14, 2018 at 5:41 AM
    #1965
    Hashc93
    Hashc93 Well-Known Member
  6. Jan 20, 2018 at 10:53 AM
    #1966
    McSwine
    McSwine Well-Known Member
    Levy, Arkansas
    First of all, thanks to the OP for a most excellent DIY.
    And to the guy that came up with the magnetic, swivel spark plug socket: Give the man a blue ribbon.
    Not knowing what had been done to my recently acquired '09 V6 Prerunner, I thought changing the plugs was a no-brainer. My snorkle thing had a 12mm bolt that didn't want to come out cleanly, so I disconnected the snorkle at the air cleaner and worked around it. It went smoothly except for the connector on the front driver side that was a huge pain in the ass to get disconnected.
    It still had the NGK plugs on the drivers side so I'm assuming they've never been changed, which is a bit worrisome. They didn't look awful, but were obviously worn with gaps around .070. At any rate, it idles better and seems a bit smoother. It's nice knowing I saved a ton of money as well.
    Thanks again for the great thread.
    NAAC3TACO likes this.
  7. Jan 30, 2018 at 9:37 PM
    #1967
    Chuy
    Chuy Well-Known Member
    Lakeside, CA
    07 V6 DCLB 4X4 Sport
    Silver Taco
    Changed my plugs for the 2nd time couple of weeks ago. These are NGK Iridiums LRFK6AIX-11 with 101,050 miles. The Taco was running great when I replaced them but the ground electrodes were noticeably worn down. The gaps were good 'cause I had re-gapped them at 80K; at that time they averaged .060. Replaced them with Denso Iridium Long Life SK20HR11 which have a hardened ground electrode and should provide reliable service past the NGK's they replaced.
    sgtnewundies likes this.
  8. Feb 2, 2018 at 3:25 AM
    #1968
    sgtnewundies
    sgtnewundies Well-Known Member
    Eric
    Florida, Citrus County
    14 trd sport red
    Working on it now....UNDER CONSTRUCTION
    I have them in my truck now and will run them to 80000 miles. Looks good.
  9. Feb 28, 2018 at 4:50 PM
    #1969
    witter beach
    witter beach Active Member
    seattle
    2008 tacoma trd offroad
    Thanks for the write and pictures. I also noticed your tape on the socket extension, good idea so you don't lose it some where it doesn't belong............
  10. Mar 4, 2018 at 11:17 AM
    #1970
    samjpatt
    samjpatt Well-Known Member
    Raleigh, NC
    2018 Cement TRD Off Road
    RIP: 2015 Silver TRD Sport
    Great write up- just did this as part of my 30k (overdue) service.
    Highly recommend grabbing a universal joint socket adaptor for getting the 10mm on the driver side. Made my day a heck of a lot easier. Done in a little under 2 hours.
    Thanks a ton!
    DoorDing likes this.
  11. Mar 25, 2018 at 9:26 PM
    #1971
    VibratingTaco
    VibratingTaco Member
    Littleton, CO
    2015 Toyota Tacoma Magnetic Grey DCSB
    3" Toytec BOSS Kit
    Thank you Chris for this, I'll be hitting 30K on my 2015 soon.
  12. Mar 30, 2018 at 9:55 PM
    #1972
    Skittles93
    Skittles93 'Member
    Novato CA
    TRD OR SB 4x4 (sold) 19 4runner TRD Pro
    Frankenstein Mid-Travel Kit, sPod, Relentless Custom Baja Bumper, Relentless: Sliders, T-case skid, rear bumper, tailgate reinforcement, Rago Fab: Bed Channel Stiffeners, SCS 16" wheels, BFG KO2 275,75,R16, Diff breather mod, A/C hose extension mod, Custom exhaust routing. (Sold)
    My fun chore for this weekend, great write up Chris!
  13. Apr 4, 2018 at 4:00 AM
    #1973
    birddog11
    birddog11 Member
    2012 sr5
    Great write up, I’m picking up some anti seize, the op just uses the basic tube which I haven’t been able to find yet, I have only seen the aluminum and copper version. Which of the three is best to use ? Copper with the denso plugs or just keep looking for the standard anti seize ? Tia
  14. Apr 4, 2018 at 8:41 AM
    #1974
    Chuy
    Lakeside, CA
    Silver Taco
    If you gonna use anti-seize remember to reduce torque spec by 10-15%. I don't think it matters which anti-seize you use. Permatex has an application guide on their website.
    @birddog11
    birddog11 likes this.
  15. Apr 4, 2018 at 8:44 AM
    #1975
    birddog11
    birddog11 Member
    2012 sr5
    Good to know ty
  16. Apr 7, 2018 at 4:20 PM
    #1976
    NiGelTRD
    NiGelTRD Tacoma Rocks!
    San Diego, CA
    09 TRD Sport Silver Mica Double Cab LB PreRunner
    Nothing yet!
    Read this write-up prior to doing replacement last night, Taco seems to run smoother. Must be placebo effect. Original plugs were still pretty good shape.
  17. Apr 9, 2018 at 7:39 PM
    #1977
    SaphiraTaco
    SaphiraTaco Well-Known Member
    Sean
    Seattle WA
    2013 DCLB TRD Sport
    About halfway done...
    Great write up OP! This was the third plug change on my 06. I finished quicker this time and decided to clean the throttle body while I had the air filter separated. Truck runs great.
  18. Apr 17, 2018 at 12:08 PM
    #1978
    AJS
    AJS Active Member
    15 DBCBLB
    Changed my 2015 for the first time after 32K miles. I noticed they had Denso plugs on the passenger side and NGK on the drivers. All the plugs were at .045" gap except 2 on the drivers side were closer to .050. Went with Denso Irridiums so I don't have to change them for another 100K miles. Pass side was easy. Drivers side a bit more challenging but not overwhelming. Just need to take off brackets to gain access. Overall an hour and forty min job. Well worth doing yourself.
  19. Apr 17, 2018 at 12:11 PM
    #1979
    inwood customs
    inwood customs Roaming potato
    Dave
    2006 v6 potato bugTuRD
    K&n, flowmaster, plastidip, chipped, hids, daves
    30k intervals give you an idea how the truck is running and save threads.
    Just a couple pennies
  20. Apr 18, 2018 at 2:54 AM
    #1980
    Chuy
    Lakeside, CA
    Silver Taco
    You don't have to replace them at 30K to do that. Just pull them out, inspect, re-gap/clean, re-install. The 30K replacement recommendation in the maintenance schedule is primarily to comply with their emission warranty agreement - says so in my manual. The standard copper plugs can easily go 50K + .
    I replaced the OEM plugs in my Taco at 60K with NGK Iridiums. Then replaced those recently after 110K with Denso Iridium Long Life. I do recommend pulling them at 60K or so. When I inspected mine at 80K, the gap was nearly .060. The engine was running fine when I replaced them but the ground electrodes were visible worn down; the ignition cycle eats the electrodes. I noticed the exact same thing on our Lexus ES250 which came stock with NGK Iridiums and recommended replacement is 120K. The Long Life's (and more expensive Iridiums) have a hardened electrode which will minimize this effect. With a little anti seize on the threads, there is no issue removing them.
    It's not a matter of saving pennies. It's practical to extend usage of things based on individual needs. The recommended maintenance schedule is to reduce warranty claims from those that wouldn't know how to maintain their cars otherwise. It gives the average car owner a guide to follow. For those of us that know a little more about auto mechanics, we know, for example, we can safely switch to synthetic oil to extend oil changes. That we can switch to Iridium plugs, etc... You can apply a little logic here also - a reputable plug manufacturer would not list a plug in their application guide if they hadn't tested it for usage in that vehicle.
