How to: Swap Your Spindles
Discussion in 'Suspension' started by JLink, Feb 13, 2012.
  1. Jan 18, 2013 at 2:17 PM
    GREEKBOY12295
    GREEKBOY12295 Well-Known Member
    Nick
    Phoenix, AZ
    2005 Toyota Tacoma PreRunner
    Radflo 2.5 Coilovers, Viper Alarm 5902, Bilstein 5100's, Polk Speakers, Blacked out grille and Emblems, All Pro 3" leafs, Pioneer AVH-4300 Double Din, BHLM, 4" Maxtrac Spindle, Aero Turbine 2525xl, Ultra Gauge, Rockford Fosgate 300 mono amp, 10" Kicker CVR
    There isnt much you can without being there.
  2. Feb 2, 2013 at 3:27 AM
    357sig
    357sig Donut king
    dough boy
    donut shop
    Gold digger
    So I replaced my spindle just the other day. Went for an aligment and the guy said my bearing was bad! Anyways I got did a google search and this post popped up. It seems like you have everything covered but one. You forgot to mention how to pull the bearing out of the spindle. Now that was what I was actually looking for. Putting it back in would just consist of bolting all 4 corners down. I think I messed my bearing up when I was trying to take it out.
  3. Feb 2, 2013 at 4:14 AM
    357sig
    357sig Donut king
    dough boy
    donut shop
    Gold digger
  4. Apr 26, 2015 at 7:22 PM
    skygear
    skygear                    
  5. Apr 28, 2015 at 6:58 PM
    JLink
    JLink [OP] Well-Known Member
    Josh
    Ocean, NJ
    Lifted, Locked, Armored. Ready To Wheel.
    don't know what you mean about removing the bearing from the spindle.. the hub just unbolts from the spindle and the bearing remains intact in the hub. if you are talking about replacing the bearing in the hub, then your best bet is to order a replacement from NJ636 otherwise you can damage the bearing and have catastrophic failure if you don't have the bearing seated properly.
    Crom likes this.
  6. Apr 28, 2015 at 7:17 PM
    skygear
    skygear                    
    Me? I was just posting a vid I found since there was a 4wd version.
  7. Apr 29, 2015 at 7:32 AM
    JLink
    Josh
    Ocean, NJ
    Lol no the guy above you saying I didn't explain how to remove the bearing.
  8. May 3, 2015 at 9:41 PM
    Softtacosupreme
    Softtacosupreme Well-Known Member
    Is welding the spindle gussets on difficult? On a scale of 1-10, 10 being professional/excellent welder, I'm about a 5 or 6. Would this be something a more experienced welder should do? My beads are decent, I just have to hone in my consistency.
  9. May 18, 2015 at 5:50 PM
    CVYota
    CVYota Damaged goods
    Andy
    Crescenta Valley
    2011 DCLB V6 4WD
    Thanks for the write-up, it helped this weekend. I had trouble getting the hub off of the spindle, had to use a bearing puller to coax it off the CV, looks like it was rusted a little.
    Crom likes this.
  10. Aug 28, 2015 at 7:41 PM
    JLink
    Josh
    Ocean, NJ
    Idk man. That's up to you lol
    Anti sieze is your friend
    Crom likes this.
  11. Sep 8, 2015 at 6:44 AM
    yotastaco
    yotastaco Well-Known Member
    NC
    2015 MGM TRD OR
    See Build
  12. Mar 6, 2016 at 7:17 PM
    Alejandro Jr
    Alejandro Jr Member
    Alejandro
    2008 red tacoma trd
    i have put on a 4 inch lift kit
    where did you buy your knuckle from and how much?
  13. Mar 6, 2016 at 7:18 PM
    Alejandro Jr
    Alejandro Jr Member
    Alejandro
    2008 red tacoma trd
    where did you get your knuckle from? i am currently looking for one for the front driver side of my 2008 tacoma prerunner
  14. Aug 16, 2016 at 12:17 PM
    Crom
    Crom Super-Deluxe Member
    Nick
    San Diego, CA
    2009 4x4 DCSB Camp Supreme
    Millions
    @JLink Very nice write up. This is very useful! Thanks.
    JLink[OP] likes this.
  15. Jul 25, 2018 at 8:59 PM
    #35
    reidkm
    reidkm Does lifting my truck increase my boto size?
    Reid
    Hilo, Hawaii
    2015 Tacoma, 4.0V6, 4x4 SB
    6" RC Lift Kit, Bilstein 5100 Full length shocks front and rear, OME 883 Coils, SPC UCA's, 285/70/17 Cooper STT Pro's
    Nice write up
  16. Sep 4, 2018 at 3:01 PM
    #36
    Jibbs
    Jibbs "When in doubt, throttle out!"
    Josh
    Cincinnati
    2017 SCREW Raptor Lightning Blue
    Whoooooooshchchch
    Hello from 6 years after OP. I had a HARD hit on my passenger front on the trail (hard enough to debead), and now I have some random inward camber on that tire that I can't adjust out with the cams. The space between my tie rod and the disc is the same on both sides, but I wonder if I may still have a tiny amount of bend in the spindle from the impact that is causing it. Any thoughts?
    Also- good aftermarket spindles or places to find OEM spindles? I figure even if the spindle isn't bent it'd be good to have a spare.
  17. Sep 4, 2018 at 3:06 PM
    #37
    JLink
    Josh
    Ocean, NJ
    Yea I’d imagine you may have bent it. Try a junk yard or car-part.com or eBay or search around on here.
    Would be a good idea to get total chaos spindle gussets too.
    Good luck
    #37
    Jibbs[QUOTED] likes this.
  18. Dec 19, 2018 at 12:02 PM
    #38
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
  19. Jan 17, 2020 at 9:56 AM
    #39
    Taco-Obsessed
    Sub for future reference.
    Thanks OP
  20. Jun 1, 2020 at 4:41 PM
    #40
    deekyn
    deekyn Well-Known Member
    Dustin
    Yellowstone
    2015 Black Tacoma TRD Off Road
    Great write up! Thanks for the help.
    I too had to use a three jaw puller to get the hub off. But otherwise this really helped!
