How to Take Measurements
Discussion in 'Suspension' started by TacomaJay09, Jan 31, 2014.
  1. Jan 31, 2014 at 6:25 AM
    TacomaJay09
    TacomaJay09 [OP] Well-Known Member
    Central MA
    09 TRD Sport Dbl Cab
    None Yet
    Although I've read some posts describing both scenarios, the descriptions are very vague and could easily be misunderstood by anyone looking to take measurements. I thought it might be helpful if anyone has pics, or could take pics of the actual proper way to take measurements. The most obvious is the amount of lift......hub to fender. Is this done with the wheel on or off and where on the fender. Also suspension travel. What's the easiest way to flex the suspension with the shocks removed and do you just measure from shock mount to shock mount?
