how to tell if my new used rims fit my trd
Discussion in 'Wheels & Tires' started by eric80, Oct 20, 2010.
  1. Oct 20, 2010 at 10:19 PM
    eric80
    eric80 [OP] Member
    eric
    Whistler
    07 tacoma trd dbl LBox 4x4
    getting ready to huck a move
    I'm shopping for winter tires. The ones I want, Michelin ice-x 265/70r/16, come with rims. Looks like the tires will fit but I've been trying to figure out if these rims will fit my truck. (Toyota dealership could not tell me).
    I have a 2007 Toyota Tacoma TRD dbl cab long box 4x4. It came with 265/65r/17. I understand the 17 were an optional upgrade.
    The VIN plate says 265/65r/17 17x7.5JJ
    I found a web site that says
    TACOMA 4WD & PRE-RUNNER 95-UP 15x7 6x139.7 12x1.5 106 M
    The rims I am looking at say several different things
    Of the four rims this is what is stamped on them
    1st rim; 23 MR EW
    T 16 x 7 J DOT CMC 306 NEW 27
    2nd rim; 07 AP EW
    T 16 x 7 J DOT CMC 306 NEW 30
    3rd rim; 07 AP EW
    T 16 x 7 J DOT CMC 406 NEW 5
    4th rim; 11 AP EW
    T 16 x 7 J DOT CMC 406 NEW 17
    First off will these used rims fit my truck? Or what can I do to figure it out?
    I gather the 15 x 7 may be stock and the 16 x 7 from the used rims is the OE wheel size.
    Do I need to worry that my VIN plate says 17 x 7.5JJ ?
    Any comments, Thanks Eric
    dandm18@hotmail.com
  2. Oct 21, 2010 at 8:50 AM
    TexasTacoma37
    TexasTacoma37 Well-Known Member
    The 17x7.5's come stock on TRD sports.
    15" rims will not fit on any second gen tacoma except the 5-luggers
    What you need to find out about these used rims is the bolt pattern (you need 6 on 5.5, or 6 on 139.7), and the backspacing or offset (4.5" backspacing to5.5" backspacing, depending on the tire size you want to run)
    Do you have a link to these rims?
  3. Oct 24, 2010 at 11:22 PM
    eric80
    eric80 [OP] Member
    eric
    Whistler
    HI thanks for your note
    The only info is what is stamped on them .
    They are Tundra rims.
    I bolted the front ones on no problems, no rub etc.
    there is very little (1/4") clearance to caliper but other wise seem fine
    I'll attach a pic tomorrow, seems I've hidden all my pics on windows7 and can't get them back yet.
  4. Oct 25, 2010 at 4:23 AM
    TexasTacoma37
    If they are tundra rims you are good go.
  5. Oct 26, 2010 at 12:14 AM
    eric80
    eric80 [OP] Member
    eric
    Whistler
    good to go thanks
  6. Oct 26, 2010 at 6:06 AM
    TexasTacoma37
    Oops, what I meant to say was if they are OLDER tundra rims you are good to go. The newest tundras are 5-lug. I apologize.
