How To: Throttle body cleaning 2005+ V6
Discussion in 'Technical Chat' started by genxer36, May 23, 2010.
  1. Jan 11, 2013 at 6:24 PM
    #221
    Rays08
    Rays08 Member
    Ray
    Kaysville, Ut
    08 TRD Sport Crew Cab
    Thanks for your help, and for a great write up and photos. Now I am confident I can change the part myself, although it costs $900 from the dealer. I am going for used.
  2. Jan 13, 2013 at 3:59 PM
    #222
    genxer36
    genxer36 [OP] Lord of Tomfoolery
    Sean
    Bethlehem,GA
    Tow package, XM Satellite radio, K & N Air filter, & Channel Vent Visors
    Good luck. And welcome to TW! Take pictures & do a write up on " How To: Replace a Throttle body".
  3. Feb 5, 2013 at 9:13 AM
    #223
    MrTacoma
    MrTacoma Well-Known Member
    Tacoma Base v6
    None
    I just did mine yesterday...the back on the throttle body towards where it was conntected was as black as my iphone cleaned it out and pulled the MAF sensor sprayed it to..I was amazed with amount of power I got back and how much pick up it gained from doing this less than hour maintence..however when im driving and accelerating and slowing down seems to make a fizzing noise is that cause something wasnt connected properly or is loose or is it just me?
  4. Feb 5, 2013 at 9:40 AM
    #224
    tacoma guy
    tacoma guy Well-Known Member
    Joe
    Phoenix Az.
    2011 Tacoma Prerunner TRD
    Bilstein 5100's on all four corners. Front set @ 0 with OME 883x coils. Alcon leaf springs. Viper Alarm. Wet Okole seat covers. WeatherTech Floor liners front and back. Oem Toyota chrome exhaust tip. ARE Shell. America Outlaw Wheels.
    If you unhook the wire harnes at the MAF do you still have to unhook the battery and will it still afteck the idedling ? Also can you just take the MAF sesor out of the intake tub ? So that your not trying to spray it from inside the intake tub?
  5. Mar 24, 2013 at 8:31 PM
    #225
    TacosNBurritos
    TacosNBurritos Active Member
    Nick
    Pacific Northwest
    2012 4x4 T|X TRD
    Cleaned MAF and Throttle body today. It was my 30k maintenance. I noticed just a little carbon build up. The toothbrush I used was black so it did its job. The cleaner recommended doing this whenever you change your engine air filter. I swapped the OEM filter for a K&N. I did notice when I fired it up it idles at 1500. Will monitor to see it come down. Not difficult at all to do.
  6. Mar 25, 2013 at 4:04 PM
    #226
    MrTacoma
    Tacoma Base v6
    None
    I changed my spark plugs when I did my oil change / tire rotation/ air filter , I decided when doing spark plugs i said what the hell ill clean maf and throttle body again after about 1000 miles...the maf and throttle were barley dirty at all not suprised but I figured I'd clean it again since I was right there...the truck feel really good and hell of a lot strong idk it its plugs changing the oil or new air filter or cleaning the throttle and maf..idk if ill see result for a couple 100 miles cause I disconnected the battery so I think ecu has readjust but it feel really good I didn't have issues I had before...I'm starting question where u gotta disconnect battery since ur unplugging sensor and unplugging throttle they shouldn't have any electricity in them since the source is cut out, like sparkplugs don't need battery out wouldn't same follow for maf and throttle?
  7. Mar 25, 2013 at 4:17 PM
    #227
    genxer36
    Sean
    Bethlehem,GA
    Unplugging the maf doesn't effect the ECU. It is still drawing current from the battery. Disconnecting the battery is kinda like rebooting the ecu. It will help the vehicle get back to normal operating procedures faster, than if you didn't disconnect. Another words the high idle may take longer to settle in by not disconnecting the battery. This is what I took from my research when I was writing the "How to".
    The illustration I found to show where the different ecu's are located. And the engine control module.
  8. Apr 4, 2013 at 6:06 PM
    #228
    boto
    boto Active Member
    Philip
    Quebec/Canada
    07 taco dbl.cab.long bed TRD
    fog anytime bhlm royal purple oil kn&n oil/air filter secondary filter removed ultimate lift kit toytech 3 inch coilovers ans add a leaf relentless fab diy bumper
    wow,thanks ,il try this.mine got 150k and it has never been cleaned
  9. Apr 27, 2013 at 11:43 AM
    #229
    LBtaco
    LBtaco Thread killer
    Long Beach , CA
    15 Nissan Leaf
    Jetsons mod
    Just did mine, took about an hour but I went slow and changed my wiper blades too :D
    Thanks for the write up, it made it super easy:thumbsup: (yes!! nice arrows too!!!)
    I ended up not moving the valve and just cleaning around it, just in case it would mess something up.
    Idle was a little high at first but after going around the block it seemed fine.
    Throttle response was better and no hesitation.
    116k miles and it was prbably never done.
  10. May 20, 2013 at 9:20 AM
    #230
    forealz
    forealz Active Member
    Los Angeles
    07 PreRunner OffRoad TRD 33k
    Thank you for the write up. I did it on Sunday. So far so good.
    I'm a little worried I overtorqued the 4 bolts on the throttle body though. I got it up to 70 on the highway and it seemed fine.
    http://www.amazon.com/gp/product/B000MB53ZE/ref=oh_emp_details_o03__i00?ie=UTF8&psc=1 was the wrench I used.
    I think I did closer to 15/20 supposedly the wrench is "calibrated to +/- 4%" so I might be okay?
  11. May 21, 2013 at 10:17 AM
    #231
    Hans Moleman
    Hans Moleman Well-Known Member
    Bay Area, CA
    2023 F-150 Powerboost
    So it's ok to move the butterfly manually? I know with some electronic throttles, moving the butterfly manually will damage the servo motor or the electronics.
  12. May 21, 2013 at 5:52 PM
    #232
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Yes. It wont hurt anything. Dot go nuts, and sit there moving it back and forth until your finger hurts, but moving it to clean isnt bad.
  13. May 23, 2013 at 6:47 AM
    #233
    Agent Smith
    Agent Smith Always outnumbered, never outgunned
    05 TRD Offroad Ivan Stewart Edition
    Toytec lift,FJ Anthracite wheels wrapped in BFG A/T 265/75/16's,WAAG Brush Guard, IPF 868's,sleeved fog lights
    I did this at the same time I changed out my plugs. I pulled the MAF out to clean it, no problems (of course I treated it like a fragile computer sensor). Funny thing is, it looked spotlessly clean before I sprayed it. Now the TB, that was black as sin.
  14. May 23, 2013 at 9:10 AM
    #234
    adio
    adio Well-Known Member
    HI
    2015 INFERNO TRD PRO
    great write up. gonna do this when my 08 reaches 50K miles.
  15. Jun 1, 2013 at 11:30 AM
    #235
    easystickerco
    easystickerco Well-Known Member
    San Diego
    Tacoma SR5
    This is one of those threads that will go on forever. I just did it to my Tacoma, and WOW. Bogging went away completely. Thanks to the OP
  16. Jun 1, 2013 at 5:55 PM
    #236
    george3
    george3 Well-Known Member
    New Jersey
    2008 2.7 Manual Trans Tacoma
    Seat belt beeper, Cabelas (Weathertech) floor liner gray, Covercraft Seat Savers in Taupe, Protecta Heavy Duty Rubber Truck Bed Mat, Pop n Lock PL5200, Pace Edwards Full Metal JackRabbit, Wolverine oil pan heater, Scangauge2, afe pro dry s filter, Remote Underbody 4 Piece LED Light Kit (White) used as Bed light, DIY Washable Cabin Air Filter, PA15-TOY, 4x4 Illuminated Switch, full synthetic, Redline Tuning Hood Support, Smittybilt Nerf Steps black powder-coated
    How many miles do you have with your Bogging ?
  17. Jun 2, 2013 at 3:46 AM
    #237
    easystickerco
    San Diego
    Tacoma SR5
    127k
    I recently bought 05 4dr 4.0 used. B4 I paid for it, I took it to the dealer asked them to check it out. Told them about the bogging between 1k-1500 rpms
    Came back clean, all service n maintenance records done at Toyota, Strange thing is I asked about the bogging, she said that's normal. All Tacomas do that.
    Mine doesn't do it anymore! Thanks to this thread.
  18. Jun 2, 2013 at 5:59 AM
    #238
    george3
    New Jersey
    Very interesting. Dealers - go figure. We know more then they do just by reading TW or maybe they just don't give a shite. Thank 4 the reply.
  19. Jun 9, 2013 at 6:33 AM
    #239
    JCruiser
    JCruiser Well-Known Member
    Master Chief (E-9) USN (Ret)
    Georgia
    '23 Tacoma SR5 4WD 4D "Ice Cap" w/ XP Package
    Upcoming...... Pro grille and driving lights
    "Most" service writers have never been mechanics much less part changers, especially at the "Stealerships". I have learned more from this website than most of the service writers even know.... and I appreciate those on here that do share the tips, tricks and ideas. Thank you all.
  20. Jun 9, 2013 at 9:03 AM
    #240
    george3
    New Jersey
    X2:D
