How To: Throttle body cleaning 2005+ V6
Discussion in 'Technical Chat' started by genxer36, May 23, 2010.
  1. Jun 9, 2013 at 8:18 PM
    #241
    genxer36
    genxer36 [OP] Lord of Tomfoolery
    Sean
    Bethlehem,GA
    Tow package, XM Satellite radio, K & N Air filter, & Channel Vent Visors
    :thumbsup:
  2. Jun 10, 2013 at 5:41 PM
    #242
    taco2010trd
    taco2010trd Cyber Bully
    Tampa, Florida
    2010 Silver TRD OR DCSB
    Thank you OP, great thread. Just did it on my 2010 trd OR. Have 55k miles, didn't see too much buildup and not sure it made too much difference. BTW I used two coat hangers instead of wire, worked perfectly.
  3. Jul 7, 2013 at 10:33 AM
    #243
    Bajatacoma
    Bajatacoma Well-Known Member
    SC
    05 TRD Off-Road, SR5, 6 speed
    110k and it was supposedly done before around 65K. I don't believe it was actually done properly as it was nasty; much better now! Initial high idle that went back to normal after a drive around the block.
  4. Jul 16, 2013 at 6:10 PM
    #244
    totmacher
    totmacher automotive hypochondriac
    Daniel
    TN (memphis-ish)
    Toyotas
    Cut & broke off stuff. Prolific ziptie and tape usage.
    Did mine @ 126,100 miles. Had a lot of build-up.
    Now, I can hear airflow under hard accelleration.
    In "normal" driving (1k-2k rpm) every thing sounds normal.
    Reving in neutral sounds mostly normal.
    It's just under load >3k rpm that I really notice an airflow sound.
    Almost makes me wonder if the o-ring didn't seat correctly when I put the TB back on. On the other hand, maybe that's just what the TRD CAI sounds like with a clean TB. I don't remember what it sounded like way back when I installed it almost 100,000 miles ago.
    O-rings are cheap so I might take the TB back off this weekend to replace that just in case.
    **edit/update
    Replaced the gasket. Got rid of the whoosh/whistle around 2100 rpm. $8.99 at Toyota, $3.99 at Autozone.
    Also noticed this time around that all of the rubber hoses had some cracks near the ends and the clamps were embedded into the rubber so they weren't really clamping very tight any more.
  5. Aug 11, 2013 at 8:11 PM
    #245
    geogecko
    geogecko Well-Known Member
    Broken Arrow, OK
    Thanks for these instructions. Did this for the second time on my Taco (2005 with 125k miles now). Wasn't that bad, but was doing a spark plug change, and figured I'd take a look. I think the first time was around 90k miles, and it was pretty bad then.
    Only step I modify, is that I actually take the MAF sensor out of the housing. Maybe dangerous, but I am very careful with it. I just feel like I can get to it better that way. Hate the way you have to clean the TB, but I don't think I want the extra steps of taking it off.
    I also noticed a few hoses with cracks in the end. I will probably take an inventory of those, and replace the ones I find. At some point, I would like to do the main radiator hoses as well. Better catch those before failure...
  6. Aug 11, 2013 at 11:46 PM
    #246
    george3
    george3 Well-Known Member
    New Jersey
    2008 2.7 Manual Trans Tacoma
    Seat belt beeper, Cabelas (Weathertech) floor liner gray, Covercraft Seat Savers in Taupe, Protecta Heavy Duty Rubber Truck Bed Mat, Pop n Lock PL5200, Pace Edwards Full Metal JackRabbit, Wolverine oil pan heater, Scangauge2, afe pro dry s filter, Remote Underbody 4 Piece LED Light Kit (White) used as Bed light, DIY Washable Cabin Air Filter, PA15-TOY, 4x4 Illuminated Switch, full synthetic, Redline Tuning Hood Support, Smittybilt Nerf Steps black powder-coated
    I like the preventitive maintenance idea - replacing the various hoses.:D
  7. Aug 18, 2013 at 2:39 PM
    #247
    Ttruck55
    Ttruck55 Member
    Edmonton
    08 Tacoma
    Thanks for the tutorial, very well done.
  8. Aug 18, 2013 at 2:46 PM
    #248
    tacomonazul
    tacomonazul Well-Known Member
    Luis
    SOCAL
    07 DCSB LT/4LINK
    http://www.tacomaworld.com/forum/2nd-gen-builds/227832-my-never-end-build.html
    Using this for my TB cleaning, nice write up!
  9. Aug 21, 2013 at 10:28 AM
    #249
    chetweewax
    chetweewax Well-Known Member
    NJ
    15 TRD Sport
    Homelink mirror (Adding soon) Came with truck: FUEL Rims, Mickey Thompsons, Vinyl Tonneau Cover, Remote Start, 20% front window tint
    Did this over the weekend, big difference in throttle response and no more rough idle. I did do two extra steps.
    1. SeaFoam spray to clean out the intake
    2. PCV
    Plus to make my life easier I removed the MAF, only two phillips screws, and un bolted the TB to access the back side much easier.
    I will be replacing the spark plugs next, I waited since I read that the SeaFoam can loosen some nasty shit and dirty plugs up pretty bad, just a precaution
  10. Aug 26, 2013 at 10:08 AM
    #250
    RegularPete
    RegularPete Member
    Pete
    Ohio
    07 TRD OffRoad PreRunner SR5 4x2
    Wanted to add my thanks, this tutorial was clear and concise! Tacomaworld.com is really helping me get more hands on with my truck. Without quality guides like this one I wouldn't have the confidence.
  11. Sep 6, 2013 at 7:33 AM
    #251
    dexdawg
    dexdawg Well-Known Member
    Frederick, MD
    2010 DC SB OFF-ROAD
  12. Sep 11, 2013 at 3:11 PM
    #252
    Jimuh
    Jimuh New Member
    Orange County
    11 SR5 PreRunner
    GF chip
    Xlnt article. Just one comment. I would remove the MAF sensor only because the wire is the critical item to clean, and you can see it much better with the sensor out. If you have experienced pinging a dirty wire can be the culprit.
  13. Sep 11, 2013 at 3:38 PM
    #253
    chetweewax
    NJ
    15 TRD Sport
  14. Sep 12, 2013 at 2:25 PM
    #254
    genxer36
    Sean
    Bethlehem,GA
    Thanks. And welcome to TW!
  15. Sep 13, 2013 at 10:31 AM
    #255
    coreypso
    coreypso Member
    2007 PreRunner
    Just wanted to say thank you to genxer and everyone else that posted great info. easy follow threw write up. My 2007 tacoma trd sport v6 throttle body was VERY gummed up. cleaned up pretty easy with a tooth brush. Thanks again, you saved me a few hundred bucks from what toyota wanted.
  16. Sep 14, 2013 at 4:42 PM
    #256
    storktaylor
    storktaylor Well-Known Member
    California, MD
    09 Pre-Runner TRD Off-Road
    Bak FLip G2 ScanGauge2 Black Labrador Retriever
    Great write-up! Took about 30 minutes and my truck runs a whole lot smoother and some pinging I had noticed has gone away. My truck is idling a little high right now, but from the looks of things, that is to be expected. Can't say thanks enough!!
  17. Oct 19, 2013 at 7:11 AM
    #257
    JoeSchmuck
    JoeSchmuck Well-Known Member
    Joe
    Virginia
    09 PreRunner SR5 2x4 O.R., Timberline Green
    Pop & Lock, Access LE Rollup Cover, Alpine PDX-5 Amp, Image Dynamics CS-6/CX-6 & 10" Sub
    Very nice writeup and like others have expressed, good use of the arrows, they gave me a good laugh. I will be doing this cleaning in a few weeks when I hit 50K on my truck. I will also be replacing the spark plugs at the same time and air filter. I have noticed over he past several weeks that my engine has been running a little rough at lower RPMs so I suspect one of these will fix it. Routine preventative maintenance will definitely make things run better and last longer. And it's time to buy new tires too, now there is an expense I could do without.
  18. Oct 27, 2013 at 8:29 PM
    #258
    itsky
    itsky Member
    Great write up, thanks for taking the time to put it together.
  19. Jan 1, 2014 at 6:18 PM
    #259
    TacoBrah
    TacoBrah Well-Known Member
    Sean
    Icon stage 1, 255/85/16 KM2
    Did this today, wasnt bogging or anything prior but at 60k it cant hurt. Didnt notice any real difference after, so that good.
    Thanks OP.
  20. Jan 19, 2014 at 7:49 PM
    #260
    TXMarine
    TXMarine Well-Known Member
    Fred
    Houston, TX
    2011 DC TRD Off Road Magnetic Grey
    OME 3" lift, LR UCA's, 1.25" wheel spacers, custom Homertaco grill, horn relocation, BFG KM2's 285/75-16, alarm w/ remote start
    Thanks to the OP for this write up. Without it I would not have attempted this myself. I have 49K miles and cleaned the MAF as well as the throttle body in conjunction with changing the plugs and the difference is awesome. I didn't realize how sluggish my truck was feeling before.
