How To: Throttle body cleaning 2005+ V6
Discussion in 'Technical Chat' started by genxer36, May 23, 2010.
  1. Aug 30, 2010 at 12:38 PM
    WARGASM723
    WARGASM723 Member
    Mission,TX
    2005 Toyota Tacoma TRD
    But it says on the can "for best results, do this every time you change your air filter" I just changed my filter about 2 months ago and did the throttle cleaning today. *sigh*
  2. Sep 12, 2010 at 1:11 AM
    Taco11
    Taco11 Well-Known Member
    Seattle WA
    Technically you should never have to clean your MAF unless you run oiled filters like K&N. Certainly not every time you change your filter. Cleaning the TB however is a good thing to do.
  3. Sep 20, 2010 at 11:55 PM
    alextdunn
    alextdunn Active Member
    alex
    san Diego
    05, 4cly, base, Xtra cab, 5 lug lift
    ready lift 5 Lug lift, bed lights, 400 watt inverter, scan gauge II, AFE pro Dry s, second air filter removed
    Grate write up !!
    good job on the pics.
    Just did mine on my 4 banger, noticed a big improvement in performance and in MPG for the first two days. dont know if the 400 mile drive back got it that dirty or i got use to it that quick but now i dont notice the improvement as much.
    I took out the two screws on top of the MFs disconnected it and spayed it then placed it in a paper towel to make sure it did not get dirty, while to took the rest apart and cleaned that. not to bad it is failry well protected just dont poke it or drop it.
  4. Sep 20, 2010 at 11:58 PM
    alextdunn
    alex
    san Diego
    I looked in my tech manual and it stated to replace the gasket so i did not take the throttle body off. is it a rubber/reusable gasket or more of a one time use paper one ??
  5. Oct 24, 2010 at 7:09 PM
    ArmyEN in VA
    ArmyEN in VA New Member
    Northern VA
    05 Silver TRD 4x4
    5100's
    Thanks for the info - took me all of 20 or so minutes. It was pretty nasty at 77K miles. Great job on the pics.
  6. Nov 5, 2010 at 4:17 PM
    milehitaco
    milehitaco Member
    THORNTON,CO
    06TACOMA DOUBLE CAB 4X4 SR5 OFFROAD
    outstanding, The dealer probably charges $1699.99 for this service.:):p:):p:):p
  7. Nov 5, 2010 at 4:23 PM
    trd7
    trd7 4wd tacoma
    Tyler
    Columbia, SC
    95.5 Tacoma 4x4 4cyl auto
    AEM air intake
    Has anyone cleaned their throttle body in a 1st gen?
  8. Nov 13, 2010 at 4:29 PM
    Hams98
    Hams98 Member
    Bryan
    Alexandria, VA
    06 DC PreRunner
    K&N RAM Air Intake Altezza Tail lights
    Great Write Up! You would be amazed how dirty throttle bodies can get even if just using a stock air box. If you use an after market ram air intake or cold air you should do this every 25k miles or so. If not maybe at the 75k mile mark should be fine. In between to keep it somewhat clean, I like to not only inject seafoam right into the intake manifold but I'll also remove the air filter and spray it directly at the throttle body.
    Don't under estimate the effect on gas mileage that a dirty throttle body can have, especially when it does not let your truck idle normally, the computer will compensate with more fuel.
  9. Nov 16, 2010 at 1:22 PM
    blahablaha
    blahablaha Member
    Father
    KS
    2006 Silver 4WD v6 manual
    Thanks to the creator of this walk-through. I'm a new Taco owner and found this extremely helpful for getting to the bottom of my troubles with low-end responsiveness and gurgling from an over-oiled K&N air filter!
    All squared away now, though, and lessons learned.
  10. Nov 21, 2010 at 4:14 PM
    genxer36
    genxer36 [OP] Lord of Tomfoolery
    Sean
    Bethlehem,GA
    Tow package, XM Satellite radio, K & N Air filter, & Channel Vent Visors
    Thanks. Just trying to help. The first time I did it, I was kinda shooting in the dark. Was going from a written direction. So I figured it needed a good write up with pictures.
  11. Jan 3, 2011 at 10:06 PM
    GiverDeaner
    GiverDeaner Member
    Kevin
    Kamloops,BC
    Nicest 2ndGen in town Wannabe
    3"lift,33/11.5's,TRD Bronze rims,HID fogs and headlights,All LED's,Black front lip,Fogs on when high beams on mod.
    Is this service necessary if your running a paper OEM filter as only air passes through the throttle body ?
  12. Jan 3, 2011 at 11:03 PM
    genxer36
    Sean
    Bethlehem,GA
    Yes. You will notice a big difference in power gains when you clean it the first time. My truck was lagging at start off. I cleaned mine @ 80k miles & again at 130k. The truck felt invigorated like it had regained the lost power. The first cleaning it was caked with carbon. The 2nd cleaning, it wasn't as bad.
    The pictures & write up I did was from the 2nd cleaning.
    The can says that so they can sell more product. I will do mine again, when my truck seems sluggish.
  13. Jan 3, 2011 at 11:19 PM
    kraxtra
    kraxtra Well-Known Member
    Kenwood
    Parker, CO
    06 TRD Offroad
    K&N CAI, Dynomax Super Turbo Catback, Westin Step, ARE LoPro tnneau, debagded
    Great write-up! I'm at 78k and I know what I'm doing this weekend...
  14. Jan 20, 2011 at 12:57 PM
    Tacomanator
    Tacomanator Boiling denim and bangin whores
    Clam Slammer
    Southern Cali
    King 2.5" extended travel coilovers with compression adjusters, Camburg UCA's, King 2.5" rear shocks, TRD 1st gen CAI.
    great write up! ill be doing this tomorrow or sometime this weekend
  15. Feb 1, 2011 at 5:11 PM
    #35
    jjw1
    jjw1 Well-Known Member
    Jesse
    Citrus County Florida
    2011 Super White DCSB TRD OR PreRunner
    Weather Tech Floor Liners, Truxedo Bed Cover, OEM Silver Step Bars, Debadged, Colormatched Satoshi, Wet Okoles, OEM Roof Rack, Bed Mat, Locking Gas Cap, and removed Mud Flaps
    sub'd
  16. Feb 1, 2011 at 6:55 PM
    #36
    mattygabe
    mattygabe Well-Known Member
    Western PA
    2011 Access Cab SR5
    Access Limited Soft Rollup Tonneau Cover
    Yeah, great effort on that. I was going to say, you don't even need Photoshop (and its $600 license, ahem...). Paint.NET is free, and provides a really nifty arrow tool. Maybe I'll provide a quick screenshotted tour of how to do that in the Computers section and link it here.
  17. Feb 7, 2011 at 10:27 PM
    #37
    genxer36
    Sean
    Bethlehem,GA
    I use paint.net occasionally. I can do basic stuff. Still learning. It was quicker to use the box lid arrows.
  18. Feb 17, 2011 at 3:32 PM
    #38
    Taco93
    Taco93 Well-Known Member
    Milton, Ontario
    2011 TRD Sport
    Extang Trifecta Tonneau, Weathertech Floor Liners
    I just done this on my 06 Taco and boy was it due for a cleaning. I expected it to be dirty but the black gunk I cleaned off the throttle body was just like tar. Also, inside the black part it connects to was coated in the black gunk. I don't think it has been done for the lifetime of this truck. Anyhow, just a thanks for this write-up. Well Appreciated.
  19. Feb 17, 2011 at 3:35 PM
    #39
    genxer36
    Sean
    Bethlehem,GA
    You are welcome. You should notice a difference on power right away. I know I did when I went for a test drive after cleaning mine.
  20. Feb 25, 2011 at 9:38 PM
    #40
    fullback
    fullback Well-Known Member
    NJ
    Double Cab TRD short bed
    HI Sean nice demo on the clean up very clear. now my question before i go to the Dealer
    i have 2009 TACO 4x4 V6 48000 miles 90% TPK Hwy driving, 3 weeks ago i noticed as i am driving i hear a humming from the engine, not engine sound , but like some thing spining freely in the background , i noticed today That when i am cruising ,and i let off the gas pedal the Tachometer does not drop instantly, should it??? could this be dirt and GUM issue in the Air flow sensor, would a cleaning like you described here help at this point , also i use regular Gas from a no brand gas station in the Truck. any suggestion is helpful Thanx
