How To Trouble Shoot 4x4 Actuator
Discussion in '2nd Gen. Tacomas (2005-2015)' started by blackhawke88, Feb 15, 2013.
  1. Sep 12, 2016 at 5:28 PM
    #201
    Smar969905
    Smar969905 ToyotaLover
    Zach
    Deer Park, WA
    96 Dodge 12valve cummins- mine, 16 T4R - wife's, 11 Taco - totalled
    Are you mechanically inclined? Do you have basic tools available and a sauldering iron, saulder, and flux? If you answered yes to both of those, you don't need to buy the ADD front diff actuator. Pull your skid plate off, remove the bolts that hold the front diff arms on, then remove the ADD by removing 4bolts. See first page for pics. Now remove 5 philips screws, pull black cover off, and check the ADD motor leads for discoloration or singe spots. Saulder those (again, refer to first page for pics). Put everything back together. Test 4x4.
    I am 3.5 hours from home for work, seeing the same symptoms on my truck, but going home this weekend and plan to take care of it then.
  2. Sep 12, 2016 at 9:49 PM
    #202
    SoTexTacoma
    SoTexTacoma Well-Known Member
    Whidbey Island
    '14 TRDOffroad
    BP-51 w/Dakars MobTown Hybrid Bumper All-Pro skids Redline Hood Struts AllPro bed bars A lot, really.
    I have the symptoms on my sons 4wd. Problem is, his truck has a DB lift installed and it seems the bracket is in the way. We tried to pull the actuator off and the damn bracket is in the way. Anyone with this kind of lift have a solution? We want to plan a trip soon but his truck won't go into 4wd for nothing. Anybody
  3. Sep 12, 2016 at 10:16 PM
    #203
    Tacomaui
    Tacomaui Well-Known Member
    Middle of the Pacific Maui, Hawaii
    2007 TRD Double cab 4x4
    3" Revtek kit, , Wet Okole seat covers. Now with 285/70/17 BFG all terains on Moto Metal 955 17x9 chrome wheels. Tube steps, Tinted windows. Used to have 265/70/17 BFG all terrains on Mickey Thompson Classic Bead lock wheels,
    I can do it no problem. Used to be a auto mechanic for 25+ years so I have all the tools. I installed the lift on it myself as well as lifted several other trucks for friends. Did get the truck in the air this past weekend and tried it. Transfer case engages and front drive shaft spins but front wheels remain free wheeling so pretty sure the front actuator is the culprit. Hopefully will have some time to attack it this coming weekend. Just kind of bummed because I only had the truck in 4wd once before and now go to use it again it doesn't work. Truck is well maintained and never abused with only 30000 miles. Thanks for the help!
  4. Sep 18, 2016 at 10:08 AM
    #204
    Tacomaui
    UPDATE
    Worked on the truck yesterday. Pulled the ADD out. Top left bolt wasn't easy to remove but not too bad with a 1/4" ratchet and a short extension. Funny how that one was the tightest of all 4. Since I had a new ADD on hand and time was a big factor I just installed the new one. Took me about 2 hours total including time to run to the store to get a hose to put on the bottle of oil so I could refill the front diff. After all was put back together took the truck for a test drive. It works! Goes right into 4HI and 4LO no problem and lights come on solid. Haven't done an autopsy on the old unit yet. Got a little injury on my finger when removing the jack stands. (Don't put your hand under the stand when releasing it). I'll just play with the old one first chance I get and If I can get it to work I'll just keep it as a spare. My son has a 2011 Tacoma so he may need one eventually.
  5. Sep 24, 2016 at 10:52 PM
    #205
    wachuko
    wachuko Well-Known Member
    Orlando, FL
    WTB-2019 Tacoma Double Cab TRD Off Road 4x4
    Very thankful for this thread. Got a call from my brother today asking about issues with the 4WD on his father-in-law 2008 Toyota Tacoma. After a quick search, this thread came up... sure enough, the issue that Tacoma was having was related to the actuator. Internals were corroded, and some contacts were beyond repair. A new one is on the way to replace it and get the 4WD back working again.
    86a3f972-c740-4734-83b9-5ff4ba0d1d8d_zps_2e4c29ebdba0939fd5ee7c6c7c27af67f9c8c45a.jpg
    6527f5a1-5c97-4809-b5ea-ef75aa7b6d97_zps_b1e8e8351f6d91b56b2786b23a6e64a27ea2eb31.jpg
  6. Oct 10, 2016 at 11:09 AM
    #206
    jhinderliter
    jhinderliter Well-Known Member
    West central il
    2009 Double Cab TRD Off Road
    Any one getting a ratcheting sound from the front when it's trying to disengage ? Like a card in the spokes for us old timers lol
    Thanks
  7. Oct 10, 2016 at 6:46 PM
    #207
    hobiecat111629
    hobiecat111629 Well-Known Member
    2015 Tacoma Access Cab
    I had a Jeep Comanche that issues with the vacuum actuator on the dana 30 and ended up drilling the shift fork and running a cable to the cab to be able to kick the actuator over manually. It really worked out pretty well and gave me 2low if I shifted the transfer case to 4 low and left the actuator on the front axle in the "open" position.
    The Tacoma actuator looks similar, but I expect a similar mod would piss odd the electronics
  8. Oct 13, 2016 at 8:29 AM
    #208
    jhinderliter
    West central il
    Anyone?
    Thanks
  9. Oct 13, 2016 at 8:53 AM
    #209
    Smar969905
    Zach
    Deer Park, WA
    No ratcheting sounds for me. Check your CVs though. They will make that clicking noise when they are going out, especially in turns. Clicking on right turn is typically right CV axle IIRC
  10. Oct 13, 2016 at 10:09 AM
    #210
    jhinderliter
    West central il
    Its not a CV , when I disengage 4 High the light blinks and I get a ratcheting noise from the front right ish... wondered if I had an actuator hanging up...
  11. Oct 13, 2016 at 11:25 AM
    #211
    Smar969905
    Zach
    Deer Park, WA
    Could be missing teeth on part of gearing so it doesn't fully disengage. Tear it open and see what there is to see. While in there, do the solder mod to keep from having to get into it to do it later.
  12. Oct 13, 2016 at 9:00 PM
    #212
    Tacomaui
    No noise from mine. Meant to do the solder mod on the new one before I installed it. Only remembered after the job was done. o_O. At least it still works!
  13. Oct 16, 2016 at 3:21 PM
    #213
    Smar969905
    Zach
    Deer Park, WA
    Finally got home and pulled skid plate to get to ADD. Top 2 bolts aren't as hard with about 9" of extension once front diff bolts are pulled off. Just put 12 mm socket on extensions, and feed around hard line from the front of truck.
    Found my ADD in near perfect condition on the inside, no solder needed. My problem is that a gear was broken.
    I also looked up the part, and part number for ADD is 41400-35033
  14. Oct 16, 2016 at 5:17 PM
    #214
    Tacomaui
    I got mine from EBay. Dealer wanted a little over $400.00 for the part. Got it for 247.95. Genuine OEM part. Still works!
    Took my old one apart and it looks like new on the inside. No broken gears or anything. Have no clue why it wouldn't work. Just going to keep it for a spare.
  15. Oct 16, 2016 at 5:32 PM
    #215
    4x4Hank
    4x4Hank Member
    Steven
    2002 Tacoma TRD
    First I want to thank blackhawke88 for posting this info. I was about to go in blind until I came across this thread.
    The vacuum line to my 2002 Transfer Case Actuator broke and allowed water to corrode my actuator. I was able to rebuild it. I put a short post together in the Gen 1 area and wanted to share it here too. The TC Actuator Assembly looks like it is the same on the Gen 2 trucks.
    https://www.tacomaworld.com/threads/4x4-actuators-gen-1.456059/
  16. Oct 16, 2016 at 9:39 PM
    #216
    Smar969905
    Zach
    Deer Park, WA
    Thought about you when I was putting my ADD back on until I can either replace it or the gearing inside. I jacked up my front end with ADD off and tried spinning front wheels to make sure I was keeping front diff disconnected. When I had the slide to what would put front diff connected, then spun wheels, I could hear a light clicking noise. Are you able to go between 2hi and 4hi without problems?
  17. Oct 20, 2016 at 7:21 PM
    #217
    Smar969905
    Zach
    Deer Park, WA
    Got lucky, found a new actuator on eBay for $200 plus $15 shipping. It was also the last one from the seller. Hopefully it arrives home before I do next weekend so I can get my truck back up to par
  18. Dec 13, 2016 at 4:28 AM
    #218
    NewfoundlandTaco
    NewfoundlandTaco Well-Known Member
    Newfoundland, Canada
    06 TRD Offroad Indigo Ink
    Billy 5100 at 2.5", 1.5" blocks, tailgate theft mod, extra bed D-rings. General Grabber AT2's.
    Having some trouble with my 4wd as well, however this morning it was being weird. I turn to 4HI and it'll go in, light solid, then it'll start flashing green with the 4LO. Then after some driving it'll go back solid green. But then numerous times it'll start flashing again while driving even though it is in 4HI, it really is in cause I can feel it in the snow. This seems like an electrical problem to me... Had a new chassis in August and haven't used the 4wd until this week. Maybe a lose ground or plug?
  19. Dec 13, 2016 at 2:16 PM
    #219
    Smar969905
    Zach
    Deer Park, WA
    Are you following direction on putting it into 4lo found on driver visor? What do you need 4lo for? 4hi spins front and rear differentials, and the only thing 4lo gives you from there is low range gearing where you hit top reasonable speed of something about 35-40 ish.
    In case you don't have the idiot guide to shifting between 4hi and low, have the truck completely stopped. In manual transmission, put in the clutch all the way, then turn knob. In automatic, put transmission in neutral, then turn knob.
  20. Dec 13, 2016 at 9:09 PM
    #220
    excorcist
    excorcist Well-Known Member
    Reno, NV
    '06 dcsb, '86 pickup, '89 runner
    My 4 hi and 4 lo gives me problems every now and then with just getting the blinking light and a big clunk when going back to 2wd.
    Was going to pop open my ADD actuator to have a look, and I have a 6'' Drop bracket lift, did you guys get yours out ok?
