How To Trouble Shoot 4x4 Actuator
Discussion in '2nd Gen. Tacomas (2005-2015)' started by blackhawke88, Feb 15, 2013.
  1. Apr 25, 2017 at 7:22 AM
    #261
    VolcomTacoma
    VolcomTacoma Well-Known Member
    Jeff
    NorCal
    2015 TRD Sport 4x4 6 Speed Supercharged
    Front- Camburg 4x4 Long Travel 2.5" King Coilovers 2.5" King Triple Bypasses Wheelers Superbumps Rear- DMZ SUA 16" 3.0 King Triple Bypasses 3" 2.0 Fox bumps Wheels and Tires- 295/75/16 Toyo ATII XTREME SCS SR8 Dark Matte Bronze 16" Lighting- (2) 30" Combo light bars (4) Iggycorp diffused pods Tepui Ayer TRD Supercharger URD Mark III 3" Exhaust URD 4x4 Y Pipe URD CAI URD 2.85 Stealth Pulley Hurst Core Shifter with Hurst T URD Stage 3 clutch URD Lightweight flywheel URD Throw out bearing upgrade AEM Wideband AFR Gauge Speedhut Boost Gauge Craven Speed Flex Pod mount Weathertech Floor Liners BAMF Sliders Ultragauge sPod SE ARB CKMTA12 Hella Supertone horns Relentless Tailgate Reinforcement
    You do need to drain the diff otherwise it's allllllll coming out from that actuator hole lol. Maybe if you lift the passenger side of the truck up a foot or two you might be able to not drain some, but it's really not all that hard
    uurx[QUOTED] likes this.
  2. Apr 25, 2017 at 8:27 AM
    #262
    B3dlam
    B3dlam Member
    Zach
    2011 Tacoma TRX pro Manual 6spd
    VHF/UHF radio
    Soldering upside down in a teeny space? Sounds like working on helicopters :-D. Ill drop the skid plate and take a look at the space in the next couple of days and decide where to go from there.
  3. Apr 25, 2017 at 11:44 AM
    #263
    VolcomTacoma
    Jeff
    NorCal
    You're talking about 3" or so in front of the crossmember. Even dropping the diff down and holding it down only clears about half of the actuator. Sounds like putting in way more work to avoid draining some oil lol. Get a clean catch can, wear some gloves, drain it, remove actuator, fix, do it all in reverse. Shouldn't take more than an hour TOPS
  4. Apr 25, 2017 at 1:43 PM
    #264
    B3dlam
    B3dlam Member
    Zach
    VHF/UHF radio
    I
    I'll likely end up just draining than replacing the oil after I reinstall it.
  5. May 19, 2017 at 2:27 PM
    #265
    uurx
    uurx Well-Known Member
    long island, new york
    '12 t|x pro
    2500-4000!!!! o_O
    this is by far the highest price i have seen quoted
    the part new on eBay can be had for under 300 and in many cases under 200, and that is a toyota branded part not an aftermarket unit!!!
    the labor is not that tough, it is tricky maybe but it sure is not pulling out a transmission or something..
    they are quoting way too high if you ask me
  6. May 19, 2017 at 2:39 PM
    #266
    uurx
    '12 t|x pro
    interesting, i have not had the problem getting stuck in 4hi
    my issue has been not being able to get the light to stay on in 4hi, it keeps flashing so I can not use 4lo but I know for sure 4hi is engaged
    In my case my ADD will not turn 4hi off as well, I have to turn the dial to 2wd then turn the car off fully, turn key on engine off you should hear the clunk of 4hi disengagement
  7. May 19, 2017 at 4:14 PM
    #267
    la0d0g
    running for the hills
    For crawling not hauling
    :laughing:
  8. May 19, 2017 at 7:47 PM
    #268
    VolcomTacoma
    Jeff
    NorCal
    Wow. Trouble shoot that shit yourself. Put it in 4x4, if your front driveshaft won't turn, its your front diff actuator. If it turns, then its something in your Transfer case. I'd try replacing your actuators yourself first before going with the dealer
  9. Jun 10, 2017 at 10:35 PM
    #269
    Charlie213
    Charlie213 Well-Known Member
    San Gabriel Valley, CA
    06 OR TRD 6speed DCSB 4X4
    I just installed a new front ADD thinking it would fix my 4hi not engaging and still nothing. Is there a relay or something else I'm missing? I checked the fuse below drivers side and it's good. I'm almost certain the ADD is not getting power because each time I switch to 4hi I don't hear any noise or clicks coming from the actuator motor. Could it be my 4WD ECU went bad?
  10. Jun 11, 2017 at 8:32 AM
    #270
    VolcomTacoma
    Jeff
    NorCal
    Can you hear your actuator in your Transfer case click? Did you try taking apart the Front Diff actuator and see if the motor is still connected?
  11. Jun 11, 2017 at 8:42 AM
    #271
    Charlie213
    I don't hear anything at all. The green light blinks soon as I turn on my truck without it being in 4hi. I recall when everything worked the moment I switched the knob to 4hi I heard the actuator motor work in the front add. It seems like it's locked out somehow and I can't get it to reset. I pulled my select knob switch and tested it per the Toyota specs and it's good. I'm stumped and can't figure it out. I applied voltage to the new actuator and it moves the fork without any problems so the motor is getting voltage.
  12. Jun 11, 2017 at 8:49 AM
    #272
    uurx
    '12 t|x pro
    is it just me or does it seem like us with 6 speeds are having these add issues more so than the automatics...???
    @Charlie213 you purchased a brand spankin new one?? from a dealership? or dealership via eBay maybe??
  13. Jun 11, 2017 at 8:50 AM
    #273
    VolcomTacoma
    Jeff
    NorCal
    Have someone else turn the knob while you hold your face next to your transfer case actuator, you should hear a click, AND you front driveshaft should be solid at that point. If nothing happens it means your transfer case actuator is either dead or not receiving power. If you hear it click and your DS is solid, do the whole thing again but hold your face next to the front differential actuator, if you hear nothing, do the thing on the front page of this thread.
  14. Jun 11, 2017 at 8:59 AM
    #274
    Charlie213
    I got it from Cameltoyota. It looks legit.
  15. Jun 11, 2017 at 9:03 AM
    #275
    Charlie213
    Is there a way to reset the system. I feel like the green light blinking won't allow me to do anything. I'm going to unplug my 4WD ECU and see if that resets it.
  16. Jun 11, 2017 at 9:04 AM
    #276
    VolcomTacoma
    Jeff
    NorCal
    Put 4x4 knob back to 2WD, turn truck off completely, take keys out, open and close door
  17. Jun 11, 2017 at 10:12 AM
    #277
    Charlie213
    That worked before but now it doesn't want to stop blinking. At times the 4Lo decides to start blinking and this is with the switch on 2WD
  18. Jun 11, 2017 at 10:13 AM
    #278
    VolcomTacoma
    Jeff
    NorCal
    pull your positive battery cable off for like 15 minutes, then try what I told you to do before to find out where its at. If there is an issue, this will not clear the issue, it will simply reset the computer and anything on the dash flashing for now. Unless your actuators are stuck in place, then it wont clear shit and you're either gonna be on your back wrenching for a while, or your about to spend alot of money at the dealership.
  19. Jun 18, 2017 at 10:56 PM
    #279
    MJonaGS32
    MJonaGS32 MJ on a GS
    MJ
    SF Bay Area (East)
    07 LT 4x4 DCSB 6spd Vagabond
    Drifter wedge camper, Dual battery, OBA, ARB locker, 4.56 gears
    Gonna have to pull the skids off and trouble shoot this.
    Thanks @blackhawke88 for the info
  20. Jun 27, 2017 at 9:16 PM
    #280
    MJonaGS32
    MJ
    SF Bay Area (East)
    Thought I'd update my findings. Front actuator looked prestine (10 yr old truck w/ lots of wheeling). But the transfer case actuator was a diff story
    Water snuck in through the breather hole (more on that later) and the water was causing the electical current to connect all metal contacting points - which is what you don't want. I read somewhere on here that someone put dialectic grease on there, but you dont want to do that either for the same reason.
    After cleaning the gunk, one of the metal contacts was corroded just like someone had posted in this thread
    The reason is because the way the actuator sits, when water is in there it will rest in that area. But the good thing is that its not completely corroded through. I literally put it back together just as you're seeing it - no grease, extra soldering, etc.
    So the moral of the story, if you're going to submerge the underside of the truck in water, make sure the breather hose is in good condition. Mine was frayed pretty bad so I cut the frayed section off
    Then I put the hose back on and ziptied it
