How To Trouble Shoot 4x4 Actuator
Discussion in '2nd Gen. Tacomas (2005-2015)' started by blackhawke88, Feb 15, 2013.
  1. Sep 26, 2017 at 6:06 PM
    #321
    PyriteNH12
    PyriteNH12 Member
    NH
    '12 Reg Cab 4x4 5spd
    GY Duratrac 265/75R16, Thrush exhaust, 32" LED bar
    Front ADD actuator is also beeping when plugged in and switched to 4HI.
    uurx likes this.
  2. Sep 27, 2017 at 6:01 AM
    #322
    uurx
    uurx Well-Known Member
    long island, new york
    '12 t|x pro
    @PyriteNH12 have you removed and inspected inside the transfer case actuator?
  3. Sep 27, 2017 at 8:52 AM
    #323
    PyriteNH12
    PyriteNH12 Member
    NH
    I haven't done this, was hoping to rule out the transfer case actuator since it responds and engages the front drive shaft. I have performed a resistance check on both detection switches on the transfer case near the transfer case actuator and they check OK.
    uurx[QUOTED] likes this.
  4. Sep 27, 2017 at 9:08 AM
    #324
    uurx
    '12 t|x pro
    when you opened up the front actuator for inspection, aside from soldering and cleaning.... did you also bend the three prongs slightly to ensure contact??
    here is a picture stolen from @jberry813 as well as a link to his thread explaining the steps he took.
    https://www.tacomaworld.com/threads...-moderator-with-a-tacoma-build.455075/page-42
  5. Sep 27, 2017 at 10:58 AM
    #325
    PyriteNH12
    PyriteNH12 Member
    NH
    @uurx Yep checked that. I actually popped the cover off again to double check and those three drag prongs are contacting fine. They are making a perfect trail through the new grease.
    I'm going to rig of a relay test circuit later today. Per TSM, they want you to "create a circuit" using a fuel pump relay to test the ADD then perform resistance check. This will be my last step before ordering an actuator.
    uurx likes this.
  6. Sep 27, 2017 at 11:05 AM
    #326
    uurx
    '12 t|x pro
    g/l keep us posted
  7. Oct 3, 2017 at 5:16 PM
    #327
    Imacunta
    Imacunta New Member
    Thanks men , a lot if helpful info here
  8. Nov 12, 2017 at 12:54 PM
    #328
    mightytacoman
    mightytacoman Mighty-known Member
    Kel
    4.5L 1grfe
    Brian Crower stroker kit, Carrillo pistons moly/ceramic coated, BC sportsman rods, arp s2000 head bolts, Darton M.I.D sleeves, Kelford race cams, Magnusson supercharger, hp tuner tuned, 650cc flow matched fuel injectors, CSF radiator, Walbro 255 fuel pump. pulleyboys quick change pulley with 2.3", fpr mod, NST crank, water and alternator pullies, 160° mishimoto thermostat. Puma On-board air, Radflo CDC ext coilovers with 14" 700# springs, extended length rear Radflo shocks with CDC, Dakar leak pack, Brute Force Fab front bumper galvanized and powder coated, DTRL mod, yellow fogs, fog anytime mod, relocated rear differential breather, synthetic fluids, custom airbox, tundra sized intake. 76mm throttle body, secondary air filter removed, Airflow snorkel, 4x innovation sliders powder coated, URD equal length headers, DT y-pipe, Aero-Turbine 2525xl exhaust dumped over axle, seat belt chime disabled, Warn 8000i winch, 1- 20" slim light bar in grill, 42" curved roof light both with custom brackets. Mesh grill, Brute Force Fab rear bumper with extra reverse lights, u bolt flip kit, SS extended brake lines, hockey puck bump stop extension, AT shackle flip kit, Light Racing UCA's, 4crawler 1.5" bodylift. custom built front and mid skid plates, re-geared to 4.56s, windows tinted 25%, Sony stereo, 8" skar sub-woofer, 1000 watt mono amp, retrofit headlights with legal demon eye, Kryptek Marathon seat covers. North Star agm 27f battery, Helo 791 rims, 315/75/r16 Mt/r ARB front air locker
    Could use some help guys. Truck started giving me issues in the cold weather last winter with not wanting to fully shift between 2wd/4wd/4lo. Went away in the summer so I forgot about it. Now its cold and not working again. Original main issue was it would shift into 4wd and back into 2wd but 4wd light would continue to flash. I took apart the front add actuator, soldered and bench tested the parts to confirm function. Reinstalled and problem persists. Removed transfer case actuator and cleaned up the inside of that + bench tested motor. Now here is my current issue- I push the shaft on the t-case all the way forward (2wd), set trans actuator to what I believe is the correct timing for this phase. Switch inside truck is on 2wd. When I turn key on, the trans actuator turns the wrong way and puts the truck in 4wd (steady light in dash) and 4lo light blinking on the dash. Before I turn the key, I confirmed that the truck is in fact in 2wd. Im at a loss of what to do next. Please help.
  9. Nov 14, 2017 at 8:57 AM
    #329
    Manwithoutaplan
    ID
    this really needs to be a sticky!
  10. Nov 14, 2017 at 10:27 AM
    #330
    mightytacoman
    Kel
    4.5L 1grfe
    Bump with problem still persisting.
    My current plan is to have the actuator off the transfer case yet fully assembled. From there I'll be able to reach into the actuator and apply pressure to the two sensors that tell the 4wd ecm where the transfer case is currently keyed. If these sensors aren't satisfying the 4x4 ecm, I don't believe power can/will be sent to the actuator. Only two sensors with two locations for each sensor (in and out). I'll try all variables to see if I have the transfer case a few teeth off on the selector rod or if it's those sensors that have shit the bed. Those sensors "rarely go bad" but then again, rarely do people drive fully flooded vehicles. Up coming weekends project
  11. Nov 17, 2017 at 1:55 PM
    #331
    mightytacoman
    Kel
    4.5L 1grfe
    Next bump. I now know that I have the front ADD keyed correctly and in the right place (all the way passenger for 2wd). The trans actuator is key correctly as well. The small gear is sitting on the 3rd tooth of the shifting rod which is also correct for 2wd. Front drive shaft spins freely. The switch inside the cab is in the 2wd position matching all other variables. When key is turned- nothing happens at either actuator now. 4x4 and 4lo lights continue to blink. Anyone care to make a suggestion or know how to manually reset the 4x4 ecm memory. I'm all ears:confused:
  12. Nov 20, 2017 at 8:37 AM
    #332
    Subway4X4
    Subway4X4 Shameless Copy Cat
    Lloyd
    NY/NJ
    05 Speedway Blue DCSB OR TRD
    Everything TW members recommend
    @Lux - for 2nd gen actuator, but some stuff might apply to your 1st gen.
    Lux likes this.
  13. Nov 21, 2017 at 8:08 AM
    #333
    mightytacoman
    Kel
    4.5L 1grfe
    Bump, was able to get the lights off on the dash by keying everything to 4lo then slowly working everything into 2wd again with the key going on and off multiple times. The sensors on the transfer case actuator are Toyota part number 84222-12010 and 84222-35121. The 12010 sensor has alternate part numbers but the 35121 doesn't seem to have any other manufacturer than Toyota. 12010 alternate part numbers are-- Napa ns6421, Acdelco e2209a, Echlin 8950, Beck/Arnley 201-1788, Standard Motor Products ls228, and Airtex/Wells 1s5826.
    After I got everything into 2wd, I had my dad hit 4wd while I watched the trans actuator fail to turn the small gear (small cover with 3, 8mm screws was off) it didn't have the power to pull the shift rod outta the transfer housing telling me the motor on it is shot even after a rebuild so I'm forced to purchase a new one. When the new one is on, I'll update here.
    la0d0g likes this.
  14. Nov 21, 2017 at 3:47 PM
    #334
    Armed in Utah
    Armed in Utah Well-Known Member
    Utah's High Desert.......
    2003 Lexus LX 470
    OMG........
    bump to top
  15. Nov 21, 2017 at 3:54 PM
    #335
    05Taco4x4
    05Taco4x4 ToyotaHubs
    2TR-FE Enthusiast
    FJ Tcase, Manual Hubs, 2017 Head unit, Mirror Riser
    FJ transfer case and manual hubs ftw
    GilbertOz, mightytacoman and vssman like this.
  16. Nov 21, 2017 at 4:00 PM
    #336
    mightytacoman
    Kel
    4.5L 1grfe
    That is one of the best options but certainly not the easiest or cheap. With that said, looks like you did a nice job doing it on your build.
    05Taco4x4[QUOTED] likes this.
  17. Nov 21, 2017 at 4:09 PM
    #337
    Armed in Utah
    2003 Lexus LX 470
    nice build........I see the X/fer case.........
  18. Nov 21, 2017 at 4:09 PM
    #338
    mightytacoman
    Kel
    4.5L 1grfe
    rock solid toys can set you up with a quote.
  19. Nov 24, 2017 at 2:11 PM
    #339
    Karpaasi
    Karpaasi Well-Known Member
    Rob
    The Old North State
    '07 AC 4 cyl. 4x4
    After discovering that my 4x4 wasn't working ('07 manual 4 banger), I've been trying to diagnose the issue. In my case, like many others, it was the ADD actuator. However, it wasn't the contacts. The small DC motor inside the actuator wasn't turning. The inside of my actuator was clean, so I can only assume that my lack of "exercising" the 4x4 system, including this motor, caused the issue. Anyhow, it was easy enough to get it free - I connected a 9 volt battery to the motor. The motor didn't want to spin at first, but seems to work just fine now. And now the actuator drives the sleeve in the front differential.
    The only reason I mention this is that I read everywhere that the contacts inside the actuator might be the culprit. I only thought to check the motor after discovering my contacts were fine.
  20. Nov 24, 2017 at 2:59 PM
    #340
    Armed in Utah
    2003 Lexus LX 470
    playing with mine....the Tacoma.................
    goes in/out of 4H......but seems the 4L in/out is the issue......
    have to turn key....restart...you know.......before it will go back to 2H.......
    W T F Toyota.........
