How To Trouble Shoot 4x4 Actuator
Discussion in '2nd Gen. Tacomas (2005-2015)' started by blackhawke88, Feb 15, 2013.
  1. Nov 24, 2017 at 4:28 PM
    #341
    la0d0g
    running for the hills
    For crawling not hauling
    How often do you use it?
  2. Dec 5, 2017 at 8:06 PM
    #342
    lancewood
    lancewood Active Member
    lance
    British Columbia Canada
    09 tocoma 2.7L access cab 4×4
    So I have taking apart my front actuator cleaned and soldered it, put it back together and still have the 4wd light blinking and 4lo not working at all! 4 hi seams to engage sometimes but light still blinks. The only reason I know 4 hi is engaging at random times when I flick the switch is when I drive in circles. Anyone know why this is happening? I want to fix this!
  3. Dec 6, 2017 at 4:41 AM
    #343
    mightytacoman
    mightytacoman Mighty-known Member
    Kel
    4.5L 1grfe
    Brian Crower stroker kit, Carrillo pistons moly/ceramic coated, BC sportsman rods, arp s2000 head bolts, Darton M.I.D sleeves, Kelford race cams, Magnusson supercharger, hp tuner tuned, 650cc flow matched fuel injectors, CSF radiator, Walbro 255 fuel pump. pulleyboys quick change pulley with 2.3", fpr mod, NST crank, water and alternator pullies, 160° mishimoto thermostat. Puma On-board air, Radflo CDC ext coilovers with 14" 700# springs, extended length rear Radflo shocks with CDC, Dakar leak pack, Brute Force Fab front bumper galvanized and powder coated, DTRL mod, yellow fogs, fog anytime mod, relocated rear differential breather, synthetic fluids, custom airbox, tundra sized intake. 76mm throttle body, secondary air filter removed, Airflow snorkel, 4x innovation sliders powder coated, URD equal length headers, DT y-pipe, Aero-Turbine 2525xl exhaust dumped over axle, seat belt chime disabled, Warn 8000i winch, 1- 20" slim light bar in grill, 42" curved roof light both with custom brackets. Mesh grill, Brute Force Fab rear bumper with extra reverse lights, u bolt flip kit, SS extended brake lines, hockey puck bump stop extension, AT shackle flip kit, Light Racing UCA's, 4crawler 1.5" bodylift. custom built front and mid skid plates, re-geared to 4.56s, windows tinted 25%, Sony stereo, 8" skar sub-woofer, 1000 watt mono amp, retrofit headlights with legal demon eye, Kryptek Marathon seat covers. North Star agm 27f battery, Helo 791 rims, 315/75/r16 Mt/r ARB front air locker
    The sensors to tell the truck it's in 4wd, 2wd or 4lo are located in the transfer case actuator. Those sensors could be bad or the actuator itself.
  4. Dec 13, 2017 at 5:19 AM
    #344
    NewfoundlandTaco
    NewfoundlandTaco Well-Known Member
    Newfoundland, Canada
    06 TRD Offroad Indigo Ink
    Billy 5100 at 2.5", 1.5" blocks, tailgate theft mod, extra bed D-rings. General Grabber AT2's.
    Replaced my front diff actuator this past weekend and still having the same issues. Truck will shift into 4HI, light will flash even though its in 4HI, switch won't do anything, can't get the truck out of 4HI until after a while it makes a connection and comes out. Any ideas? Tcase?
  5. Dec 13, 2017 at 6:13 AM
    #345
    mightytacoman
    Kel
    4.5L 1grfe
    Replaced trans actuator this past weekend and I'm having the same issue as you. I'll be taking apart the transfer case this weekend or next to attempt to find further problems. Changing the oil in the transfer case did seem to help some.
  6. Jan 8, 2018 at 2:32 PM
    #346
    awolo
    awolo Active Member
    Aaron
    Medina, OH
    05' DCSB TRD Sport SR5
    Guess i'm joining the Club. Went to switch into 4HI and got the dreaded blinking lights. Both the 4wd green light and orange 4LO lights just flashing. They continue to flash until i shut the truck off and let her sit.
    Truck wouldn't switch into anything. Started searching and came across this thread. 18 pages later...i'm going to tackle the ADD fix.
    As a backup I ordered a whole new ADD anyway. Got it from RockAuto for $205 with 2-Day Shipping. This truck has been too good to me for the years I've owned it. $200 is nothing for my old girl.
    My plan:
    - Jack the truck up and perform some quick tests to see whats engaging and whats not while in Drive
    - Check and clean all electrical connections
    - Provide a couple hammer smacks in well placed areas to see if I can knock something loose
    - If nothing changes, remove old ADD
    - Install new ADD
    - Test system and go from there
    When I get the brand new ADD, I plan on opening it up, soldering the 4 weak points and closing her back up with additional sealant, hopefully she it wont need replaced for another 200k! I'm going to take the old one, clean it up and see what can/cant be salvaged for future use, should this issue come back.
    Stay tuned!
    GilbertOz likes this.
  7. Jan 11, 2018 at 9:48 AM
    #347
    awolo
    awolo Active Member
    Aaron
    Medina, OH
    Soooo.....the 4wd just started working when I got home on Tuesday. For kicks, I tried engaging it in my garage with the truck off, and I finally heard all the actuators cycle and move. She went right into 4wd. I verified by doing some donuts in my driveway. WAY MORE GRIP!
    Switched in back between 2HI and 4HI a few times and have been doing so since that day. I'm not sure what happened but oh well. We have more bad weather coming, so hopefully it stays working for a bit.
    The brand new Actuator arrived yesterday. I'm not sure if i'm going to send it back, on just hold onto it until mine fails. Ill probably hold onto it, open it up and solder everything so that when/if the day comes, i can just install it and go.
  8. Jan 11, 2018 at 11:10 AM
    #348
    redzmvt
    redzmvt Well-Known Member
    Scott
    Western Wisc.
    2011 Regular Cab 4x4 Auto stock
    Bone stock for now
    I would keep it.Did you get a Dorman or OEM?Your problem will come back,I have the same thing going on.In early December during the first cold snap,I started my truck and got the flashing green symbol.Switch was in 2HI.About 3 days later,the light stayed off,and all modes worked perfect.More cold weather and flashing again.About three days ago,temps hit 40 and no light.Tried again and perfect again.4HI to 4LO is also perfect with 0 noise.
    My guess is when you first start truck,the ECM checks all modes.If a connection is broken,4WD does not do anything and light flashes.Just like GM with service AWD/4WD message?
  9. Jan 15, 2018 at 10:52 AM
    #349
    awolo
    awolo Active Member
    Aaron
    Medina, OH
    I'm going to hold onto it. I don't plan on letting the truck go anytime soon, so i'm sure ill need it.
    I've been switching into 4HI a lot since all this started happening, seems to working very well, and this truck is a tank in the snow, even on my all season tires.
  10. Jan 15, 2018 at 11:49 AM
    #350
    docbrown
    docbrown Well-Known Member
    Tampa, FL
    05 Tacoma SR5 4X4
    Doug Thorley Long Tube Headers, Eclipse 6620 AVN GPS/DVD, K&N Drop-in Air Filter, Hose clamp mod, Redline Quick Lift Elites, Bilstein 5100's at .85, Firestone Ride Rite Air Bags, Weather Techs front and back, Bug Guard, and Factory Bull Bar, Wet Okole's up front, Bed Mat, LED interior lights, Fumoto Oil Valve
    Anyone know if there is a gasket for the actuator? From what I have seen most folks are using form a gasket, but I would like to be able to drive the truck without waiting 24 hours.
  11. Jan 25, 2018 at 3:02 PM
    #351
    bluewlf04
    bluewlf04 New Member
    Travis
    2006 Tacoma TRD 4x4 DCSB
    New member here, but I've been turning to TW for all of my truck needs pretty much since I bought my 2006 taco four years ago.
    I had the same issue as a number of posters here... 4x4 wouldn't engage in freezing temperatures (or disengage if it was already in 4x4). I read all of the posts explaining the issue with the front diff actuator, as well as the ones saying that the transfer case actuator could be dirty. The trans case looked to be the less involved repair so I figured that I would start there. Opened it up (just the black plastic part... didn't remove it totally from the t-case), cleaned out the yellow gunk, and re-greased the gear. Put it all back together and test-drove the truck. Not only did it not fix the problem, but it was now stuck in 4-lo. Took everything apart again and repositioned contacts based on diagrams I found. Several tries at this and no luck. I then opened up the actuator, but left it plugged in... turned the key and cycled the selector switch to 4-lo to see if maybe there was a mismatch going on. Reconnected everything, turned the key, and cycled the selector back to 2-hi. The 4-lo went off, but the 4wd light was flashing. Started the truck to test drive and see if this means that it's in 4-hi or 2-hi, but now the truck won't move. What have I done now? I'm really starting to think that I'm in over my head, but hopefully someone can help me out here.
  12. Jan 29, 2018 at 10:43 PM
    #352
    redzmvt
    Scott
    Western Wisc.
    Bone stock for now
    The current Aisin part # is SAT-017,which fits 2005-2017 Tacomas.I believe the 10 digit numbers are what Toyota uses.Part must have had revisions along the way.I believe the OEM part is made by Aisin?
    Rockauto and Amazon are both out of stock,so am looking for one reasonably priced on ebay.
    Bigislandrock likes this.
  13. Feb 2, 2018 at 11:17 AM
    #353
    Rsketoe
    Rsketoe New Member
    Roderick
    Summerville SC
    2013 Toyota Tacoma
    bluewlf04
    I’m going threw the exact same thing. We had snow down here about a month ago, I tried to put my truck into 4wd and would not. I got to the house, turned truck off went inside got a drink. Came back out got in truck, turned the truck over and was in 4lo but knob was in 2h. Could get it to come out if 4l, drove around the block to see if would disengage, no luck.
    Now it’s a 13 with 110,000 Miles and been in the mud once and maybe 4wd ten times. I’ve taken the actuator off and looks brand new. Been reading the posts on here, looks like I have a few more tests to do.
    Good luck to you sir.
  14. Feb 11, 2018 at 12:45 PM
    #354
    Outback mb
    Outback mb New Member
    2013 Tacoma
    4” toytec lift custom bumper and rock sliders
    Just took my actuator apart and looks ok even tried it out just hanging from the wire works 100% . My 4wd has been working for the first few min of driving then cutting out after a turn with the usual clunk given when you switch it off , yet the indicator light stays on
    Also if u use an indxable ratchet you can access the top bolts without lowering the dif . They are pricy from Mac but worth every penny
  15. Feb 16, 2018 at 11:04 AM
    #355
    excorcist
    excorcist Well-Known Member
    Reno, NV
    '06 dcsb, '86 pickup, '89 runner
    Getting ready to pull my front add.... What grease should be used in there? Want to replace all of the ~12 year old grease.
    Kooltaco likes this.
  16. Feb 22, 2018 at 6:54 PM
    #356
    john_only
    john_only Slick Products - Marketing
    Johnny
    Orange County
    2006 White Tacoma Trd Offroad
    Icon Suspension, Camburg UCAs, Deaver Springs, ARB bumper, Flippac on 6" bed.
    This has been super useful. Going to attempt the repair this weekend
  17. Mar 12, 2018 at 7:54 AM
    #357
    Calion
    Calion Well-Known Member
    2002 Black Tacoma SR5 4x4
    Came used with brush guard, winch and bed cover.
    Could someone tell me what this means? There's a Toyota 4x4 official troubleshooting guide?
  18. Apr 28, 2018 at 5:44 PM
    #358
    MilSpec
    MilSpec Well-Known Member
    2014 Tacoma TRD Off-Road [1GR-FE] [A750F]
    GilbertOz, Taco2Me and dborrer like this.
  19. May 18, 2018 at 1:58 PM
    #359
    Bigislandrock
    Bigislandrock Member
    Paul
    Big Island Hawaii
    2008 DCLB
    So let me understand this after reading most of these posts and comments..
    My 4x4 will not engage on my 2008 Tacoma.
    The 4x4 light does not light up when switching the dial to 4H. This means the T-Case actuator wiring is faulty?
    I no longer hear my front actuator lock. Is this because the rear T-Case actuator isnʻt working?
    When the 4x4 light blinks that means the T-Case actuator is working? Which may mean the axle actuator is at fault?
    I just replaced both side bearings, rotors and brake pads. A month later and now I have no 4x4...frustrated...
    Any suggestions?
  20. May 18, 2018 at 2:05 PM
    #360
    Mr x 1979
    Mr x 1979 23 TRD Sport MT SB
    Mitch
    Truro Nova Scotia Canada
    2023 Black Tacoma TRD Sport MT SB
    Iam going through the same BS
