How To Trouble Shoot 4x4 Actuator
Discussion in '2nd Gen. Tacomas (2005-2015)' started by blackhawke88, Feb 15, 2013.
  1. Apr 2, 2013 at 10:25 PM
    blackhawke88
    blackhawke88 [OP] wo ai ni bao bei ^_^
    SGV, CA
    07 TRD Offroad
    Didnt lose any oil. 6 philips screws to pop off the face of the actuator. Dont even need to remove the front diff, just loosen the bolts and tilt down.
  2. Apr 2, 2013 at 10:43 PM
    joesmith
    joesmith Well-Known Member
    Alaska
    2005 Access Cab 4x4
    Cool! I am going to try and diagnose my 4x4, I think the actuator is broken.
    For the longest time it wouldn't switch from 2WD into 4WD, now its stuck in 4WD and the light is blinking. I don't want to drive it around much until I get it fixed, especially since all the snow and ice is melting and I will be driving on pavement.
  3. Apr 3, 2013 at 9:14 AM
    joesmith
    Alaska
    2005 Access Cab 4x4
    It's in 4WD, I can feel the wheels bind when I make a sharp turn.
  4. Apr 4, 2013 at 12:17 AM
    qnyla
    qnyla Well-Known Member
    NM
    2006 & 2016 DCSB TRD Off Road 6-Speed
    I wish I had known this when mine went out last year. Thanks for this info!
  5. Apr 4, 2013 at 5:31 AM
    moondeath
    moondeath Well-Known Member
    Pa, Gardners
    2013 TRD Sport DCLB 4x4
    5100 @ 0” w/ 2.5” Eibach spring, 1.5" Icon Progressive 3 leaf + 1” block, Procomp Wheels, Grill Thin Lip (Custom Car Grills Mod), Access Tonneau Cover, Pop & Lock Tailgate Electronic Lock PL8521
    Maybe we'll get lucky and the next tacoma will go back to a manual transfer case.
  6. Jun 10, 2013 at 1:45 PM
    Manwithoutaplan
    ID
  7. Jun 23, 2013 at 5:08 PM
    Bearcoatoffroad
    Bearcoatoffroad Well-Known Member
    Barry
    Rincon, GA
    '07 TRD Off Road 4x4 Double Cab
    2.5" spacer lift, Tundra wheels with spacers
    Whoever else does this, you have to pull the front diff way down to get the top actuator bolts out, when you do this it is likely going to disconnect the diff breather hose.
    LOOK for it on reassembly!
    It is hard to see and real hard to reconnect. A steel tube exits the top of the diff, then there is a 3-4 inch long section of rubber hose directly above the actuator, then another steel tube. All the prying down of the diff pulls on the vent and can unplug the rubber from the second steel tube, did not seem to have any clamps on it.
    Also, keep an eye on the CV boots, they will contact the front LCA bolts and can damage them.
    My ADD actuator had about a cup of water in it, half submersing the motor and entirely the micro switch. A good cleaning with alcohol, then WD-40 seemed to get it working again.
    Test the motor with alligator clips and a battery (I used a dewalt drill battery). Two pinouts on closest to the motor are for the motor, you can also test the connections at the motor this way.
    GilbertOz, Marc70, dborrer and 2 others like this.
  8. Jul 3, 2013 at 6:11 PM
    farminfireman
    farminfireman Active Member
    Myles
    WNC
    06 trd off road
    3 inch lift, custom built tool box, aftermarket headlights, smoked taillights, diff lock any time mod :), k&n cold air intake, after market headunit with 2 10inch subs behind the rear seat
    Could this be why my 4wd lo dont work
  9. Jul 3, 2013 at 6:14 PM
    blackhawke88
    SGV, CA
    07 TRD Offroad
    ^ dunno, do a continuity test
  10. Jul 3, 2013 at 9:09 PM
    farminfireman
    Myles
    WNC
    06 trd off road
    ^ can you tell me how to do that please
  11. Jul 3, 2013 at 9:38 PM
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    Lick your fingers and touch them to both leads ;-)
    Seriously you don't sound like you need to open anything.
    sloth671 and BMOC like this.
  12. Jul 26, 2013 at 8:41 AM
    Sje1124
    Sje1124 Well-Known Member
    Sean
    Louisiana
    2010 DBL Cab TRD OR 4x4
    Just a few
    Sub'd, will be doing this tonight
  13. Jul 26, 2013 at 9:41 AM
    allmotorrex
    allmotorrex Grove St. Fab
    Gideon
    Memphis 901
    08 SR5 4wd 2.7
    NWF crawlbox, 5.29s, rear Detriot, front Harrop, 37" SXIIs, 17x9" KMC Grenade Crawl beadlocks, Dirt King 3.5" LT kit with King shocks, Fox 12" smooth body RR, BAMF shock kit, AP 3" springs, ext. brake lines, custom 1 piece driveshaft with .135 wall tubeing, GSF front rock crawling bumper, GSF rear bumper, Relentless Fab ifs skid, BAMF k/o sliders, X2O 10K comp. winch, TP glass fenders, OKled 20"bar, EBS dimpled/slotted rotors, EBS green pads, custom K&N CAI, LCE headers, FM Super 44 w/h turn down, URD MAF, Spec clutch, LCE heavy flywheel, URD short shifter, TMPer M1 Abrams shift knob, Amsoil oil, Cobra 75wxst w/h 4' firestix, Grillcraft, FXR TRS, T1 eyelids, custom ADV Monster 60 lights, bed lights, speedo light mod, Glow Shift volt/oil pres gauges, Glow shift 2g column pod, Optima yellow tops dual battery setup w/h IBS system, Pioneer DEH-P7200HD head unit, Pioneer 600W 4ch & 350w 2ch amps for doors and sub, Wet Oakle covers
    Do you have a multimeter?
  14. Jul 26, 2013 at 9:44 AM
    Sandman614
    Tim
    '06 SR5 Off Road
    He has 8 posts and doesn't know how to do a Cont. test.
    unstpible and fuzz26 like this.
  15. Jul 26, 2013 at 1:30 PM
    #35
    LowerBost
    LowerBost Well-Known Member
    Nick
    Pittsburgh, PA
    09 Tacoma Sport
    Old Man Emu Lift w/ Dakars and Billsteins, K&N Intake, Throttle Body Space, Front Bull Bar, Side Rails, Painted Stock Rims, Bilstein 5100 Front Shocks, Third Brake Light Cover, Satoshi Grill Mod, BHLM Mod
    I'll have to keep this thread in mind. Had an issue with mine last winter. It wouldn't come out of 4WD. Took it to my dealer and said it was $1300 to get the actuator replaced and that if I put it in 4WD again they will not be able to remove it and MUST replace the actuator. Them jags think I'm stupid or something?... Took it to another dealer and they said nothing was wrong with it at all...Just waiting for it to go again... Great write up!
  16. Jul 26, 2013 at 3:20 PM
    #36
    allmotorrex
    Gideon
    Memphis 901
    08 SR5 4wd 2.7
    Haha aight ill be quiet .......
  17. Jul 26, 2013 at 4:07 PM
    #37
    TheGoat
    TheGoat Well-Known Member
    Justin
    Greenville, SC
    White 07 SR5 4x4 6spd
    OME 885 springs on 90000 shocks, sway bar removed 1.5" AAL on 285/75/16s
    WTF? How the hell does an engineer say: "this motor will make or break the 4wd system. No need to actually connect it to power, just make sure the leads touch the source enough to get it working." really WTF?
    daytrader2 likes this.
  18. Jul 26, 2013 at 5:53 PM
    #38
    Sje1124
    Sean
    Louisiana
    Just a few
    Did anyone have trouble getting the screws out?
    DC92T likes this.
  19. Jul 26, 2013 at 6:10 PM
    #39
    Bearcoatoffroad
    Barry
    Rincon, GA
    Top passenger side needed a 1/4" drive extension with a u-joint. I may have used a few select profanities during the removal of the ADD.
    dborrer likes this.
  20. Jul 26, 2013 at 6:31 PM
    #40
    Sje1124
    Sean
    Louisiana
    Just a few
    Just got mine apart
