How To Trouble Shoot 4x4 Actuator
Discussion in '2nd Gen. Tacomas (2005-2015)' started by blackhawke88, Feb 15, 2013.
  1. Apr 4, 2019 at 11:29 AM
    #541
    1moa_solutions
    1moa_solutions Active Member
    Adam
    2021 AG TRD Off Road
    Quick update:
    I checked the 6 prong terminal on the actuator after reassembling it by applying power to the number 1 and grounding 2. The actuator arm moved fine. Switching power and ground caused the arm to move back the opposite direction so it appears to be functioning as intended.
    I mounted the ADD back onto the front diff with the gray sleeve and the actuator arm centered so that the sleeve could move left to right freely. I also connected the wiring harness and the vacuum line.
    No change, still getting the flashing 4WD and 4LO lights without being able to actually engage the 4WD.
    What next? Because I’m lost as hell on what I’m doing wrong.
  2. Apr 4, 2019 at 5:19 PM
    #542
    93yotasr5
    93yotasr5 Well-Known Member
    Sacramento
    Right there with you. I’m a about to order a new/used actuator to see if for whatever reason that is giving me the problems. At my wits end with this bitch to be honest.
  3. Apr 10, 2019 at 8:59 PM
    #543
    TDRsport
    TDRsport Member
    2017 Tacoma TDRsport MT
    This goes for both 2nd and 3rd gen 4wd actuators. Assuming you already troubleshooted the small motor contacts and they are now soldered. This should be fixed now on the 3rd gens. However, there is one more place where you can have contact problems. It's the tiny switch you can barely see, you would normally ignore it. If your actuator been out there for a few winters or you have a cut on your breather hose (like I did) and you get water inside it will corrode the insides of that little switch and then the computer won't have the response that the actuator did in fact moved the fork and ingaged the 4wd. Since the computer doesn't know about it out won't let you shift to 4LO.
    Here is the fix. Take that little switch apart very carefully and clean those tiny contacts. As simple as that.
    GilbertOz, Marc70 and Crom like this.
  4. Apr 11, 2019 at 3:30 PM
    #544
    [KD]
    [KD] Used Import
    Dan
    Halifax, NS
    06 DCSB 6MT
    So just throwing this out there - right after I had my actuator off and back on the 4x4 and 4lo lights flashed a couple of times and went out while I was in 2hi. Then the other day the lights started flashing again and didn't turn off this time except once briefly while driving. Couldn't engage 4x4 with the lights flashing either. Drove it like that for a couple of days then today inspiration struck - unplugged the electrical connector, blew on the pins and plugged it back in and voila, no flashing lights, 4x4 works again. So check your connections!
  5. May 13, 2019 at 4:48 AM
    #545
    kidthatsirish
    kidthatsirish Well-Known Member
    2006 Tacoma Access Cab, 2.7L, 4x4, Manual Transmission
    President McKinley w/KLM 203P and threw the roof antenna, ICON RXT leaf spring packs (position 2), Bilsteen 5100s, ARE Camper Shell, Pop & Lock tail gate, Dash Cam
    so i did some diagnosis on my truck with similar issues.
    Can anyone confirm the part numbers for the two limit switches on the transfer case actuator?
  6. May 14, 2019 at 7:20 AM
    #546
    Gfrank54
    Gfrank54 New Member
    Garrett
    Northeast Ga
    09 Pyrite Mica Access Cab 4 cyl 5speed 4x4 SR5
    On 33 nitto trail grapplers
    Ended up getting an entirely new transfer case from a local shop since it was less than half the price of what the dealership was going to charge for just the transfer case actuator. No more flashing 4x4 light
    Crom and WoodsGhost like this.
  7. May 14, 2019 at 2:37 PM
    #547
    93yotasr5
    Sacramento
    Purchased a used but in perfect shape actuator from another TW member. Threw it in today and it didn’t change anything. I removed the transfer case actuator motor, tested it, greased it up and reinstalled it. I cleaned up all the connectors on everything again for the 50th time. Reset the ECU and it is all good now. After several months of trying to fix this damn thing I finally got rid of the blinking lights.
  8. May 14, 2019 at 4:28 PM
    #548
    WoodsGhost
    WoodsGhost Well-Known Member
    PA
    2017 DCSB OR:2016 4Runner
    After the dealer fixed the pinched wire. My 4x4 was working again. But after a week or two the 4wd/4lo light started flashing again. So i unplugged the transfer case swithches(like i usually did for them to go away)But they stayed on.
    So this time I disconnected the battery for awhile and also unplugged what i think is the 4wd ecu. The lights havent been back on in a month.
    Is the 4wd ecu behind glove box on far right? Grey box?
  9. May 14, 2019 at 9:04 PM
    #549
    kidthatsirish
    mine is black but yes its behind and above the glove box on the passenger side of the glove box. If you unplugged those then the 4wd system will not turn on the dash lights.
    WoodsGhost[QUOTED] likes this.
  10. May 14, 2019 at 9:08 PM
    #550
    93yotasr5
    Sacramento
    I actually just reset the main ecu and it started working.
  11. May 14, 2019 at 9:21 PM
    #551
    kidthatsirish
    by main ecu do you mean the 4wd ecu or truck ecu?
  12. May 14, 2019 at 10:19 PM
    #552
    93yotasr5
    Sacramento
    Truck ECU. But honestly I think it would’ve worked just turning the truck on and off a few times for it to learn that a new working part was in there.
    WoodsGhost likes this.
  13. May 15, 2019 at 6:12 AM
    #553
    kidthatsirish
    thays good to know.
  14. Jul 18, 2019 at 10:20 AM
    #554
    tathambenjamin
    tathambenjamin Well-Known Member
    ben
    2008 4Runner SR5
    -2.5/1.5 spacer lift -270/65/17 Cooper AT3
    I also need the part numbers for the limit switch in the t case actuator. Anybody?
  15. Jul 19, 2019 at 12:46 PM
    #555
    TWTaco
    TWTaco Well-Known Member
    Dave
    rc1.jpg I have a 3rd gen and recently went thru a stream crossing water was about 3ft deep maybe a little more. After being on the trail all day and going back to pavement driving switched to 2 wheel drive everything worked no flashing light. Stopped for a gas fill up and started up and green 4x4 light was flashing. Tried to engage and disengage 4x4 but nothing but flashing light. so started to drive to camp and after a few minutes of driving light went out. Did not try engaging 4x4 until trip home was over. When i arrived home light was still off truck engaged and disengaged 4hi 4lo no issue . Now light comes on occasionally but goes out on its own after a few minutes of driving any time light flashes cannot engage 4lo or 4hi. Does the 3rd gen share the same actuator problems? Any help would be good ,warranty well passed by. Thanks
  16. Jul 19, 2019 at 1:23 PM
    #556
    uurx
    uurx Well-Known Member
    long island, new york
    '12 t|x pro
    the symptoms sure sound the same, look up the part numbers and if they are indeed the same then rest assure the diagnosing and corrective measures will be the same...
    TWTaco[QUOTED] likes this.
  17. Jul 19, 2019 at 1:27 PM
    #557
    uurx
    '12 t|x pro
    it looks like the part numbers are the same, i see them being advertised as 05-17 tacoma
  18. Jul 19, 2019 at 1:33 PM
    #558
    TWTaco
    Dave
    APDTY 134104 4WD Front Differential Shift Fork Actuator Assembly Fits 2007-2016 Toyota 4Runner or Tacoma 2014 Toyota FJ Cruiser (Electric & Vacuum Operated; 4-Wheel Drive Models With V6 Engine)does this look correct?
  19. Jul 19, 2019 at 1:39 PM
    #559
    uurx
    '12 t|x pro
    not 100% sure where you pulled that from, but that part number looks incomplete...
    here is a picture of the part label from one that I purchased some years back
  20. Jul 19, 2019 at 1:41 PM
    #560
    uurx
    '12 t|x pro
    I would suggest avoiding aftermarket.
    The dealership charges an arm and a leg for these, you can find OEM toyota ones over on ebay for a fraction of what the dealer quotes.
    TWTaco likes this.
