How To Trouble Shoot 4x4 Actuator
Discussion in '2nd Gen. Tacomas (2005-2015)' started by blackhawke88, Feb 15, 2013.
  1. Apr 14, 2022 at 11:25 PM
    #781
    6 gearT444E
    Deep South
    Herculiner Hootus
    it shares a tube for financial reasons. Real estate is expensive these days. For why it needs one, it’s an enclosed area with no fresh air. In theory it’s not needed but helps. It’s a fresh air inlet more than a vent and it helps to keep parts moving. If water gets in you’re screwed.
  2. Apr 16, 2022 at 4:20 PM
    #782
    GilbertOz
    GilbertOz Driver
    CA
    2014 AC V6 MT 4WD, 84K miles
    FOX 2.5, Deavers, ARB, OTT, 4xInnovations
    I've read through this entire 40-page thread (in parts, over the last week or two) and don't recall seeing any serious discussion about the best choice(s) for replacing the breather tubes (both actuators, transfer & ADD). Seems like a majority of early failures are caused by water/dirt intrusion & upgrading to more-robust tubing would prevent these. Looks to me like the stock/OEM tubes aren't the correct material for long-term use since they tend to crack easily.
    What's the best type of tubing to use? Maybe viton material? Does anyone know the exact specs (O.D./I.D.) on the tubing? Has anyone put on aftermarket miniature hose clamps to keep the tubing from slipping off the friction-fit nipples?
    This is the hose on my 2014 V6 6MT TRD OR at 63K miles, most of those highway miles on mild, salt-free California highways, + maybe 1K miles on dirt roads / light off-road use.
    SR-71A and 6 gearT444E[QUOTED] like this.
  3. Apr 16, 2022 at 4:48 PM
    #783
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    I haven’t any idea. But those of us with Automatic Transmission are going to have a hard time replacing the hose for the Transfer case. It ties into the trans breather and is on top of the transmission. Definitely doesn’t look easy to get to.
  4. Apr 16, 2022 at 9:19 PM
    #784
    6 gearT444E
    Deep South
    Herculiner Hootus
    i replaced mine with silicon vacuum tubing. Don’t remember the size but maybe measure the old tubing, I believe I got from trail gear. A hose clamp isn’t necessary. It doesn’t operate at pressure so a barbed fit is plenty sufficient to keep the elements out.
    https://trail-gear.com/drivetrain/engine/components-misc-kits/silicone-vacuum-hose-10-roll.html
  5. Apr 17, 2022 at 7:48 AM
    #785
    Leomania
    Leomania Well-Known Member
    Leo
    2011 Tacoma TRD Sport DCLB v6 4x4
    All stock, baby!
    The hose for the transfer case ADD is more prone to cracking/splitting IMO because of the tight angle the hose is at. What I did on mine was to cut out the bad end and added a right angle adapter with a 1” section of vacuum line to replace what I removed. It takes the pressure off the old hose so it’s not going to split on you nearly as quickly. Put a small zip tie around the old hose if you’re concerned about it not being brand new rubber.
    I checked every other hose I could, especially the front ADD, and everything looks good. I’m pretty impressed with the longevity of the rubber components on these vehicles.
  6. Apr 20, 2022 at 2:18 AM
    #786
    SoCal808
    SoCal808 Member
    Kalaeloa
    Off-Road DCSB 4WD
    Mall Crawler
    Aloha! Requesting some assistance please.
    Working on my friend’s 2008 Tacoma with manual transmission. Truck has blinking 4wd and 4lo lights. Truck does not go in 4wd. I’ve tested both the ADD and T-Case actuator with a 12v battery and the motors work.
    I cleaned, soldered, and applied lithium grease to the ADD. Moved the locking sleeve to the driver side when the ADD was reinstalled. Didn’t fix the blinking 4wd and 4lo lights. Also didn’t hear the ADD’s motor turn when attempting to turn the selector to any 4wd positions.
    Cleaned, regreased, and clocked the t-case actuator. Spline was all the way down when I removed and reinstalled the actuator. Also checked both pressure switches and they still had the detent. Both the 4wd and 4lo lights turned off. However, the lights returned with I attempted to go in 4wd. Didn’t hear the ADD motor turn.
    Does the ADD motor not engage if there’s a problem with the t-case actuator?
  7. Apr 20, 2022 at 4:55 AM
    #787
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    The 4wd ECU won't engage the ADD until the transfer case has completed it's shift into 4H and it sees those limit switches in the correct positions for 4H, same thing going into 2wd the transfer case always completes it's shift first.
    Did you get the Transfer Case Actuator timed correcly when you reinstalled it?
    Limit switch voltages can be checked at the 4wd ECU or the actuators.
    Charts, voltages, sequence of operation, diagrams, and more in the thread below.
    https://www.tacomaworld.com/threads/4wd-system-operation-help-thread.742420/
  8. Apr 20, 2022 at 5:07 AM
    #788
    SR-71A
    SR-71A Define "Well-Known Member"
    Zack
    Southern Maine
    2012 DCSB, TX Baja Edition. Barcelona Red
    255/85/R16 Falken Wildpeak MTs, Mobtown sliders, ARB bar, SOS front skid, Icon RXT leafs, extended & adjustable Kings, JBA UCAs, OVS wedge RTT, dual AGM batteries, Gen2 xrc9.5 winch, CB, GMRS, S1 ditch lights...
    Thats on my list of things to do this summer is to replace the ADD soft lines. I have some 1/8" ID (I think) parts store vacuum line. Not sure if its the right choice, but its all I could find. Im going to try and do both rubber lines between the ADD and the breather in the engine bay.
  9. Apr 20, 2022 at 1:26 PM
    #789
    SoCal808
    SoCal808 Member
    Kalaeloa
    Off-Road DCSB 4WD
    Mall Crawler
    Thank you for the assistance and reference!!! Will read up on it.
    I seated the long pin on top of the dead space pictured. Is that the correct position or should the pin contact the trace upon seating?
  10. Apr 20, 2022 at 4:49 PM
    #790
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    I'll take a closer look when I get time but the contacts need to be lined up in the correct position for where the shift fork is in the transfer case after the housing is installed if that makes sense.
    There's a picture of the cover with the contact positions overlaid on it in the thread I posted.
  11. Apr 20, 2022 at 5:27 PM
    #791
    SoCal808
    SoCal808 Member
    Kalaeloa
    Off-Road DCSB 4WD
    Mall Crawler
    Thanks again! There's a small red circle on the attached pic where I lined up the contacts. I eyeballed it so that my be an issue.
  12. Apr 20, 2022 at 7:34 PM
    #792
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    Yea I checked that is the 2H position but do you have the transfer case selector rod in 2H (fully in)?
    TnShooter likes this.
  13. Apr 20, 2022 at 8:44 PM
    #793
    TnShooter
    Deogee
    STOCK
    I believe you might be able to use a voltage meter to see if it’s timed correctly for 2WD?
    In @Dm93 link you will see this picture.
    Pin #5 should only have continuity with pin #4 in 2WD. And NOT #3 & #6.
    SR-71A likes this.
  14. Apr 20, 2022 at 8:50 PM
    #794
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    He had the actuator off the transfer case though, in that case the position of the transfer case Must match the position of the switch wiper when it is reassembled or it will not work properly.
    TnShooter[QUOTED] likes this.
  15. Apr 20, 2022 at 8:59 PM
    #795
    TnShooter
    Deogee
    STOCK
    Yeah, like you said. Rod pressed all the way in.
    I hate to even think about the day I will have to “look at” mine.
    If I ever do, I will definitely take a bunch of picture.
    :fingerscrossed: Here is to NOT having to
  16. Apr 20, 2022 at 9:02 PM
    #796
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    Keep the vent hoses on the actuators in good shape and attached and use it regularly and there's minimal risk of issues.
    SR-71A likes this.
  17. Apr 20, 2022 at 9:08 PM
    #797
    TnShooter
    Deogee
    STOCK
    They look ok. They aren’t cracked. But they definitely feel “hard”.
    Probably need to address them before long.
    Dm93[QUOTED] likes this.
  18. Apr 21, 2022 at 1:15 AM
    #798
    SoCal808
    SoCal808 Member
    Kalaeloa
    Off-Road DCSB 4WD
    Mall Crawler
    Thank you again @Dm93! Your diagrams , charts and spreadsheets were money!!! I'm hoping the rod was all the way in. I pressed the rod as far in as I could with a large pry bar, i didn't see any notches on the rod to indicate it was further out than 2wd, and the wiper was set to 2wd when I reassembled. I only tested in cabin (the 4wd ECU). Please see my results. Any idea of what the issue might be just from looking at the spreadsheet? I'll continue on tomorrow to test the transfer case actuator.
    Thank you @TnShooter! I'll try that tomorrow!
  19. Apr 21, 2022 at 7:06 AM
    #799
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    I'd want to backprobe TL1 (Pin 5 Blue/Yellow) at the Transfer Case Actuator and see if you also have 12v there in 2H, if you do then you need to check Pin 4 (White/Black) (should be less than 100mV, If it's 12V you have a broken ground wire or bad ground), if the ground is good you have a problem in the actuator (or a spread terminal in the plug), if you don't you have a broken wire or bad connection between the 4wd ECU and Transfer case actuator.
  20. Apr 21, 2022 at 7:35 AM
    #800
    SR-71A
    Zack
    Southern Maine
    With everything across the board reading high I wonder if there is an issue with the GND connection?
    The ADD readings make sense because it would not have attempted to engage
    Dm93 likes this.
