How To Trouble Shoot 4x4 Actuator
Discussion in '2nd Gen. Tacomas (2005-2015)' started by blackhawke88, Feb 15, 2013.
  1. Apr 21, 2022 at 7:54 AM
    #801
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    I did not think of that yes absolutely backprobe & check voltage on the ground Pin 4 (White/Black) of the Transfer Case Actuator (should be less than 100mv at all times). I edited my post to reflect this
    Also remember once the 4wd ECU detects a fault it locks out any further movement of the actuators until the fault clears or the key is cycled.
  2. Apr 21, 2022 at 12:40 PM
    #802
    SoCal808
    SoCal808 Member
    Kalaeloa
    Off-Road DCSB 4WD
    Mall Crawler
    Thank you again for the assistance, Dm93!
    Thank you for the insight, SR-71A! Will definitely check the grounds!
  3. Apr 21, 2022 at 9:35 PM
    #803
    SoCal808
    SoCal808 Member
    Kalaeloa
    Off-Road DCSB 4WD
    Mall Crawler
    @Dm93 and @SR-71A looks like I have 12v running through pin4 (GND).
    0F79F96E-03BB-43D2-8917-93F73511BC14.jpg A74815B9-1BCB-403E-B12A-5762400A2243.jpg
  4. Apr 21, 2022 at 9:37 PM
    #804
    SoCal808
    SoCal808 Member
    Kalaeloa
    Off-Road DCSB 4WD
    Mall Crawler
    Please tell me I probed the wrong pin.
  5. Apr 21, 2022 at 9:40 PM
    #805
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    Hard to tell in the picture but it looks like your in pin 3, you need to be backprobing with the connector plugged in to get actual readings otherwise your just seeing the reference voltage from the 4wd ECU.
    SR-71A likes this.
  6. Apr 21, 2022 at 9:45 PM
    #806
    SoCal808
    SoCal808 Member
    Kalaeloa
    Off-Road DCSB 4WD
    Mall Crawler
    Gotcha! Will plug it back in. Is orientation of the pins 6-5-4-3-2-1 with the clip release button on the top? Or, the other way around?
    Thanks again for all your help!
  7. Apr 21, 2022 at 9:49 PM
    #807
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    When it is plugged into the actuator yes, when it's unplugged and facing you its 123456
    If in doubt use the wire colors as a reference (Pin 4 is White/Black).
  8. Apr 21, 2022 at 10:00 PM
    #808
    SoCal808
    SoCal808 Member
    Kalaeloa
    Off-Road DCSB 4WD
    Mall Crawler
    Thanks again!!! I missed the first time you mentioned the ground was white/black. That was my bad. I did probe the wrong pin.
    The ground is at 3.4ohms/1.5mv so it has a lot of resistance.
    32290F0F-66E0-4212-BA6D-F2D6DA74D8C6.jpg 43068922-13EA-4631-A9C1-74FDB8939D7A.jpg 941A8193-76D4-439E-97F8-C8E42FED1DF3.jpg
  9. Apr 21, 2022 at 10:10 PM
    #809
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    Resistance test would have to be done with it unplugged, 150mV isn't too bad if that is key on.
    What are you getting on TL1 Pin 5 (Blue/Yellow) with the key on ?
  10. Apr 21, 2022 at 10:30 PM
    #810
    SoCal808
    SoCal808 Member
    Kalaeloa
    Off-Road DCSB 4WD
    Mall Crawler
    Confirmed, the key was on during the pin 3 test. For pin 5, I have an open line. Key was also on during this test.
  11. Apr 21, 2022 at 10:33 PM
    #811
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    Open line as in 12v or 0v?
  12. Apr 21, 2022 at 10:33 PM
    #812
    fatfurious2
    David
    Ashburn, VA
    2010 TRD OR Access Cab
    If I open the actuator to spread the grease around, can I apply some marine grease also? Or should i use a dielectric grease?
  13. Apr 21, 2022 at 10:35 PM
    #813
    SoCal808
    SoCal808 Member
    Kalaeloa
    Off-Road DCSB 4WD
    Mall Crawler
    Sorry, 0v.
  14. Apr 21, 2022 at 10:37 PM
    #814
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    So you have 0V on TL1 at the actuator and you still have 12V on TL1 at the 4wd ECU?
  15. Apr 21, 2022 at 10:39 PM
    #815
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    I'm not sure what would be the best grease for the actuator contacts, @6 gearT444E your thoughts?
    fatfurious2[QUOTED] likes this.
  16. Apr 21, 2022 at 10:45 PM
    #816
    SoCal808
    SoCal808 Member
    Kalaeloa
    Off-Road DCSB 4WD
    Mall Crawler
    Confirmed, 0v on TL1 actuator.
    B93C9C3D-10CC-4B08-A879-738D78524102.jpg E4216E1A-D094-44C1-B7CE-0D7DA5ACE66C.jpg
    12v on TL1 at 4wd ECU.
  17. Apr 21, 2022 at 10:47 PM
    #817
    SoCal808
    SoCal808 Member
    Kalaeloa
    Off-Road DCSB 4WD
    Mall Crawler
    Disregard, I reprobed TL1 actuator and it’s 12v also.
  18. Apr 21, 2022 at 10:50 PM
    #818
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    So looks like there's a problem with the TL1 contact in the actuator, I wonder if it maybe got bent when you had the actuator apart?
  19. Apr 21, 2022 at 11:08 PM
    #819
    SoCal808
    SoCal808 Member
    Kalaeloa
    Off-Road DCSB 4WD
    Mall Crawler
    I did bent them up. Did I bent it too much? Could I also have possibly incorrectly align the actuator?28A2749F-886F-4CF8-85AF-1D79B3F27988.jpgC541BEF5-136B-4D8F-A9E1-5530BE45518A.jpg
  20. Apr 21, 2022 at 11:16 PM
    #820
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    They look fine to me, did you ohm out the traces on the cover to the pins on the plug end to make sure the trace isn't broken in the cover?
    Otherwise your timing is off or something is goin on with the contacts.
    I'm going to bed, I'll check back in the morning.
    SR-71A likes this.
