How To Trouble Shoot 4x4 Actuator
Discussion in '2nd Gen. Tacomas (2005-2015)' started by blackhawke88, Feb 15, 2013.
  1. Mar 12, 2015 at 8:20 PM
    #141
    PSU Taco85
    PSU Taco85 Señor Member
    optional
    '10 TRD OR mostly stock
    Plasti dipped hootus
    expensive mistake, if the 4hi engages then it's not the ADD
  2. Mar 12, 2015 at 8:30 PM
    #142
    gmata
    gmata Well-Known Member
    Gonzalo
    Delaware
    2007 DCB 4x4 TRD sport
    I am not the first one with this problem, I have EXACTLY what uscg2008 described:
    And then he said:
    So hopefully it won't be a waste of money.
  3. Mar 12, 2015 at 8:34 PM
    #143
    PSU Taco85
    optional
    if the 4x4 light isn't blinking then it didn't go into 4wd. The ADD turns on the 4wd indicator light solid. So as long as your 4x4 light stayed blinking that is probably what it is, but your desciption said it went into 4wd :notsure:
    SF_Taco likes this.
  4. Mar 12, 2015 at 8:39 PM
    #144
    gmata
    Gonzalo
    Delaware
    uhmm my light blinks but I am pretty sure my 4HI is engaged because I cannot turn the truck when I am in 4HI. However when I go to 4LO I am pretty sure that one doesn't engage since I cannot hear it engaging or feel any difference and I hear a beep when going into drive.
    I orderd a used ADD from a Salvage truck, I am going to try it and worst case scenario I will return it for a 35% restocking fee.
  5. Mar 13, 2015 at 6:42 AM
    #145
    avw4x4
    avw4x4 Well-Hung Member
    (M)Andrew
    Rochester, NY
    2003 Yota
    ...loading....
    maybe a stupid question, but are you sure you had the clutch all the way in to get into 4lo?
  6. Mar 16, 2015 at 3:56 PM
    #146
    BazzokaJoe
    BazzokaJoe Well-Known Member
    Olivier
    Canada,QC
    TRD OffRoad
    you find these bolt hard to access and you work on aircraft??:p
    IwasDacapsterAz likes this.
  7. May 21, 2015 at 2:43 PM
    #147
    Traviste
    Traviste Now with more woopow
    Travis
    Georgia
    2014 DCSB Locked 4x4 Mid-Travel
    F:King 2.5 coilover resi ext 700#coils R:King 2.5 ext allpro expos
  8. Jul 24, 2015 at 6:32 PM
    #148
    dnorris
    dnorris New Member
    Dave
    2006 Taco V6 6 spd
    None
    Hi Everyone,
    Worked on this very problem all day today on my son's 06 Tacoma. Hie just got out of the Navy yesterday, so his first day back in the civilian world was working on this...! Anyway...took front actuator off, took it apart, overall good condition. Soldered the terminals, cleaned out the caked yellow grease from the half circles on the cap, and put it back on. Still have the blinking green light, and no noise whatsoever from either actuator EXCEPT... and I"m not making this up... the front actuator now beeps/chirps quietly.
    We did not do the diagnostics noted in this thread as I just found the thread now. Any ideas on what the noise would be from the ADD? ANy help greatly appreciated, as this has been frustrating.
  9. Sep 16, 2015 at 9:12 AM
    #149
    Manwithoutaplan
    ID
  10. Sep 16, 2015 at 9:15 AM
    #150
    greeneggsnspam
    greeneggsnspam ಠ_ಠ
    Houston, TX
    .gif
    Too poor to list anything interesting.
  11. Sep 16, 2015 at 9:17 AM
    #151
    Manwithoutaplan
    ID
    you don't even know ^
  12. Nov 15, 2015 at 3:40 PM
    #152
    pcolache
    pcolache Member
    Phil
    Southern NJ
    I did the ADD removal today and it looked like it was in good shape. I soldered the terminals anyway and re-assembled. I now have the 4x4 light blinking constantly. It originally only blinked when I turned the switch to 4 high. What a let down.
  13. Nov 15, 2015 at 4:43 PM
    #153
    romafern
    romafern Hug diz nuts
    Rob
    80918 Let's meet!
    Paid for and saving a shit ton of $$$$$
    Thinking of adding a second battery...
    hell yes!
  14. Nov 15, 2015 at 4:47 PM
    #154
    romafern
    Rob
    80918 Let's meet!
    maybe the ones from mejico or the numbnuts not from japan...
  15. Nov 15, 2015 at 4:47 PM
    #155
    username
    username Fluffer
    Pendleton, Or
    05 Taco with some crap welded to it
    mostly stock
    Pop it out again, leave it plugged in and have someone move the selector switch and see if it moves.
  16. Nov 15, 2015 at 4:49 PM
    #156
    romafern
    Rob
    80918 Let's meet!
    it is not an easy part to find in the junk yard from what I've been told...
    I need the inverter and can't even find one. Online is almost the same as dealer....
  17. Nov 15, 2015 at 6:53 PM
    #157
    pcolache
    pcolache Member
    Phil
    Southern NJ
    Thanks, it may be a few days before I can get back under there, but I will try this. I'll check back in
  18. Nov 22, 2015 at 8:51 AM
    #158
    pcolache
    pcolache Member
    Phil
    Southern NJ
    Hey username,
    I just popped it out while my son moved the 4x4 switch and nothing moved. I could here something above making a noise and some beeping, but no movement on the fork. I have it out on my bench, I'm going to take it apart and bench test the motor.
    Thanks again for any help!
  19. Nov 22, 2015 at 12:29 PM
    #159
    pcolache
    pcolache Member
    Phil
    Southern NJ
    I put 12v to the motor and I got nothing. I couldn't get the motor to turn, move the gears or the fork. So I'm going to look for a new actuator. Anyone know of a place I can order one for a fair price?
    Thanks
  20. Nov 23, 2015 at 10:16 AM
    #160
    azreb
    azreb Geezer
    TN
    '20 SR5 crew cab; gray
    camper shell, front camera, floor mats, cheap bed mat, dash camera, catalytic converter cover, fumoto
    I got one (part # 36410-34015) from Toyota of McDonough in Georgia. They had the best price I could find. The first was damaged in shipping. They replaced it and paid the return shipping for the damaged one promptly.
