How to turn off LSD and traction control?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by JoshyP, Oct 17, 2016.
  1. Oct 17, 2016 at 11:43 AM
    JoshyP
    JoshyP [OP] Well-Known Member
    Josh
    Northern California
    2016 TRD OR 4x4 DCSB MT
    I know this seems like a pretty silly question. But in my old tacoma (1st Gen) I was able to spin my rear tires around corners when it was wet and get a little sideways. Super fun when I mean to get a little sideways.
    Anywho, I tried this on my truck this weekend and I can not spin the tires with traction control on, so I tuned it off and it automatically turns on Auto LSD so it spins the tires but the LSD kicks in, I'm sure you know how that goes...
    Is there a way to turn on LSD and traction control so I can spin the tires and do donuts?
  2. Oct 17, 2016 at 11:46 AM
    arnette64
    arnette64 Well-Known Member
    Amos, QC (Canada)
    2016 Inferno TRD Sport Double Cab 4X4
    '16 Inferno TRD sport DC
    Press and hold the traction control button for a couple of seconds
  3. Oct 17, 2016 at 1:45 PM
    JoshyP
    Josh
    Northern California
    Thanks!!!! I will give that a shot when I get home.
  4. Oct 17, 2016 at 1:49 PM
    VangaSTL
    VangaSTL Well-Known Member
    Garrick
    St. Louis, MO
    2016 TRD Sport 4x4
    Just remember when you turn off TRAC and VSC your essentially opening your diff so you will probably only get one wheel that spins.
  5. Oct 17, 2016 at 3:22 PM
    JoshyP
    Josh
    Northern California
    Works for me, easier to throw out the backend! I seriously rarely due this by the way, just when it is wet and no one is around.
    Lord Humongous likes this.
  6. Oct 17, 2016 at 3:26 PM
    Aussiek2000
    Aussiek2000 Well-Known Member
    2016 Offroad AC
    Just be careful. All it takes is catching traction to grenade the diff
    Joe23 and JoshyP[OP] like this.
  7. Oct 23, 2016 at 10:55 AM
    johntoyota
    johntoyota "I'm higher than you'll ever be." -Treetop
    Down yonder in TN
    16 truck
    Doesn't the LSD option on these trucks retard the timing and Kill acceleration? I have been trying to figure out all the different modes of traction control on these trucks. Seems like every time the Auto LSD light is on, I lose a ton of power.
    cryptolime likes this.
  8. Oct 23, 2016 at 10:58 AM
    Aussiek2000
    2016 Offroad AC
    Yes it does.
  9. Oct 23, 2016 at 11:06 AM
    David K
    David K Well-Known Member
    Pala Mesa, California
    2010 4WD Off Road DC
    See my link on this, in my sig (much of it applies still, even with newer changes)...
    The names Toyota uses are confusing...
    AUTO LSD (in 2WD) and TRAC OFF (in 4WD-HI) are BOTH the same level of traction control: more than the standard TRAC that the truck is in.
    AUTO LSD and TRAC OFF are BOTH limited slip systems that have NO engine output regulation, so gives the truck "more power" to get moving from a stop or stuck using only brake control on spinning tires.
    TRAC alone has both engine regulation and brake control.
    To the OP, these are nice trucks and not for spinning donuts with, so try and get over that. They add these systems to stop stupid driving that rolls the truck and hurts people.
    However, just so you have control over these computer assisted vehicles, what arnette64 posted is what you need to do. Turning off VSC and TRAC is only temporary and when you restart the truck, the TRAC and VSC will go back to normal operation... or if the truck senses you are driving stupid, it will reactivate the VSC. HAL is in charge! LOL
    vinkon235 likes this.
  10. Oct 23, 2016 at 11:15 AM
    David K
    Here is the sheet I made for the changes done in 2012 to 2015... while you have A-TRAC incorporated into the CRAWL and MTS systems in 2016, this may still help you with the modes:
    Press Nothing...
    H2= TRAC (Limited Slip with Engine Output Regulation)
    H4= TRAC (Limited Slip with Engine Output Regulation, front and rear)
    L4= No Traction Control
    Quick Press (VSC OFF SWITCH) moving or stopped...
    H2= AUTO LSD (Limited Slip without Engine Output Regulation, VSC OFF to 30 mph)
    H4= TRAC OFF (Limited Slip without Engine Output Regulation)
    Press and Hold In 3-5 seconds (VSC OFF SWITCH) while stopped...
    H2= VSC OFF (No Traction Control)
    H4= VSC OFF (No Traction Control)
    Off Road TRD:
    Quick Press of RR Lock Switch = Rear differential Locker (L4 only on 4WD models)
    L4 Only: Quick Press of A-TRAC Switch = Front and Rear near-no slip traction control. A-TRAC works the front below 3 mph when the Rear Locker is also on.
    What should you use?
    Standard Mode until you lose traction, then quickly press the VSC OFF button to increase the power of your traction control (more engine RPM, stronger braking on the spinning tires).
    In L4 (Low Range) and your tires spin, press the A-TRAC button (Off Road TRD only) to nearly lock-up any spin. I always have A-TRAC on in L4... unless you need to spin the mud out of the tires.
    Emergency stuck if A-TRAC doesn't work in any situation, press the RR Lock button (works with or without A-TRAC working on the front tires). The rear locker connects both rear tires from inside the differential (0 spin). Turn off RR Locker, once you are unstuck.
    1) H2 TRAC
    2) H2 AUTO LSD (VSC OFF to 30 mph)
    3) H2 VSC OFF
    4) H4 TRAC
    5) H4 TRAC OFF
    6) H4 VSC OFF
    7) L4 VSC OFF
    8) L4 & A-TRAC
    9) L4 & Rear Locker
    10) L4 & Rear Locker & A-TRAC
    nibrwr and trdsilver like this.
  11. Oct 23, 2016 at 11:19 AM
    Aussiek2000
    2016 Offroad AC
    The rear locker should be on before you ever have a chance of getting stuck. I hit the switch any time I'm climbing a hill or going through mud
    scouterjan, vinkon235 and Paul123 like this.
  12. Oct 23, 2016 at 11:20 AM
    NosBigShot
    NosBigShot Well-Known Member
    Charleston Oregon
    93 Bronco , 2016 Taco
    Does anyone have a way to install a switch to interrupt all of these functions and allow the locker to be used in 2WD ? Life would be a lot better if I could disable all nannies and run my locker when I want to.
  13. Oct 23, 2016 at 11:22 AM
    Aussiek2000
    2016 Offroad AC
    Not on a 3rd gen. They run the locker through several modules and no way to bypass it yet
    NosBigShot[QUOTED] likes this.
  14. Oct 23, 2016 at 11:31 AM
    NosBigShot
    Charleston Oregon
    Thanks for the response. The crazy computer has done me dirty and left me stuck on stuff that I would not have normally had problems with more than once. I would love three switches. One to temporarily disable the anti lock brakes, one to temporarily disable traction control. The final switch to lock the diff. Hopefully someone comes out with something.
    Onepunchko likes this.
  15. Oct 23, 2016 at 11:36 AM
    Aussiek2000
    2016 Offroad AC
    There is already a button for traction control. You could wire in a switch to interupt the ABS fuse. Install ARB locker
  16. Oct 23, 2016 at 11:45 AM
    NosBigShot
    Charleston Oregon
    That button has issues. I don't trust it. I want to hard disable it. I don't want to install an ARB. I don't go to Moab I just want it to work so I can get up the driveway.
  17. Oct 23, 2016 at 11:46 AM
    Aussiek2000
    2016 Offroad AC
    Get some real tires then
    dYL0n likes this.
  18. Oct 23, 2016 at 11:50 AM
    David K
    IF you use the locker, then the other traction controls may be deactivated... it is with my truck, except if the A-TRAC button is depressed. The rear locker cuts out ABS and that is used by TRAC. In low range, you only have A-TRAC and/ or the rear locker. There is no VSC or TRAC.
    Junkhead and Aussiek2000 like this.
  19. Oct 23, 2016 at 11:58 AM
    NosBigShot
    Charleston Oregon
    True then the engine makes less power ... and if you rev the thing it will drop the RPM . I have real tires . The truck will stop on its own with the pedal to the mat.
  20. Oct 23, 2016 at 12:01 PM
    Aussiek2000
    2016 Offroad AC
    Time for some more skill
