how to wire extra lights?
Discussion in '1st Gen. Tacomas (1995-2004)' started by jcremeans11, Dec 21, 2010.
  1. Dec 21, 2010 at 2:04 PM
    jcremeans11
    jcremeans11 [OP] Well-Known Member
    Jon
    Ohio
    01 Tacoma SR5
    Spectre Cold Air Intake, Michelin XLT's (265/70/16), Escort Solo S3, Grounded Throttle body
    I want to do a mod to my taco and add some lights to the lower part of the bumper; however, I really don't know how I would get power to them.
    How does everyone here generally wire auxiliary lights? Also, do you just run the ground wire for a switch or what?
    Thanks
  2. Dec 21, 2010 at 2:09 PM
    rmb_crew
    rmb_crew My other ride has 18,400HP!!!!!!
    Jacksonville, FL 30.243103, -81.591007‎
    2010 F150 XLT SuperCrew 4X4
    Access larado tonneau, magnaflow exhaust
    Wire from your battery to a switch, wire from switch to light, light to ground. If the switch has a built in light the switch will need a 3rd wire going to ground.
  3. Dec 21, 2010 at 2:13 PM
    Southern01Taco
    Southern01Taco Well-Known Member
    Sean
    Holden, La
    01 V6 4x4 Xtra Cab SR5
    Its best to use a relay.
    edit: which isn't much different than what rmb crew said.
    A relay has four prongs: constant hot, switched hot, ground, lights.
  4. Dec 21, 2010 at 2:14 PM
    jcremeans11
    Jon
    Ohio
    01 Tacoma SR5
    Alright, thanks.
    Do you put a ring terminal on the battery and go from there, or is there some other way of connecting to the battery?
  5. Dec 21, 2010 at 2:29 PM
    Southern01Taco
    Sean
    Holden, La
    Yea just hook it to the battery terminal somehow.
  6. Dec 21, 2010 at 2:36 PM
    brutalguyracing
    brutalguyracing BIG DADDY
    F.U> GUYZ
    broken mods
    x2 use a relay
  7. Dec 21, 2010 at 2:38 PM
    brutalguyracing
    F.U> GUYZ
    broken mods
    [​IMG]ut a ring terminal on the battery with an in line fuse...run power to relay, ground to relay, out from relay to lights and 1 wire from switch or headlight to relay
  8. Dec 21, 2010 at 2:48 PM
    95SLE
    95SLE Starting to get cold outside
    Tom
    Maryland
    09 RWD Access Cab
    Custom XM Install, Window Tint, Intermittant Wiper Install, AVS Bug Deflector, Bed Mat, TRS FX-R retrofits, CIBIE fog and spot lamps, PIAA 510 lamps, Acess LE cover, Weathertech Digital floorr mats, LED interior lighting, Pioneer AVH-2300BT HU, Boston Acoustics speakers, JL Audio Amp, shorty antenna, leather wrap steering wheel cover, Viper security system.
    SImple schematic.
  9. Dec 21, 2010 at 3:27 PM
    jcremeans11
    Jon
    Ohio
    01 Tacoma SR5
    Thanks alot :D
  10. Dec 21, 2010 at 3:44 PM
    jcremeans11
    Jon
    Ohio
    01 Tacoma SR5
  11. Dec 21, 2010 at 3:46 PM
    brutalguyracing
    F.U> GUYZ
    broken mods
  12. Dec 21, 2010 at 3:54 PM
    jcremeans11
    Jon
    Ohio
    01 Tacoma SR5
  13. Dec 21, 2010 at 3:55 PM
    brutalguyracing
    F.U> GUYZ
    broken mods
    you mean u want the new light just to work on the switch your mounting under radio???
  14. Dec 21, 2010 at 4:03 PM
    jcremeans11
    Jon
    Ohio
    01 Tacoma SR5
    yeah thats it
  15. Dec 21, 2010 at 4:05 PM
    MountainEarth
    MountainEarth Well-Known Member
    Bryan
    CO
    2010 TRD OR Access
    Leer 100XR Shell, BedRug mat - comfy sleeping, GT Covers microfiber seat covers, BFG All Terrains 265/70r16, Dashmat, Antennax 13" shorty antenna, Weathertech liners, Ultra Gauge, Avid Light Bar, PIAA 520 ATPs, one old dog
    Did you already buy your lights? Othewise just buy a kit that comes with the wiring harness and relay.
  16. Dec 21, 2010 at 4:21 PM
    brutalguyracing
    F.U> GUYZ
    broken mods
    take your power from the acc box "under driver seat" run a power wire like 16/18 gauge to switch then run another wire from switch to relay......run a 12 gauge wire "depending on what wattage your running" from the battery to inline fuse then to relay...a ground to relay...and last a wire from relay to lights..
    sounds like alot but its nothing $20 bucks from radioshack and your set
  17. Dec 21, 2010 at 4:40 PM
    MountainEarth
    Bryan
    CO
    2010 TRD OR Access
