How To: Wiring Corner Lights as Parking & Blinkers
Discussion in '1st Gen. Tacomas (1995-2004)' started by bellassaiw10, Dec 16, 2013.
  1. Dec 16, 2013 at 8:47 PM
    bellassaiw10
    bellassaiw10 [OP] Formally afroman5015
    Currituck NC
    09 LMM 2500HD Duramax
    As the title says I'm gonna address how to wire the corner lights of an 00 Tacoma so that you can use them as Parking lights and also as blinkers.
    So I did the Blinker Relocation Mod where you drill an additional hole in your parking light and have two bulbs in the housing. I decided I only want one bulb yet still wanted to use my parking lights and have them second as turn signals. With a little research I finally completed it. Follow the links and view my "wiring diagram" :p Will upload more pics and some video tomorrow when my camera charges.
    To buy list:
    Turn & Stop Socket W/Ground from local auto parts store
    1157 Amber bulbs
    Some form of connectors I used Male & Female connectors
    Silicone
    Dremel Tool or Large Drill Bit.
    ScreenShot2013-12-09at83122PM_zps17ff29c_dbb17827fdaee449ecf8ff9aa83c515f938b2f4a.jpg
    PDF from this thread
    http://www.tacomaworld.com/forum/1st-gen-tacomas/81243-fog-light-mod-how-pics.html
    Reference to this thread.
    http://www.lieblweb.com/blinkerconversion.html
    Note* Use some test leads to figure out which wire goes to the "Bright" filament label it and use that for your turn signal.
  2. Mar 17, 2014 at 4:31 PM
    LSC15
    LSC15 Southern Retrofits
    Logan
    2008 TRD D-Cab
    2008 Double Cab - Current 2002 4runner - Sold 2001 Double Cab - Sold 1995 Xtra Cab - Sold
    Why don't you just help me do it Bo
  3. Mar 17, 2014 at 4:54 PM
    bellassaiw10
    Currituck NC
    $50 an hour
  4. Mar 17, 2014 at 4:55 PM
    LSC15
    Logan
    2008 TRD D-Cab
    How long it take
  5. Mar 17, 2014 at 5:27 PM
    bellassaiw10
    Currituck NC
    Bout an hour
  6. Mar 17, 2014 at 5:39 PM
    dispatch55126
    dispatch55126 Well-Known Member
    MN
    2004 Xtracab SR5
    Complete OME kit w/ 881's and dakars. All-Pro Sliders, CB, HAM Radio and various other minor stuff.
    Very slick and I like this setup bettef than the 2-bulb. Do the new fog lights throw decent light or is it just for looks?
  7. Mar 17, 2014 at 5:52 PM
    bellassaiw10
    Currituck NC
    I have rigids for fog lights now so yeah they throw plenty of light lol
  8. Mar 17, 2014 at 6:07 PM
    LSC15
    Logan
    2008 TRD D-Cab
    When can we do it
  9. Mar 17, 2014 at 6:11 PM
    bellassaiw10
    Currituck NC
    You can do it whenever you got time to
  10. Mar 17, 2014 at 6:12 PM
    LSC15
    Logan
    2008 TRD D-Cab
    Lets do it this week Bo
  11. Mar 17, 2014 at 7:21 PM
    dispatch55126
    MN
    2004 Xtracab SR5
    Its a very straight forward wire diagram. Dim setting is parking light and bright is turn signal. Are there any other Toyotas that run dual function bulbs? It would be nice to use a OEM tri-wire socket and not have to modify the lens.
  12. Mar 17, 2014 at 7:25 PM
    bellassaiw10
    Currituck NC
    I believe the 01-04s actually have a 3 pin socket in the turns didn't really research it though
  13. Mar 17, 2014 at 7:28 PM
    dispatch55126
    MN
    2004 Xtracab SR5
    Interesting. Do 4runners or Tundras have dual lamps? OEM costing would be to use as many common parts as possible.
  14. Mar 17, 2014 at 7:43 PM
    bellassaiw10
    Currituck NC
    Not sure id imagine they may though, I was thinking the same way but it was just easier to go buy the socket ha
  15. Mar 17, 2014 at 7:56 PM
    dispatch55126
    MN
    2004 Xtracab SR5
  16. Mar 17, 2014 at 7:59 PM
    bellassaiw10
    Currituck NC
    Good find
  17. Mar 17, 2014 at 8:15 PM
    dispatch55126
    MN
    2004 Xtracab SR5
    I have to go to the dealer next thursday. I'll check to see if the plugs are compatible.
  18. Apr 3, 2014 at 8:26 PM
    SR5Tac0
    SR5Tac0 Well-Known Member
    Los Angeles
    98 SR5 V6 4x4
    Did you ever find out if the plugs are compatible? I just smashed up my front bumper and would love to get on this as soon as possible.
  19. Apr 3, 2014 at 8:36 PM
    dispatch55126
    MN
    2004 Xtracab SR5
    Parts Dept was busy when I was there so they didn't have time to mess around. If it ever warms up around here, I may take a field trip to the local junkyard.
  20. Apr 3, 2014 at 9:00 PM
    frizzman
    frizzman Well-Known Member
    Pittsburgh, PA
    04 XCab 4x4 TRD/OR
    OME 2.5,Tundra 17s,Falken Wildpeak AT3W hitch w/ 7-pin, ARE cap, JVC HU w/BT, HID/LED lights
    the turn signals on 01-04 uses 3157 dual-filament bulbs. however they only utilize 2 wires (ground and turn) so you will need to add a 3rd wire for the "running" light to work
