How will 33" tires affect my gas mileage?
Discussion in '4 Cylinder' started by Tacoma9396jrc, Dec 8, 2011.
  1. Dec 8, 2011 at 2:14 PM
    Tacoma9396jrc
    Tacoma9396jrc [OP] Well-Known Member
    Jacob
    South Carolina
    96 4x4 tacoma 4 cyl
    Cherry Bomb exhaust, 3" suspension lift
    I have the 2.7 4 cylinder. I'm running 31x10.50's with a 3" suspension lift now, I'd like to upgrade to 33x10.50 or 33x11.50. How will these run on stock gears? Will I lose a lot of power and gas mileage?
  2. Dec 8, 2011 at 3:21 PM
    Tepidy
    Tepidy Well-Known Member
    Ted
    upstate NY
    11 tacoma 4x4
    Toytec Coil Overs 3.00" DSM UCA's (Desert Products) TSB 4 Leaf w/AAL by Pro Comp Bilstein 5100 rear 1"ToyTec SwayBar Drops 1" diff drop Detroit Trutrac Rear Diff Nitro 4.56 Gears Doug Thornley Header MagnaFlow Cat Back Exhaust Custom Built Rear Plate Bumper Custom Built Front Plate Bumper 4X Innovations Rock Sliders ATO Front Skid BAMF Rear Diff Skid Uniden 510XL Pro CB Raceline Renegades BF Goodrich Mud Terrains KM2's 265x75x16 WeatherTechs Rear Diff breather Relocate Intake Resonator Removed Yellow Wire Mod
    yes you will loose power and mpg's If you want to go with 33's then you should re-gear. If dd then 4.56's If for mostly off road then 4.88's
    bijick likes this.
  3. Dec 8, 2011 at 3:36 PM
    ST3VE
    ST3VE IG: @fishsohard
    MD --> SC
    Tint, car seat, baby wipes
    I put 33's and if I treat it like a virgin then I can get 300 miles out of the tank but if go between offroad and street and drive it normal I lose about 20ish miles a tank.
  4. Dec 8, 2011 at 8:01 PM
    907taco
    907taco Alaskan Assassin
    Bobby
    Alaska
    2010 BlackSandPearl 4x4
    ultimate lift kit ( toytec ) ome dakar leaf pack , w/ extended length billies, LR uca's, Pro comp 7089s, KM2's 285 70 17, neoprene seat covers, weather techs, CBI sliders w/kickout, URD ss, cab mount chop, VHT night shade tint>tails,3rd B-light. Debadged. Grillecraft grille, rear diff breather mod. CBI Moab front bumper, warn M8000 winch, HID kragens 7", Hella's micro fogs. retrofit headlights HIDS, LED solutions maps/license! 886 back up light mod,
    my 285's and 3" lift, i can go easy on it and get over 300mi. per tank, but mixed driving or strictly in town stop and go it drops between 20- 30 miles less per tank.
  5. Dec 8, 2011 at 8:20 PM
    Phuket
    Phuket Well-Known Member
    Travis
    Los Angeles
    03 4X4 TRD
    Eibach/Toytec coils, bilstein 5100's all around, Kenwood DNX7100 Navigation
    you will lose power for sure and unless you keep the tach below 2k you will lose MPG's like crazy
  6. Dec 8, 2011 at 8:38 PM
    bjmoose
    bjmoose Bullwinkle J. Moose
    San Jose CA
    '11 Std Cab 4x4 5sp
    I'm getting 16.5mpg after regearing to 4.88, same as before regearing.
    All numbers corrected for tire size, gear ratio, etc...
  7. Dec 8, 2011 at 8:40 PM
    45acp
    45acp Paint me back in Wyoming again...
    Jonathan
    Boring, Wisconsin
    1981 Long bed 4x4
    If I take it easy, I get 22mpg (stock 4.30 gears)
  8. Dec 8, 2011 at 8:48 PM
    jlvhrse
    jlvhrse Well-Known Member
    Jen
    SoCal SGV
    2009 TRD Sport 4X4 Long Bed
    LSK front and rear LT and stuff
    with stock gears and ~3" lift i lost about the same as everyone else, about 20miles/tank. According to my scan gauge I get about 18mpg combined which is pretty much the same as before... The power loss was noticeable but only really when accelerating from a stop.. IMHO totally worth it
  9. Dec 9, 2011 at 10:28 PM
    Tacoma9396jrc
    Jacob
    South Carolina
    96 4x4 tacoma 4 cyl
    Doesn't sound too bad. Any recommendations for tires? I'm thinking BFGoodrich mud terrain T/A...
  10. Dec 9, 2011 at 10:30 PM
    Tacoma9396jrc
    Jacob
    South Carolina
    96 4x4 tacoma 4 cyl
    Also, how much strain will 33's put on my motor? I got 250+ miles on the original motor, so I don't wanna overwork it
  11. Dec 10, 2011 at 7:12 AM
    Tacoma9396jrc
    Jacob
    South Carolina
    96 4x4 tacoma 4 cyl
    I have stock 4.10 gears if this helps
  12. Dec 16, 2011 at 4:38 PM
    Tacoma9396jrc
    Jacob
    South Carolina
    96 4x4 tacoma 4 cyl
    So will going with a wider tire make any difference as far as gas mileage?
  13. Dec 16, 2011 at 4:40 PM
    AndrewFalk
    AndrewFalk Science!
    The North East
    2010 5 speed 5 lug
    This is a simple physics problem. It doesn't matter which dimension of the tire is larger...a larger tire weighs more and requires more energy to move it. The only way your truck can produce more energy is by burning more fuel.
  14. Dec 16, 2011 at 4:43 PM
    186000mps
    186000mps ..Slingin' up mud and we're scarying off bunnies..
    Charles
    Wimberley, TX
    01 Tacoma V6 4WD
    Bilstein 5100's, Toytec front adjustable coilover kit, Exporear leafs, Fox resi rears, Slotted & Drilled front rotors, 33x12.50 BFG ATs on Outlaw II 15 x 10s, Bushwacker cutout flares, K&N cold air intake with aluminum sheathing water baffles, ARB bumper with XD9000 winch with wireless remote, IPF 900XS lights, Flowmaster cat-back exhaust, Rhino bed liner, UWS gullwing toolbox with tools and recovery gear. 48" Hi-Lift Jack secured under toolbox.
    yup
    More rolling resistance and more rotational mass
    I heard somewhere that it take 3x the force to move weight at the edge of the wheel than that centered at the center
  15. Dec 16, 2011 at 4:43 PM
    DPR921
    DPR921 Well-Known Member
    Dylan
    Cheshire, MA
    08 SR5 4x4 2.7
    They will effect Negatively.
  16. Dec 16, 2011 at 4:44 PM
    HB Taco
    HB Taco Well-Known Member
    Curt
    Huntington Beach, CA
    2019 F150 FX4 S Crew 3.5 TT
    yes / worse If your worried about gas mi. dont do it, otherwise suck it up. I only went up to 32" and it cost me about 1mpg. You could always get a prius! LOL
  17. Dec 16, 2011 at 4:46 PM
    moblarkus
    moblarkus Well-Known Member
    Mark
    British Columbia, Canada
    '06 Black Sand Pearl TRD Off-Road
    Satoshi grille, All-pro bumper, Allpro UCA's, Walker Evans coilovers, 10" Lightforce Blitz, PIAA 510's,Magnaflow cat-back, K&N CAI, Revtec rear blocks. TSB leafs, Firestone Ride-Rite air springs, Hopkins Agility brake controller.
    Negatively. You could put 4.11's in it or 4.56's but the increased ride height and tread will still hurt.
  18. Dec 16, 2011 at 4:55 PM
    Tacoma9396jrc
    Jacob
    South Carolina
    96 4x4 tacoma 4 cyl
    If losing only a mile or two per gallon is it, its not that big of a deal, I think I'm gonna keep my 31's for awhile tho, just in case
  19. Dec 16, 2011 at 6:37 PM
    Dustyroades
    Dustyroades Well-Known Member
    London, Ontario
    2019 TRD Sport
    It really depends on the load range/weight of the tire. Load range E's will kill your MPGs. I moved up from P245/75R16 to P265/75R16 and noticed no decrease in mpg, with possibly an increase on the highway.
  20. Dec 20, 2011 at 9:02 AM
    Toyoghi
    Toyoghi Well-Known Member
    Shoghi
    Calgary, AB
    2011 Tacoma Double Cab
    Solid tri-fold Tonneau, Deezee Bed mat, Pop n Lock.
    How does being an alcoholic effect your liver?
