how would dtr lights look white
Discussion in 'Lighting' started by elchimpo, Jun 3, 2010.
  1. Jun 3, 2010 at 10:39 PM
    elchimpo
    elchimpo [OP] Well-Known Member
    Gustavo
    Long Beach
    2009 SR5
    rims and stereo system
    how would it look if i change the light bulbs white led. Like the audi
  2. Jun 3, 2010 at 11:26 PM
    memario1214
    memario1214 Hotshot Offroad Moderator Vendor
    Colton
    Missoula, MT
    SOLD - 05 Dub Cab TRD Sport 4x4, CURRENT - '21 Tundra MGM Limited
    Well, just gonna throw this out there and say that just changing that bulb would not make it look any more like an audi than it already doesn't. People switching those to LED have been having issues with melting inside due to heat. Decent idea, I just think that others have done better audi type setups with these trucks.
  3. Jun 3, 2010 at 11:32 PM
    SC4333
    SC4333 Well-Known Member
    Grant
    FL
    SOLD - 2016 TRD Off-Road 4x4 DCSB
    You do realize that it doubles as your turn signal too, right? Not only that, LEDs are very directional in there light distribution, making it not easily seen from an angle. I would think it over pretty good before deciding to use white, much less an LED in the turn signal.
  4. Jun 4, 2010 at 1:05 AM
    yosh2000
    yosh2000 Well-Known Member
    CO
    '17 Tundra CM 5.7
    it would still be slightly tinted yellow, as that is the lense color. also, it would look pretty stupid, as LEDs are very directional as stated, so it would look like you have a quarter sized light coming from that area....
  5. Jun 4, 2010 at 1:08 AM
    Viet2100
    Viet2100 Well-Known Member
    Viet
    South Florida
    2016 Prius 4T
    It's impossible for it to melt because of heat. LEDs draw much less current than incandescents. LEDs can be brighter than incandescents if you buy the higher quality ones. Not the ones from eBay for $20. Go to v-LEDs.com and get their new dual color turn signal 3157. They're going to run you about $60. But they are bright because they use LEDs similar to the ones behind your gauge cluster. To fix the hyper flash, just simply get a set of load resistors from them as well.
    LEDs are directional, but the SMT LEDs give a wider output. The reflecor bowl will enable you to see the light from the same angles as an incandescent.
    I hope that helps.
  6. Jun 4, 2010 at 1:11 AM
    The_Hodge
    The_Hodge Volunteer Moderator
    SC
    15 Lariat Sport 5.0L
    more people here have issue from the stock DTRL's melting the housing than anything
  7. Jun 4, 2010 at 7:39 AM
    memario1214
    Colton
    Missoula, MT
    That must have been what I was thinking about... My bad.
  8. Jun 4, 2010 at 8:39 PM
    elchimpo
    Gustavo
    Long Beach
    2009 SR5
    this is the led bulb i want to get
    http://www.youtube.com/watch?v=Z3pMwMjPNQQ
  9. Jun 4, 2010 at 10:50 PM
    KaoskrewPB
    KaoskrewPB -Empty-
    Those look alot like blue, which is illegal in California, if you want the cops to stay away I would reccomend you not get those.
  10. Jun 5, 2010 at 12:19 AM
    Viet2100
    Viet
    South Florida
    2016 Prius 4T
    It looks blue but I bet it's white. Camera tends to oversaturate.
  11. Jun 5, 2010 at 1:01 AM
    808hawaii
    808hawaii Well-Known Member
    Jay
    Hawaii
    09 Prerunner
    HID 12000k bi-xenon RetroFIT projectors. 3000k HID fogs. Toyota Devil horn emblem. 30% tint all around. wet okoles front/rear. All lighting replaced with LED bulbs. JL Audio stealth box with two 10's. Alpine Speakers front and back
    Those bulbs don't work. Its suppose to white all the time, then amber wen turn signal turns on. Intalled it on my truck, they stayed amber the whole time. Some of the LEDs burnt out, had them for a year. Not really visible to oncoming traffic with you got HIDs too
  12. Jun 5, 2010 at 1:09 AM
    only_K
    only_K Future Owner
    Kevin
    Central California
    Currently searching for dream truck...
    TBD
    those are the switchback bulbs. Somebody has those on their truck on this site. He has an install thread for them too.
  13. Jun 5, 2010 at 1:21 AM
    808hawaii
    Jay
    Hawaii
    09 Prerunner
    Cool thanks.. will do a search for it. I went ahead and jus installed my oem drl bulbs
  14. Feb 1, 2011 at 10:03 PM
    JGray83
    JGray83 Active Member
    Jon
    Newport Beach
    white tacoma trd sport
    working on it
    I put blue super white bulbs in the dtrls and parking lights they look awesome. No pics yet sorry
