Howling help.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Matt19703, Jan 11, 2021.
  1. Jan 11, 2021 at 5:23 PM
    Matt19703
    Matt19703 [OP] Member
    2013 Tacoma base double cab short bed
    Hello all,
    Let me start by saying I'm completely new to Tacoma's. I just recently bought a used 4.0L 2013 Base Double cab short bed with 103k . Coming from a jeep wrangler that was a daily driver and a weekend offroader, I've come across plenty of repairs.
    I bought the truck a few months ago and it sounded great ran perfect appeared well taken care of. Just came across a howl when driving starting at 35mph loudest at around 40-60.
    While I haven't checked the wheel hubs jacked up I've done the turning at speed check and no change in sound. Read about the needle bearing, the it in 4wd no change. Checked the drive shaft bearing no play or anything so I'm a little lost at what else it could be. Yes it could be the hubs, bit for them both to go bad at the same time seems a little odd.
    Any ideas?
  2. Jan 11, 2021 at 5:39 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    I think I'd check wheel bearing's first both front and rear, tires can cause a howl too especially ones with a more aggressive tread pattern.
  3. Jan 11, 2021 at 5:51 PM
    gearcruncher
    Canadain bumper technician
    What happens when you take your foot off the gas pedal ? can you still hear the howl during coast ?
  4. Jan 11, 2021 at 5:55 PM
    fxntime
    fxntime Well-Known Member
    2015 Tacoma off road TRD and 2014 FJC
    Load [turn the wheel] each front wheel and see if it changes pitch or goes away for a second and comes back when you correct the wheel back to straight. The wheel that is loaded [outside wheel] should remain or become noiser, the one that is unloaded should be quieter.
  5. Jan 11, 2021 at 7:49 PM
    Matt19703
    Gearcruncher noise is there regardless of gas pedal input. On the gas, off the gas, coasting in neutral the only thing I haven't done was kill the engine while coasting. I don't think its the tires though I've had a lifted jeep with 33s and the tire hum is definitely a different sound. I'll check the wheel bearings on stands this weekend but while it's up, I plan on checking the other bearings. Any input on what I'm looking for as far as the needle bearing play?
  6. Jan 11, 2021 at 7:57 PM
    gearcruncher
    Wheel bearings can be difficult to diagnose with the wheels off the ground as you are essentially removing the load from the bearing . A faulty bearing may have some back and forth movement but in those cases , the bearing is highly worn out
    https://www.tacomaworld.com/threads...g-differential-in-a-14-its-normal-huh.366687/
    East coast gear supply bushing .....you are checking for axle play at the drivers side front diff .
    https://www.tacomaworld.com/threads...differential-bearing-vibration-thread.152173/
    I seem to recall a post regarding vents on the back of the truck cab causing a howling noise .
    I will have a look for the post
    https://www.tacomaworld.com/threads/2012-access-cab-excessive-road-noise.242628/page-2
  7. Jan 11, 2021 at 7:59 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Sounds like my son's differential...
    Drain some of the rear differential fluid and see if it looks like it has glitter in it.
    Chiloquin_Car_Care likes this.
  8. Jan 11, 2021 at 8:11 PM
    Sprig
    Sprig Well-Known Member
    Ken
    N. Calif. The Twilight Zone
    Tacoma TRD double cab 4x4, Barcelona Red
    Had the same thing recently with my 2009 4x4 Taco. It kind of sounded like a howl, or road noise or aggressive tire road noise. It was most noticeable between 35mph and about 55mph. It was a wheel bearing. Brought it to my favorite garage and they confirmed it was a wheel bearing, left front wheel bearing. They replaced it parts and labor about $600. Sounds to me like you have a bad wheel bearing.
  9. Jan 11, 2021 at 8:12 PM
    Matt19703
    Gearcruncher so there should not be any play?
    Jimmyh that was another possibility I was thinking. I really hope its clean, I just bought the damn thing
  10. Jan 11, 2021 at 8:21 PM
    gearcruncher
    Very seldom do you get much play in a wheel bearing unless it is in very bad shape .
    Got any warranty on your truck ?
    I dropped a couple links for you to check out in my post above
  11. Jan 11, 2021 at 8:29 PM
    Matt19703
    Sorry I meant in the cv axle to the needle bearing. I was going to check play for the wheel bearing, but also listen for noise and feel for vibrations.
    I'll check out the links and I do have a powertrain warranty I want to know for certain what it is before I bring it in though. I appreciate all the help
  12. Jan 11, 2021 at 11:08 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    Drain some of that differential oil into a clean pan and you will know.
  13. Jan 12, 2021 at 2:36 AM
    TACOMA2NDGEN
    TACOMA2NDGEN Well-Known Member
    ROLAND
    new jersey
    2010 dcsb silver sport trd
    baja squadron pros
    Im having same issue as OP. I determined it was my wheel bearing especially the passenger front. I lifted wheel of ground and theres a little play in the tire. And when you spin the tire by hand you can hear the noise. I have a full set coming this Friday from a member on here who assembles them. Just hope the weather holds up this weekend
    Island Cruiser and Sprig like this.
  14. Jan 12, 2021 at 5:00 AM
    fourfourone
    fourfourone Well-Known Member
    2015 TRD sport(sold) 2023 Tacoma
    do you have all terrains? I have cheap coopers adventure AT that came on my truck. If I don't rotate them, they get Super noisy. 40-60, they howl like crazy. As soon as I rotate them, the noise goes away about 80%. Then they slowly get louder again.
    Before everyone jumps to conclusions, take a look at the tires. Rotate them and see if the noise is different. Do you see any cupping on the front tires?
  15. Jan 12, 2021 at 5:24 AM
    Rocketball
    Rocketball If The World Didn't Suck, We'd All Fall Off
    Scott
    Westminster, MD
    08 Speedway Blue DC Sport 4x4
    Pioneer head unit, PAC steering wheel control modual, Hard wired Sirius radio, Hard wired radar detector, Hella Supertone horns, Blacked out badges, Smoked Tails, BHLM (color matched Speedway Blue), T-Rex Eyelids, Black Powder Coated Billet Grill, Color Matched Engine Cover, Lund in channel vent visors, FJ Cruiser wheels, Leer 100XQ shell, OEM bed mat, Piezo beeper for locking doors, Tinted front side windows, Black Westin bull bar, Aires tube steps, Mini Maglite Mod, D-Cell Maglite Mod, Weathertech Digifit Floor Mats
    Something else to check are the rubber moldings that run the lenght of the roof on each side. Historically they have had a tendency to come loose just a bit in the front and make a noise just like described. My driver's side one began to come loose and made a horrible howling noise at higher speeds. Most times when the vehicle is stopped, they lay back down so you don't notice them. If you catch it early enought a little all weather adhesive to glue them back down is all that's needed.
  16. Jan 12, 2021 at 2:37 PM
    Knute
    Knute Well-Known Member
    '06 4.0L Tacoma TRD Sport
    Stock, 4WD, Access Cab, White,
    Have you looked at the serp belt idlers and tensioner pulley bearings???
    Power steering pump?
    A/C clutch bearings?
    Alternator bearings?
    Simple test. Remove the serp belt, take a short drive....does the noise remain? Yes, you can drive for a few miles without problems.
    Many times the solution isn't the most expensive item.
  17. Jan 15, 2021 at 9:21 PM
    fxntime
    Don't do this. While you can pull the belt, start the engine and run it for a short time, a couple mile drive is apt to overheat the engine as no coolant is moving thru the system. The gauge may or may not pick it up as the coolant isn't circulating past the temp sensor. [that is why, if your coolant is low, you don't get any warning that your engine is overheating, there isn't any coolant to read off of]
    06Tacooo likes this.
  18. Jan 16, 2021 at 7:28 AM
    Knute
    The key is a short drive.....I didn't indicate to take a long trip.................... say like a drive around the block.
    The engine won't overheat instantly.
    gearcruncher likes this.
  19. Jan 22, 2021 at 9:48 PM
    Matt19703
    Its definitely not the serp belt as the noise is there coasting with the engine off. I found time to jack the front end up and check the hubs. I didn't feel any play and they sounded smooth. My next step is to rotate the tires and check the diff oil. Thanks again for everyone's help!
    Jimmyh likes this.
