how's a 1st gen supposed to drive?
Discussion in 'Suspension' started by summerboy1958, Dec 28, 2010.
  1. summerboy1958
    summerboy1958 [OP] Well-Known Member
    Bruce
    Newark, De
    01 SR5 4WD, Radiant Red
    Hidden Hitch Trailer Hitch, Timbren Shock Assist System, Billy 5100's all around, Deck plate mod, AFE Pro Dry air filter, Amsoil 85W-90 Severe Gear Oil in the transmission/differentials/transfer case.
    I have a couple of questions about the suspension in the 1st Gen Tacoma. I have had my extended cab for about a year now. When I drive it over a twisty road with a rough surface, the ride is… well… exciting? It bounds and jumps around. I have always figured this was just the way thy ride. On straight bumpy roads, the ride feels like any other pick up truck, rougher than some, but not too bad.
    I installed Timbren suspension assists because I haul my own firewood. When I first installed them, there wasn’t the suggested 1” of clearance over the axle, but I didn’t think much of it as the ride didn’t seem to change. That is until I went over the nearby railroad crossing. The Timbrens bottomed out with no load and it felt like my spine had gotten shoved through my skull. I called Timbren and they sent a set that was shorter. That seemed to solve the issue. With the increased clearance, the ride over the rail crossing was just a bump, like before. The truck has run fine for several months, whether loaded with wood or driving to work.
    I finally got enough money to replace my tires and went with the Michelins. The ride is great, still bumpy, but muted. All was great until I went over the rail crossing. It’s back to spine crunching. I checked under the truck to see if the Timbrens had come loose, but they look fine.
    Here are my questions.
    • Is it normal for the front end of a 1st Gen to bounce around when on twisty, bumpy roads (at 45 – 65 MPH)?
    • Got any idea what might have happened to my rear suspension when they installed my tires? Is there anything I should look for? Is there a picture I could take that would help the diagnosis?
    [FONT=&quot]Any help is appreciated!![/FONT]
