HP Tuners for 2005-2015
Discussion in 'Performance and Tuning' started by Hacktacular, Mar 24, 2019.
  1. Apr 24, 2019 at 11:17 AM
    #2001
    Roostfactor
    Roostfactor Well-Known Member
    TX panhandle
    2015 DCSB OR Pyrite Mica
    HPT/justDSM tuned factory ecu, URD Headers, JFR Y-Pipe/l 3" exhaust, Walbro 255 fuel pump, Maggy SC (JFR ported), JFR ported lower intake manifold, 76mm tb, 2.5 pulley, 640cc injectors, CSF Radiator, custom electric fan wit Autocoolguy controller, JFR SC pulley wrap mod
    I changed the whole airbox assy including the sensor, so the MAF is already calibrated to the tube diameter, and the scaling was taken directly from a Tundra. I used the Tundra scaling values and input into the Tacoma ECU. Am I missing something here?
  2. Apr 24, 2019 at 11:18 AM
    #2002
    OVTune
    OVTune Well-Known Member
    OVTune
    Since you want to be snarky when I'm just posting MAF 101 tuning.
    Explain to us why swapping the sensor is better than rescaling stock sensor????
    Hacktacular[OP] likes this.
  3. Apr 24, 2019 at 11:21 AM
    #2003
    OVTune
    OVTune
    What I am saying is its not even necessary to change the sensor when you resale the stock for larger diameter tube. It's MAF 101
    I even posted a maf equation for this. I'm trying to be absolutely respectful and give help how I can. Snarky comments aside this is my day job for 10+ years.
    Torspd and Hacktacular[OP] like this.
  4. Apr 24, 2019 at 11:33 AM
    #2004
    loginfailed
    loginfailed Well-Known Member
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    I'm glad WE were able to do all the testing to get this figured out. This was totally my idea. @Torspd knows. :D
  5. Apr 24, 2019 at 11:34 AM
    #2005
    OVTune
    OVTune
    I'll show you my point . I am doing a 2nd Gen SC truck on 4 inch maf and STOCK maf.
    I'm just asking why. No reason to grab pitch forks.
  6. Apr 24, 2019 at 11:45 AM
    #2006
    JustDSM
    JustDSM Oderint Dum Metuant
    Justin
    Ogden, UT
    If you’re genuinely asking, it’s not that using the Tundra setup is “better” than rescaling the stock MAF in the larger housing. It’s for 1) to test. 2) because it’s already factory calibrated and gives known values for every reference voltage. It’s about elimination of variables when you’re making adjustments to other parameters. 3) it can offer some folks the OEM “appearance” while still allowing increased headroom in airflow.
    It’s just another way to skin the cat.
  7. Apr 24, 2019 at 11:55 AM
    #2007
    JacksonTacoma
    JacksonTacoma Well-Known Member
    James
    Jackson, MI
    2015 S/C TRD Pro
    Magnuson SC, 2.5 pulley, hptuner, FPR mod, AFE Intake, URD longtube headers, JFR Y-pipe, 255 Deatschwerks, 76mm TB, Banks 3" exhaust, cam gears
    Any reason why you went with 4"?
    I got a 3.5" housing...some of the local shops I talked to suggested 0.5" larger would be plenty for scaling....but admittingly, they've never tuned these Tacomas.
  8. Apr 24, 2019 at 11:56 AM
    #2008
    OVTune
    OVTune
    Yes I was genuinely curious, because it's a method people used to do years ago before calibration was well understood.
    And FYI, so we can get this out of the way right now. This thread, from the looks of it and comments is about using HPTuners and making tunes.
    I'm a tuner, and also a car enthusiasts. This isn't "justDSM tuning" thread.
    I don't want to see people get stuck or go backwards and have no problem giving tips or helpful hints. I literally posted dyno tuned VVT tables. That ain't free for me to make those tables. So if you want to be assholy to me for simply asking questions, go make your own thread.
    Shaeet and redtaco2007 like this.
  9. Apr 24, 2019 at 12:01 PM
    #2009
    o0opackersfano0o
    o0opackersfano0o Well-Known Member
    Tony
    North Berwick, ME
    2005 xrunner swb
    Magnuson supercharger, 2.6 quick change pulley, 76mm throttle body, Doug thorley long tubes, urd y pipe, wot box with 2 step, 170 thermostat, airaid intake, urd short throw, djm 3/4
  10. Apr 24, 2019 at 12:03 PM
    #2010
    OVTune
    OVTune
    In reality 3.5 is plenty but 4.0 was chosen.
    Fact is there is a 65535 16 byte limit on the maf scale so regardless of tube you'll never get past the byte limit which translates to 4xx g/sec (don't quote me on that I have to double check exact amout)
    I'm not here to start any BS. Just watching from the side and inputting years of experience where I can.
  11. Apr 24, 2019 at 12:04 PM
    #2011
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    @JustDSM has gone above and beyond to help most of us.
    My honest opinion is you’re the snarky one. But thanks for the help, tho.
  12. Apr 24, 2019 at 12:04 PM
    #2012
    JustDSM
    Justin
    Ogden, UT
    512
  13. Apr 24, 2019 at 12:09 PM
    #2013
    o0opackersfano0o
    Tony
    North Berwick, ME
    2005 xrunner swb
    im going 5" intake just because...
  14. Apr 24, 2019 at 12:11 PM
    #2014
    Roostfactor
    TX panhandle
    No one ever said it was @JustDSM's thread! Of course you are welcome and your experience/expertise is much appreciated. @JustDSM is simply the MOST qualified REGULAR here with PROVEN skills, fast replies, and dedicated time to this platform. This is essential for many who have already worked with him getting things dialed in. He has also educated a large number of us to help us get started which is very difficult to put a pricetag on. Mas, mas appreciation @JustDSM!!!!!
    I have no doubt you are extremely knowledgeable with the ability to dial us all in, the simple fact is, @JustDSM has more time to dedicate to this one platform and to help the masses which we so desperately need! Please continue to post your opinions and recommendations as it will only benefit the community. Thank you @OVTune/Matt!!!
  15. Apr 24, 2019 at 12:12 PM
    #2015
    OVTune
    OVTune
    I'm not, at all trying to be. Simply asking why, because it's rarely done these days as a tuning method, and almost always for the wrong idea. (Rescaling maf cal).
  16. Apr 24, 2019 at 12:15 PM
    #2016
    DiamondW
    DiamondW Stockblocker
    Kent
    Gonzales Co. TX
    ‘06 AC SR5, ‘17 Tundra, ‘14 GX460
    Very well said, and ditto!
  17. Apr 24, 2019 at 12:18 PM
    #2017
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    All I can suggest is maybe use a lighter touch. It helps keep everyone’s blood pressure down at healthy levels.
  18. Apr 24, 2019 at 12:19 PM
    #2018
    Murphinator
    Murphinator Well-Known Member
    Anthony
    SoCal
    14 DCSB 4x4
    I think we’re all here for the same reasons. We just wanna go fast with out our motors going boom boom.
  19. Apr 24, 2019 at 12:43 PM
    #2019
    HPTuners
    HPTuners Well-Known Member
    I have already added LTFT enable/disable params for Tundra and will add for Tacoma (i'm building a list of params to add to all definitions). Unfortunately Toyota has no scanner function to reset fuel trims, i have checked :(
  20. Apr 24, 2019 at 12:45 PM
    #2020
    HPTuners
    Send us a photo of your PCM part # we will order it and get the file the hard way.
