HP Tuners for 2005-2015
Discussion in 'Performance and Tuning' started by Hacktacular, Mar 24, 2019.
  1. Apr 25, 2019 at 6:52 AM
    #2101
    Sacrifice
    Sacrifice Motorcycle Goon
    KS
    DCSB OR 4X4 LT
    Pelfreybilt Front Bumper,BAMF sliders, Airflow Snorkel,Mini D2S Retrofits, ADS Rear Shocks, Deaver U402 Leafsprings, 35s, AllPro +2LT
    this would be useful. my biggest gripe is when going up hills and cruise control. trans drops a gear to regain speed then upshifts again (while still on hill) only to downshift again. STUPID. ecu should look at the load and see that it hasnt dropped a reasonable amount to estimate the ground leveling out
  2. Apr 25, 2019 at 7:13 AM
    #2102
    ThomasMore66
    Dallas/Fort Worth & Durango
    Hmm, in Texas we don’t have hills. Well, there are overpasses.
  3. Apr 25, 2019 at 7:47 AM
    #2103
    loginfailed
    loginfailed Well-Known Member
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    You definitely have the ability to adjust how much throttle it takes before it tries to downshift. Not saying you want it to, but you can tell it basically "don't downshift until WOT" if that's what you wanted it to do.
    DesertRatliff likes this.
  4. Apr 25, 2019 at 7:49 AM
    #2104
    Sacrifice
    KS
    DCSB OR 4X4 LT
    And thats per gear shift it can be set? So 4->3 and 5->4 can be different? Realiatically i dont want either to downshift unless the truck is being commanded 100%. But i dont want it to upshift again until the engine load goes down which would be the trickier part.
  5. Apr 25, 2019 at 7:52 AM
    #2105
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    Yes, upshift and downshift throttle positions can be set individually and can be different for each gear. You can also tell the torque converter when you want it to lock and unlock in each gear. That weird thing it does in 3rd where it shift and then the RPM goes up can be adjusted too.
    05Taco4x4 and DesertRatliff like this.
  6. Apr 25, 2019 at 7:54 AM
    #2106
    Sacrifice
    KS
    DCSB OR 4X4 LT
    Deal. Sounds like i might be buying one soon and using it on both my vehicles.
    loginfailed[QUOTED] likes this.
  7. Apr 25, 2019 at 7:56 AM
    #2107
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    Just remember that values you see in the transmission tables are for the driveshaft speed, not engine RPM. So you have to think about what gear you are in, and do the math against that gear ratio in order to select a certain engine RPM. Also have to account for toque converter slip. So if say I want the 2nd gear WOT to shift to 3rd at 5600 RPM, I need to do the math to get it it to shift at 5600 RPM, but subtract a feww hundred RPM to account for slip.
  8. Apr 25, 2019 at 8:03 AM
    #2108
    Sacrifice
    KS
    DCSB OR 4X4 LT
    cool. ill reach out im sure if i have questions. didnt you post that formula in here?
    just ordered...will be doing sai delete too cause fuck that stuff. @Roostfactor can i get a blockoff plate?
    too bad the tacoma needs more credits than my gto :bananadead:
    Roostfactor likes this.
  9. Apr 25, 2019 at 8:07 AM
    #2109
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    Much of the issues with the cruise control are the fact the coding for it makes it slow to react, not necessarily the trans. For the case of it hunting while going up hill, the problem is it allows the truck to slow down too much, then goes, crap im going way to slow, needs tons of gas, drops a gear or two while keeping way too much throttle, then blows by the target speed and lets off the throttle and repeats the process all over again. Anytime im using cruise control and see a hill coming up that i know the truck will not make it up in 5th locked, i pop it over to 4th in the flats, which allows the truck to get into 4th locked, and the cruise control can keep the same speed up the hill without hunting because it can get back to target speed without as much gas.
    I have always wondered why there isnt a 3rd gear torque converter locked state. 4th and 5th the torque converter lockup clutch can do its thing if all the conditions are met, but somewhat here n there ill find myself needing 3rd to pull hills (whether towing up the grapevine, or loaded up pulling the shirwin grade in altitude, or both) and always wished that 3rd would also lockup to keep trans temps down. Do you think it would be possible for us to add this?!?!?
    Good to know! Driveshaft speed, check!
  10. Apr 25, 2019 at 8:08 AM
    #2110
    DesertRatliff
    DesertRatliff Well-Known Member
    Mt. Hood, OR
    Mas Tacos Por Favor
    Can you provide me/us with instruction on how to do just this? PM if necessary so I don't clutter up the thread with too much personalized stuff.
    Looking forward to playing with these parameters on JustDSM's version 3.0 tune for me (which is running @#$%ing outstanding, BTW).
    JustDSM, TodayWasTHeDaY and nd4spdbh like this.
  11. Apr 25, 2019 at 8:09 AM
    #2111
    Roostfactor
    Roostfactor Well-Known Member
    TX panhandle
    2015 DCSB OR Pyrite Mica
    HPT/justDSM tuned factory ecu, URD Headers, JFR Y-Pipe/l 3" exhaust, Walbro 255 fuel pump, Maggy SC (JFR ported), JFR ported lower intake manifold, 76mm tb, 2.5 pulley, 640cc injectors, CSF Radiator, custom electric fan wit Autocoolguy controller, JFR SC pulley wrap mod
    Sure can, send me a PM with full name and address and I will send you my Paypal. Im shipping a set out today.
    JustDSM and Sacrifice[QUOTED] like this.
  12. Apr 25, 2019 at 8:11 AM
    #2112
    DesertRatliff
    Mt. Hood, OR
    Mas Tacos Por Favor
    I basically use 3rd gear at near WOT for at least 2, 2-5 minute intervals everyday. I'd LOVE this info/modification (and I know my A750 would too).
    nd4spdbh[QUOTED] likes this.
  13. Apr 25, 2019 at 8:16 AM
    #2113
    Sacrifice
    KS
    DCSB OR 4X4 LT
    i agree with your statement. im just thinking this is going to be a way around it since the cruise control logic cant be modified. essentially just make it hold the lower gear until it reaches the preset again. usually going up a hill is pretty high throttle so it should be manageable to set a lower a number to where it drops under (reaching level) then upshifts
  14. Apr 25, 2019 at 8:20 AM
    #2114
    nd4spdbh
    SoCal
    It would definitely help this case (of cruise hunting) to say hold the gear 200rpms more, so cruise can "catch up" and go oh, well let me slow down and have the trans not try to upshift again.
  15. Apr 25, 2019 at 8:25 AM
    #2115
    Sacrifice
    KS
    DCSB OR 4X4 LT
    if i can get this to work it means ill have a useable 5th again on the highway (315s and stock gears arent exactly the friendliest for 5th gear)
  16. Apr 25, 2019 at 8:27 AM
    #2116
    DocME
    DocME Well-Known Member
    California
    '07 FJ Cruiser
    TRD S/C, UCON, 61# inj, 2.5 pulley, 7th inj, Roostfactor Y Pipe, URD exhaust, WAT Nomad Valve body, Dana 60, DK LT, JD FAB LCA mounts, custom roof rack...and way too many others.
    You should definitely get a supercharger. It'll hold gears all day long going up hills.....
    Edit: and Gears...
  17. Apr 25, 2019 at 8:31 AM
    #2117
    nd4spdbh
    SoCal
    yeah 315's and stock gears are NOT helping at all.
    JustDSM likes this.
  18. Apr 25, 2019 at 8:34 AM
    #2118
    DocME
    California
    '07 FJ Cruiser
    Yeah, I responded then saw the post about stock gears. Hell even with the supercharger I couldn't hold 5th on level ground on the freeway with 315's. Gears then supercharger, it's decided.
  19. Apr 25, 2019 at 8:37 AM
    #2119
    findingthingsout
    findingthingsout Well-Known Member
    midwest
    08 Tacoma TRD O/R A.C. MT
    Boost, armor, lights, big tires, no savings.
    This is exciting. Read a lot of this thread, but not all.
    But I gotta play Devils Advocate. Is there any concern with everyone all at once dramatically changing these tunes away from the TRD/ UCON tunes that have shown to be reliable for over a decade? Albeit Pig Rich. I see all these claims of increased MPGs, HP, and throttle response. Is there issues with people running cats and having them burn out? Have there been any Dyno runs to prove the effectiveness of the adjustments? Is there anything that can be learned/ carried over from the findings of Gadget/ Scott and the specifics of the 1GR; like cyclinder variation.
    Trying to justify ditching the UCON but want some Data. Is there any benefit of running the UCON with the HPtuner, like logging, 7th inj control?
    Roostfactor, JustDSM and DocME like this.
  20. Apr 25, 2019 at 8:45 AM
    #2120
    DocME
    California
    '07 FJ Cruiser
    Great questions, all of them........I think more time and testing is going to be required. It does all seem too good to be true, time will tell on the reliability aspect. I have the UCON as well, and the HPTuner/Flow matched injectors in cue. I'm going to wait for a little more information before I get too far. I'd like to see what a good tune on this setup produces.... I am intrigued by the increased fuel mileage. Ever since I upgraded to all my listed high performance goodies, my mileage is absolutely terrible. I would be willing to back off the peak horse power figure for some of the drive-ability improvements the HPtuner seems to offer....Then again, maybe I won't have to give that up.
    Roostfactor and JustDSM like this.
